Topic: overlap add in window swiching (Read 3553 times) previous topic - next topic
Hello ~~
  I know how overlap and add afer IMDCT helps is zeroing the aliasing in equal size winodw .
  But I am not able to find it mathematically when it is winodw switching . Can anyone explain me that
regards
leen
I prefer to view the (i)MDCT as 2 seperate orthogonal transforms. It eases the implementation and reduces the probability of using a false window sequence.
MDCT (forward)
a) butterflies (rotations) between blocks (dependant on the window function)
b) MDCT-core transform on blocks (involutional orthonormal matrix)
iMDCT (inverse)
a) MDCT-core transform (because this transform is its own inverse)
b) inverse butterflies to "cancel the blocking"
the n*n "MDCT-core" matrix A is given by
A_{i,j} = \sqrt{\frac{2}{n}} \cos \frac{(i+0.5)*(j+0.5)*PI}{n}
(for i,j = 0...n-1, n being the number of subbands)
If you look at this matrix and at the "official" MDCT definition, you'll able to figure out, what I meant by the butterflies-rotations. (I don't know how to explain it well right now)
With this perspective it's IMHO easy to realize how the whole thing is a perfect reconstruction filterbank - even with different windows and transform block lengths.
Unfortunately Vorbis's MDCT is a flipped version of this. You have to reverse the time signal *or* have to code a forward-core and inverse-core (not involutional core anymore)
BTW: It's possible to reduce the MDCT-core transform to a n/2-point complex FFT with some pre/post rotations.
HTH,
Sebastian
Can you clarify this statement? Do you mean there is a better way to detect block size changes?
Hello ~~
regards
leen
Do you mean window switching by block size switching ? Because in AAC there is another window shape switching between sin window and KB window !!!
As for block size switching.. I am afraid (as far as I know) it is very much an "ART"... Not one single technique is sufficient to correctly switch 100%.. In AAC, there is even additional tools to aid block switching just in case it fails.. the TNS tool & Gain Control tool..
What do you mean by "detect a blocksize" ?
I just said to that the whole MDCT stuff is equivalent to the procedure I described above and that it's IMHO easy to realize the correctness of it this way because the whole thing is a concatenation of 2 orthonormal transforms.
Consider you've already chosen what packet-modes you want to use for encoding (short or long transform).
...|xxxxxxxxxxxxxxxx|xx|xx|xxxxxxxxxxxxxxxx|xxxxxxxxxxxxxxxx|...  (time signal)
The remaining thing is: apply a bunch of rotation butterfliess across each | dependant on the transition function (window-half) and do the "MDCT-CORE" transforms by applying its square orthonormal matrix to all the blocks.
Hello ~~
AAC != Vorbis
You're obviously referring to an encoder's job to chose the "best" transform, right ?
I don't know if the OP cares about this. (?)
bye,
Sebastian
Maybe this view of the (i)MDCT is usefull.
see here
If you want to join a short transform and a long transform just use the "short-butterfly-set" for the block boundaries.
bye,
Sebastian
