Topic: foobar wont play this mp3 (Read 6725 times) previous topic - next topic
When trying to play this file, foobar just skips to the next song without any error messages.
It worked fine when using some older version of foobar (IIRC 0.7.7 still worked fine).
Anyway, here's the file.
[TOS #9 violation, file removed]
Can't reproduce with foobar2000 0.8.
Regards.
I downloaded the file to test, but it played without any problem for me.
This is with foobar 0.8 (special install, including all components).
Included below is the "Technical Info" from the "Properties" dialogue for your file.
Maybe it will help you in some way.
The encoding delay and padding values seem a bit odd to me.
Do you know which encoder was used to create the file?
enc_delay = 889
enc_padding = 1211
mp3_accurate_length = yes
bitrate = 128
codec = MP3
channels = 2
samplerate = 44100
mp3_stereo_mode = joint stereo
replaygain_track_gain = -9.69 dB
replaygain_track_peak = 1.366489
replaygain_album_gain = -10.09 dB
replaygain_album_peak = 1.366489
16125900 samples @ 44100Hz
File size: 5 852 354 bytes
      /b9AcE
It works with normal 0.8 standard input but not with the modified one delivered with kode54's mad input plugin (at least here).
Regards,
The Link
Works here with 0.8. Doesn't sound good though - prolly cos its not my kind of music...
Reproduced. Won't play. No error messages. This is with the foo_input_std that came with Kode54's foo_mad. Neither mpglib nor MAD decoder helps. The foo_input_std that came with the last special installer (0.8) plays it back just fine. Also tried 1by1 with the in_mad plug for reference. Played back just fine. Didn't bother to try more players.
But are you really sure you want to playback this file? It might be Peter buildt a quality control filter® into the latest version of foo_input_std...?
Evil xing file, incorrect gapless playback data gets read.
Temporary fix.
Now that the link was removed could anybody tell me what song it was? I'm curious seeing such comments.
Lullacry - Fear Dance from an album called Sweet Desire. I never heard such a bad encode@128 MP3
It could have been Blade.
Yes I want, as I can't find the CD (I think it's not avaliable anymore, at least according to their website) and I can't get my hands on a better rip of the CD either.
Info retrieved with Tag/Tagger and EncSpot:
D:\Desktop\fooNEWs\other\Lullacry___Feardance.mp3
Format:  MPEG 1 Layer 3, Joint Stereo
Details: 44100 Hz Stereo, 128 kbps, playtime 06:05
Tags:    ID3v1, APE v2.0
Title:  Feardance
Artist:  Lullacry
Album:  Sweet Desire
Year:    1999
Track:  10
Genre:  Metal
Comment:
FULLALBUM=True
RATING=4
replaygain_track_gain=-9.69 dB
replaygain_track_peak=1.366489
replaygain_album_gain=-10.09 dB
replaygain_album_peak=1.366489
Bitrates:
128     ||||||||||||||||||||||||||||||||||||||||      100.0%
Type                : mpeg 1 layer III
Bitrate             : 128
Mode                : joint stereo
Frequency           : 44100 Hz
Frames              : 14001
ID3v2 Size          : 0
First Frame Pos     : 0
Length              : 00:06:05
Max. Reservoir      : 511
Av. Reservoir       : 275
Emphasis            : none
Scalefac            : 71.4%
Bad Last Frame      : no
Encoder             : Xing (new)
Lame Header         : No
--[ EncSpot 2.1 ]--[ http://www.guerillasoft.com ]--
EncSpot 2.1? Where do I get that from? I only seem to be able to find v2.0...
Ehmmmrr.... (think hard) .... I can't really remember straight away, and I'm not sure that when I remember (I can check out later, and anyways I got a backup of the installfile somewhere) that the answer would be appropriate for these forums. Might have to find some other solution ....
