Topic: Offset (Read 3517 times) previous topic - next topic
Offset
Can you help me to find the offset setting for my two readers?
Pioneer DR-A04S
LG CD-RW CED-8042B
Sorry for my bad english.
Il valore di un uomo, per la comunità in cui vive, dipende anzitutto dalla misura in cui i suoi sentimenti, i suoi pensieri e le sue azioni contribuiscono allo sviluppo dell'esistenza degli altri individui.
A. Einstein in "Come io vedo il mondo"
Offset
I read the tutorial about offset but I didn't understand how to configure the drive.
Any help?
Do you know the value of the read/write offsets?
Offset
do you have a burner?
Offset
btw.: I suggest you read the tutorial a little better.
Offset
you are italian, so you can find all the infos and tutorials you need here :
http://eac-italia.da.ru
ciao!
Fede
Offset
Yes I've read the list of drives in www.ping.be but my drives are not listed.
I'll try to read carefully the italian tutorial.
Thank you guys.
Offset
Did you run the configuration wizard of EAC ? It has a larger offset database than Coaster Factory.
Offset
Yes I configured EAC with the wizard but the offset values were always the same. I'll try again.
Offset
If there are some values stored for your drive, the wizard will tell you. If it didn't tell, it means that there is nothing.
