Topic: foo_pod - Foobar2000 meets the iPod (Read 1225742 times) previous topic - next topic
Reply #50
Wow, this is going to be a great plugin!
I am using EphPod at the moment, but I will absolutely switch to foo_pod when its out...
Solaris
Reply #51
Then I'll add Lua scripting support, along with some more unusual ideas I have been coming up with.  Like an iPod to iPod sync - this would be a quick way to duplicate one iPod to another, or copy missing files so that both iPods would have the same set of songs.
I guess when you get the big bucks for doing foobar components you can afford to have 2 iPods
Seriously, though, my plugin uses Lua and so do a couple others.  I compile Lua into my component but I'm not sure about the other ones.  I wonder if PP would consider adding the latest version of lua  to the mainline release so that all of the components (and the core code if he's interested) could use the same, standard, lua scripting code and interface.  And/or we should all try to use the latest version compiled into a shared DLL since it appears the dlls have to be in the foobar folder vs. the components folder (maybe there is a way around that?).  I would have to upgrade my component to lua 5.0 but that shouldn't be a huge problem.  I could even build the dll unless you can already get the 5.0 distro in a windows DLL.
Looking forward to testing the write to iPod stuff.
Reply #52
foo_pod version 0.2 is now available.
This is the first version that supports writing songs to an iPod.  Write support is still a little rough in the user interface department, but I have yet to lose data or corrupt my iPod with this version, so I believe it is ready for general testing.
Just to make sure, there is a Debug menu under the foo_pod Component menu.  If you are worried that foo_pod might mess up your iPod, select the Backup menu item before using foo_pod for the first time.  If something does happen, you can select the Restore item to recover the database file saved by Backup.
From the readme:
foo_pod is a interface between an Apple iPod and Foobar2000 version 0.8.  As of Version 0.2, foo_pod allows reading and limited writing to an iPod.
The write support currently is append only - meaning that it will copy files to the iPod, but doesn't yet support removing files.  It also doesn't detect duplicate files yet, although one way to get around this is to read the iPod's database into Foobar using the "Load iPod Songs To..." menu item, add the new songs, select Playlist/Remove Duplicates, then transfer the playlist to the iPod using "Send Current Playlist To iPod".  foo_pod does not transfer playlist items that are from the iPod, so this should work.
In this version, there is no progress dialog or way to cancel a transfer.  Information about the transfer is written out to the Foobar2000 console upon completion.  The next version will have a progess dialog as well as a way to abort the transfer.
Reply #53
Great work, it really looks like this is moving forward.  I got the following error message when loading the iPod playlist:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 77C43108h
Access violation, operation: read, address: 0289FE8Eh
Call path:
WinMain=>app_mainloop=>menu command: "Components/foo_pod/foo_pod:Load iPod Songs To foo_pod Playlist"
Code bytes (77C43108h):
77C430C8h:  24 95 F0 31 C4 77 8B FF F7 D9 FF 24 8D A0 31 C4
77C430D8h:  77 8D 49 00 8B C7 BA 03 00 00 00 83 F9 04 72 0C
77C430E8h:  83 E0 03 2B C8 FF 24 85 F8 30 C4 77 FF 24 8D F0
77C430F8h:  31 C4 77 90 08 31 C4 77 28 31 C4 77 50 31 C4 77
77C43108h:  8A 46 03 23 D1 88 47 03 4E C1 E9 02 4F 83 F9 08
77C43118h:  72 B6 FD F3 A5 FC FF 24 95 F0 31 C4 77 8D 49 00
77C43128h:  8A 46 03 23 D1 88 47 03 8A 46 02 C1 E9 02 88 47
77C43138h:  02 83 EE 02 83 EF 02 83 F9 08 72 8C FD F3 A5 FC
Stack (0012EC98h):
0012EC78h:  00B2F8C8 77FA88F0 77F521E0 0000005A
0012EC88h:  00B2D238 C0000005 00B2D214 00B2D224
0012EC98h:  0221FC74 000001B6 0268FF90 013482D5
0012ECA8h:  026908E4 0221FE2A 00680065 00000214
0012ECB8h:  0268FF90 0221F8DC 00000021 00000004
0012ECC8h:  00000000 00000002 00000000 01349121
0012ECD8h:  026908D8 00000008 00000000 01C44C84
0012ECE8h:  021ABB76 00000398 0268FCD8 00000003
0012ECF8h:  0268FF90 0268FCE8 0268FF90 0012ED5C
0012ED08h:  01356DD7 FFFFFFFF 01348847 0268FD18
0012ED18h:  00000060 021ABB76 00000000 01C27AC0
0012ED28h:  0268FCB0 00000001 00000000 00073D0A
0012ED38h:  01346222 00073D66 0012EE10 01F90020
0012ED48h:  0012EE0C 0021BAF6 00000004 021ABB76
0012ED58h:  0012EE10 0012F03C 01356CE4 FFFFFFFF
0012ED68h:  01345C67 021ABB16 01F90020 77C5ACE0
0012ED78h:  002BD750 0134BB06 01F90020 77D46AE9
0012ED88h:  01359BE0 0012F920 00010011 0134265E
0012ED98h:  0012EE3C 77D46AE9 01359BE0 00000000
0012EDA8h:  71997568 DCBAABCD 00000000 0012EE04
Registers:
EAX: 00000001, EBX: 00680065, ECX: 00680064, EDX: 00000003
ESI: 0289FE8B, EDI: 02D10945, EBP: 0012ECA0, ESP: 0012EC98
Crash location: "msvcrt", loaded at 77C10000h - 77C63000h
Symbol: "memcpy" (+000001F8h)
Loaded modules:
foobar2000                       loaded at 00400000h - 00451000h
ntdll                            loaded at 77F50000h - 77FF7000h
kernel32                         loaded at 77E60000h - 77F46000h
USER32                           loaded at 77D40000h - 77DCC000h
GDI32                            loaded at 77C70000h - 77CB0000h
ADVAPI32                         loaded at 77DD0000h - 77E5D000h
RPCRT4                           loaded at 78000000h - 78086000h
ole32                            loaded at 771B0000h - 772D1000h
COMCTL32                         loaded at 71950000h - 71A34000h
msvcrt                           loaded at 77C10000h - 77C63000h
SHLWAPI                          loaded at 70A70000h - 70AD5000h
utf8api                          loaded at 10000000h - 1000D000h
comdlg32                         loaded at 763B0000h - 763F5000h
SHELL32                          loaded at 773D0000h - 77BC2000h
foo_abx                          loaded at 008D0000h - 008DA000h
foo_ac3                          loaded at 008E0000h - 008F0000h
foo_albumlist                    loaded at 008F0000h - 008FA000h
foo_ape                          loaded at 00900000h - 0091F000h
foo_apl                          loaded at 00920000h - 0092A000h
foo_bitcompare                   loaded at 00930000h - 00938000h
foo_burninate                    loaded at 00940000h - 0094B000h
VERSION                          loaded at 77C00000h - 77C07000h
foo_cdda                         loaded at 00950000h - 0095E000h
foo_clienc                       loaded at 00960000h - 0096B000h
foo_console                      loaded at 00970000h - 00978000h
foo_convolve                     loaded at 00980000h - 009AB000h
foo_dbsearch                     loaded at 009B0000h - 009C6000h
foo_diskwriter                   loaded at 009D0000h - 009E2000h
WINMM                            loaded at 76B40000h - 76B6C000h
foo_dsp_crossfade                loaded at 00A70000h - 00A77000h
foo_dsp_crossfeed                loaded at 00A80000h - 00A86000h
foo_dsp_extra                    loaded at 00A90000h - 00AA5000h
foo_dsp_nogaps                   loaded at 00AB0000h - 00AB7000h
foo_dsp_pause                    loaded at 00AC0000h - 00AC7000h
foo_dsp_skip_silence             loaded at 00AD0000h - 00AD7000h
foo_dsp_soundtouch               loaded at 00AE0000h - 00AEB000h
MSVCP60                          loaded at 55900000h - 55961000h
foo_dynamics                     loaded at 00AF0000h - 00AF7000h
foo_faac                         loaded at 00B00000h - 00B33000h
foo_festalon                     loaded at 00B40000h - 00C7F000h
foo_flac                         loaded at 00C80000h - 00C96000h
foo_flaccer                      loaded at 00CA0000h - 00CB6000h
foo_freedb                       loaded at 00CC0000h - 00CEE000h
WS2_32                           loaded at 71AB0000h - 71AC4000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_history                      loaded at 00CF0000h - 00CFE000h
foo_id3v2                        loaded at 00D00000h - 00D26000h
foo_input_std                    loaded at 00D30000h - 00DC9000h
MSACM32                          loaded at 77BE0000h - 77BF4000h
foo_lame                         loaded at 00DD0000h - 00DD9000h
foo_lpac                         loaded at 00DE0000h - 00DE7000h
lpac_codec_api                   loaded at 00DF0000h - 00DFA000h
lpaccodec                        loaded at 00E00000h - 00E29000h
foo_masstag                      loaded at 01050000h - 01060000h
foo_matroska                     loaded at 01060000h - 0109F000h
foo_mod                          loaded at 010A0000h - 010A9000h
BASS                             loaded at 010B0000h - 0110A000h
foo_monkey                       loaded at 01110000h - 0112E000h
foo_mpcenc                       loaded at 01130000h - 01138000h
foo_mpeg4u                       loaded at 01140000h - 01169000h
foo_nero                         loaded at 01170000h - 01180000h
MFC42                            loaded at 73DD0000h - 73EC2000h
foo_nez                          loaded at 01180000h - 011AC000h
foo_null                         loaded at 011B0000h - 011B7000h
foo_ofr                          loaded at 011C0000h - 011EE000h
foo_oggpreview                   loaded at 01200000h - 012FD000h
foo_output_std                   loaded at 01300000h - 01309000h
foo_out_dsound_ex                loaded at 01310000h - 01319000h
DSOUND                           loaded at 51080000h - 510D6000h
foo_out_ks                       loaded at 01330000h - 0133B000h
SETUPAPI                         loaded at 76670000h - 76757000h
foo_pod                          loaded at 01340000h - 0135D000h
MSVCIRT                          loaded at 01360000h - 01370000h
foo_psf                          loaded at 01370000h - 0141B000h
foo_read_http                    loaded at 01420000h - 01429000h
foo_rgscan                       loaded at 01430000h - 0143B000h
foo_scheduler                    loaded at 01440000h - 0144C000h
foo_search_ex                    loaded at 01450000h - 01458000h
foo_shn                          loaded at 01460000h - 0146E000h
foo_shuffle                      loaded at 01570000h - 0157E000h
foo_sid                          loaded at 01580000h - 015C7000h
foo_spc                          loaded at 015D0000h - 015DF000h
foo_speex                        loaded at 015E0000h - 015F8000h
foo_stfu                         loaded at 01600000h - 01607000h
foo_tfmx                         loaded at 01610000h - 01619000h
foo_toolame                      loaded at 01620000h - 01633000h
foo_tunes                        loaded at 01640000h - 016B4000h
uxtheme                          loaded at 5AD70000h - 5ADA4000h
MSCTF                            loaded at 74720000h - 74764000h
foo_ui_std                       loaded at 01770000h - 01787000h
foo_unpack                       loaded at 01790000h - 017C1000h
OLEAUT32                         loaded at 77120000h - 771AB000h
foo_vis_manager                  loaded at 017D0000h - 017D8000h
foo_vis_simple_spectrum          loaded at 017E0000h - 017EA000h
foo_vis_vu_meter                 loaded at 017F0000h - 017F8000h
foo_vorbisenc                    loaded at 01800000h - 018FA000h
foo_wavpack                      loaded at 01900000h - 0190B000h
foo_wma                          loaded at 01910000h - 01929000h
WMVCore                          loaded at 08530000h - 0872D000h
WMASF                            loaded at 07260000h - 07299000h
foo_xa                           loaded at 01930000h - 01941000h
CLBCATQ                          loaded at 76FD0000h - 77048000h
COMRes                           loaded at 77050000h - 77115000h
appHelp                          loaded at 75F40000h - 75F5F000h
cscui                            loaded at 76620000h - 7666E000h
CSCDLL                           loaded at 76600000h - 7661B000h
mslbui                           loaded at 605D0000h - 605D8000h
imagehlp                         loaded at 76C90000h - 76CB2000h
DBGHELP                          loaded at 6D510000h - 6D58D000h
Stack dump analysis:
Address: 013482D5h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01349121h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01356DD7h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01348847h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01346222h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01356CE4h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01345C67h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 0134BB06h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 77D46AE9h, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "SetCursor" (+00000000h)
Address: 01359BE0h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 0134265Eh, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 71997568h, location: "COMCTL32", loaded at 71950000h - 71A34000h
Symbol: "Ordinal384" (+00022876h)
Address: 77D43B1Fh, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D43B4Fh, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D43B33h, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D44A0Fh, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "MBToWCSEx" (+00000153h)
Address: 77D449FDh, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "MBToWCSEx" (+00000141h)
Address: 77D9C3A4h, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 0135742Ch, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 013573CCh, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 00440073h, location: "foobar2000", loaded at 00400000h - 00451000h
Address: 77C73187h, location: "GDI32", loaded at 77C70000h - 77CB0000h
Symbol: "ExtTextOutW" (+00000568h)
Address: 77C730C9h, location: "GDI32", loaded at 77C70000h - 77CB0000h
Symbol: "ExtTextOutW" (+000004AAh)
Address: 77CAC020h, location: "GDI32", loaded at 77C70000h - 77CB0000h
Address: 77C731C6h, location: "GDI32", loaded at 77C70000h - 77CB0000h
Symbol: "GetTextExtentPointW" (+00000000h)
Address: 77C731DDh, location: "GDI32", loaded at 77C70000h - 77CB0000h
Symbol: "GetTextExtentPointW" (+00000017h)
Address: 77D47510h, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "SendMessageTimeoutW" (+000004F0h)
Address: 77D47562h, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "DrawTextExW" (+00000040h)
Address: 77D473FEh, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "SendMessageTimeoutW" (+000003DEh)
Address: 77D48477h, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "GetDlgItem" (+000003BBh)
Address: 77FA88F0h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "wcstombs" (+00003409h)
Address: 77F51C78h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Address: 77F58A3Ah, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlAllocateHeap" (+00000E8Ch)
Address: 77C2AC14h, location: "msvcrt", loaded at 77C10000h - 77C63000h
Symbol: "free" (+000001A9h)
Address: 77C2AC19h, location: "msvcrt", loaded at 77C10000h - 77C63000h
Symbol: "free" (+000001AEh)
Address: 77C33EB0h, location: "msvcrt", loaded at 77C10000h - 77C63000h
Symbol: "except_handler3" (+00000000h)
Address: 77C12048h, location: "msvcrt", loaded at 77C10000h - 77C63000h
Symbol: "__non_rtti_object::`vftable'" (+00000C60h)
Address: 0134FDB3h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 0134D95Bh, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01345074h, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01356A6Ah, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01344B9Ah, location: "foo_pod", loaded at 01340000h - 0135D000h
Address: 01357214h, location: "foo_pod", loaded at 01340000h - 0135D000h
Version info:
foobar2000 v0.8
UNICODE
Reply #54
Worked first time.  You may want to note that it requires that you put your iPod in "drive" mode via iTunes the first time before using foo_pod.
-Reardon
Reply #55
Whoops.  Spoke to soon.  My iPod got blanked?
I did "Load iPod songs to ... Playlist".  I added a few songs.  Then I "Sent Current Playlist to iPod".  It seemed to work.  I asked WinXP to undock the iPod (iTunes has been turned off).  It undocked properly.
When I navigated on the iPod itself, however, it was blanked completely.
I had backed up the db and just restored it.  But the restore doesn't seem to work.  It appears to have a corrupted db or something, because after undocking it freezes up for about 30 seconds.  Then it shows a blank db.
Thoughts?
-Reardon
Reply #56
Thoughts?
-Reardon
Sorry?
Hopefully the backup worked, but for whatever reason, the restore didn't.  Try this:
In Windows Explorer (My Computer), go to your iPod's drive, then navigate to iPod_Control\iTunes.  There should be an iTunesDB and iTunesDB.foo_pod there - delete iTunesDB, and rename or copy iTunesDB.foo_pod to iTunesDB.  If you backed up before running foo_pod, then iTunesDB.foo_pod should be the one created by iTunes or whatever you used.
Reply #57
Hmm.  Its actually pretty bad.  I tried just recovering the db (as you described) but that failed.  The hard drive started clicking like it had a bad block.
So I reformatted and started over.  iTunes worked fine.  Sync'ed 12GB of music.
Tried foo_pod.  Added one track.  Updated the ipod.  When I did this WinXP started reporting USB level (same error on 1394 interface) bad block errors. (these always take the form of timeout errors followed by bad block reports).
Given this repro'd twice, and iTunes had no issues, I think there is some bad interaction between foo_pod and the device itself.  Perhaps there is some of proprietary bus sync command that gets sent via the IPodService?
EDIT: I misread the events in the eventlog.  They bad block occured earlier.  Now I can't figure out what happened.  The updates are not working, but it continues to read fine.  Each time I start iTunes it seems to undo the foo_pod changes.
I am still concerned about the bad block errors.  This may in fact just be a bad disk.
-Reardon
Reply #58
I'm sorry to hear about your iPod's drive, but I am 100% sure it wasn't (directly) caused by foo_pod.  All foo_pod is doing is copying song files to the iPod and generating the iTunesDB file, just like iTunes does.  If the iPod is still under warranty, I'd recommend sending it back ASAP.
There might be some interaction between iTunes and foo_pod that is causing the database problem, though.  Personally, I can't stand iTunes and other than trying it out a few times, I have used EphPod and now foo_pod, exclusively...I eat my own dogfood!  The problem is that the iTunesDB file format is not documented by Apple, so every 3rd party program writes the file a little differently than iTunes.
I will try syncing with iTunes tonight and see if I can reproduce the database problem.  Although if I understand iTunes correctly, it forces a sync from the tunes library to the iPod, so any songs not in the iTunes library will be deleted from the iPod.  So if you add songs from foo_pod, then sync with iTunes, iTunes will see the foo_pod songs as out of sync files and delete them.
Someone correct me if I'm not understanding iTunes correctly, but I think this is probably the problem you are experiencing.
Reply #59
Yes, anything off in the f## directories that isn't what iTunes thinks is supposed to be there, assuming you're doing automatic syncing, gets zapped during the sync.
And there's nothing funky about how any program accesses the iPod. When the iPod is in drive mode (which it has to be to be able to talk to it at all), it's basically just an external drive. There's nothing special you do to talk to it. You create files on a drive letter in a certain directory. That's it. The "Do No Disconnect" shows up whenever the iPod is "mounted" as a drive, and the "Ok to Disconnect" shows up whenever it's connected to a computer but not currently "mounted". Simple as that. There's nothing special to it, and no way that iTunes can do anything special to it other than simple mounting and unmounting and writing files.
Thought for the future Aero: Add mount and unmount capabilities to foo_pod so that it mounts when you need it to do so and unmounts when you don't need it to be mounted. Just an idea. I'm not sure exactly how to do it under windows, but it'd be cool though. Would also eliminate the need for iTunes or Apple software to be installed to enable drive mode.
Reply #60
"isn't what iTunes thinks is supposed to be there" == an MHIT entry in the iPod's iTuneDB file for which iTunes doesn't have a matching song for in its library?
I looked into adding unmount functionality, and it doesn't look like it be too difficult.  I want it simply because it would be cool to have a global hotkey (or multimedia key) that unmounted the iPod - I am always having to turn on my monitor just to unmount the iPod, or risk foobar'ing it up by just undocking.
I'm not sure about the drive mode, though.  My iPod has always Just Worked in drive mode, without having to make any changes in iTunes.  Plus, can't you force drive mode by holding down the Previous and Next keys?
Reply #61
Assuming nothing has changed, then yes. However, you gotta remember that during an autosync, it's rebuilding the iTunesDB itself. So anything you added to the iPod using any other program will go away because the newly built iTunesDB won't have your songs in it, unless they're in iTunes library as well.
Essentially, it reads the useful data off the iPod (last played time, stars, playcount, otgplaylist). Then it erases the Playcounts and OTGPlaylist files. Then reads in the existing iTunesDB, and redoes all the MHIT records to correspond with the songs it thinks are supposed to be on the thing. That is, MHITs not in the iTunes library get removed, and MHITs that are in the library but not in the iTunesDB get added. Then it goes and checks every file in the f## dirs and deletes any without a matching MHIT. Any MHITs that don't have a matching file on the iPod get that file copied to the right place. Finally, the playlists get erased from the iTunesDB and rebuilt entirely from iTunes list of playlists.
That's a conceptual thing though... it may do it in a different order or something, but that's the gist of it. An automatic iTunes Sync does everything it has to do to make the iPod's contents identical to the iTunes Library.
Edit: Ahh, I see what you're asking. You want to know if it'll delete something in there that the iPod doesn't know about with an MHIT entry. I'm not certain, but I think it will. It's easy to test, drop a file in the f01 directory without changing the iTunesDB, then do a sync. I think iTunes will kill it, but I'm not 100% certain on that.
Yeah, you can force drive mode, but as you can tell, the "drive mode" thing is really on the iPod firmware side of things. It goes into drive mode automatically when you connect it to a computer, regardless of what's on the computer. Unmounting it (which is the same as right clicking its drive letter and doing "Eject") will punch it back out of drive mode. Someone with iTunes or the iPod Manager software installed will get their iPod kicked back out of drive mode nearly automatically if they don't have "Enable Disk Mode" turned on. The reason you'd want a mount command is what if someone has the thing unmounted and decides to try to sync. It'd be nice to be able to mount the thing, if it's not already mounted, and sync, and then unmount again.
If I'm not mistaken, because the iPod is simply looking like an external drive, you should be able to not have any software installed (not iTunes, not the iPod Manager, nothing) and be able to hook it up and see it as a drive letter just fine. Then ejecting it will unmount it. All these software programs do is make it more seamless, in that it'll start iTunes automagically, iTunes will sync automagically, etc, etc.
Reply #62
More info on SoundCheck:
Okay, I did some experimenting. Near as I can tell, the soundcheck field in the iTunesDB (which is identical to the first number in the iTunNORM comment that we've seen) is essentially telling the iPod how much to reduce the volume of the song when Sound Check is enabled. I've not seen a case where iTunes puts in a number that noticably increases the volume, and I have not tried to do so myself as of yet.
To determine the value of this field, I picked a bunch of songs in iTunes, and did a "Get Info" on them to get what that screen has as the "Volume" field. This is a number expressed in dB there. I do not exactly know what it means, but still, there's a pretty blatent relationship between this number and both the actual volume of the song and the number that iTunes puts into the soundcheck field.
The lower this number is, the louder the song is. So a "volume" of -8.6dB is an extremely loud song. Loudest I found in a quick search of my library. Songs with larger numbers are quieter. +1.5dB was the largest I found.
To show the relationship, I found the info in the soundcheck field for each song that I looked up (9 of them). Here's the results:
dB number followed by soundcheck field
+1.5 000002ca
+1.2 000002f9
+0.3 0000039d
-1.1 000002fb
-2.1 0000050b
-4.3 00000a72
-6.0 00000f65
-7.6 000016a2
-8.6 00001c75
As you can clearly see, as the volume numbers get smaller, the soundcheck field increases. Here's the same data with the hex converted to decimal:
1.5   714
1.2   761
0.3   925
-1.1   763
-2.1   1291
-4.3   2674
-6   3941
-7.6   5794
-8.6   7285
I graphed the data in excel, and while it's not enough to be sure, it looks like some kind of logarithmic expansion. I figure the weirdness around the low end is due to iTunes being funky.
Look, I'm out of my depth here. I don't know enough about what I'm doing to know what any of this means. All I really know is that if you increase the number in the sound check field, the volume on the iPod gets smaller when sound check is on. But as to correlating this to the value that MP3Gain gives you for any given file, I have no idea on what to do next. Somebody else who knows this stuff should probably take a whack at it. I'm going on vacation for 10 days now. See ya.
Reply #63
As someone who spends way too much time trying to fit trendlines to bad lab data, I thought I'd take a look.
Heres your data with an exponential trendline:
Not a great fit.
However if we graph the positive and negative gains independantly and assume a linear relationship (which would be logical given the precision available), its a nearly perfect fit, but we have too few data points to draw any conclusions.  Anyone want to try their hand at getting more?
Reply #64
Version 0.3.1 is now available.
This version adds some good stuff, such as a smarter "Send Playlist" that detects duplicate files that are already on the iPod, an Eject iPod menu item, a "Delete All Songs" features, and progress dialogs so you can monitor and cancel lengthy operations.
This release should also improve reliability when sending songs to the iPod, and fixes the crash reported by rufu (related to smart playlists).
Upcoming versions will have a real iTunes-like sync functionality, Lua scripting, and speed improvements, as well as support for building iPod playlists.  I'm also open to feature suggestions and bug reports.  The Eject iPod should work with all iPod versions, but it has only been tested with 3rd generation iPods, so I would appreciate feedback from 1st and 2nd generation owners.
Edit - Updated to 0.3.1 after the original posting of 0.3.
Notes from the Readme:
Version 0.3.1 - Mar 18, 2004
* Minor change from 0.3 - don't transfer file formats that the iPod can't play.
  These are only MP3, AAC (.m4a and .m4p), and WAV.  AIFF isn't currently supported
  by foo_pod, due to a problem with Foobar's detection of AIFF.
Version 0.3 - Mar 18, 2004
* Improved reliability when writing to the iPod, hopefully reducing the
  number of things that could go wrong resulting in a loss of iPod data.
* "Send Playlist To iPod" now detects duplicate files, so sending the
  same file won't result in two copies on the iPod.
* Added an "Eject iPod", which allows you to safely remove the iPod from
  the computer.
* Added a "Delete All iPod Music" feature, which deletes all music on the
  iPod, as well as the iTunesDB file.
* Added progress dialogs, with cancel support, to "Send Playlist" and "Delete All".
* Fixed a foo_pod crash related to smart playlists (thanks for your help, rufu).
Reply #65
Very good.
Reply #66
working well for me; thanks HEAPS!
i don't suppose any of you have any good ideas on a skin for my ipod? getting scratched
Reply #67
Thanks for the report!  It was a little quiet before you and Mike G posted, so I was wondering if no one was using foo_pod, or no one was having any problems!
I have only tried one iPod skin, but I really like Speck's iPod Skin.  The fit isn't perfect like the exo2 (or so I hear), but is cheap (3 pack of skins for $30 at Fry's) and the best feature is that the bottom is hinged so you can dock the iPod without removing the skin.  I added 3rd party belt clip and a piece of clear plastic on the screen, so now the case is nearly perfect.  I have also read accounts of people of modifying the exo2 case so that the bottom part hinges like the Speck case.
Reply #68
sound good...but the website wants to charge 25.95 for shipping to australia - ouch....
ill have to look into getting one here or something.
anyway i suppose this is getting a bit too offtopic so ill go play with foo_pod some more
Reply #69
Cool pugin, I've been using it for a few days now with no problems.
I hope someone works out how to convert replaygain info into soundcheck info.
Reply #70
Not a great fit.
Sorry it took so long to reply. Been on vacation.
I can get as many data points as you want, but it's a bit of a laborious process for each one. I'm currently moving though and won't have internet for a while, so give me a few days on it. Think weekend or so.
Anyway, looking at your graph, I'd say that the curve there is a very good fit, given the fact that iTunes is likely *rounding* the dB number that it displays on the Get Info window. I mean, I would round it if I was programming the thing.  Given this, that means that the data points can easily slide left/right on the graph a little bit.. Given that there's so much more precision in the SoundCheck field itself (ranging all the way from 0x2ca to 0x1c75, so far), then this seems somewhat more likely to me.
For starters, let's assume that the numbers are rounded to the nearest 0.1 dB. That means a 8.6 number is within 8.55 to 8.64. Now it seems like the curve you drew hits every single one of the data points, except for the anomoly at -1.1...
Looking closer at it, you might be right about the positive vs. negative info... Looking at the negatives only, it looks like a pretty good, and slightly different, curve if you assume it hits 0,0.
Edit: Just a thought, but is there any way to actually measure the sound volume using the iPod itself? Perhaps using the line output on the dock? Really, we don't have to stick to iTunes' curves and sound profiles and what have you. What we really need is to adjust the volume according to the ReplayGain data, and to do that, we really need to know the volume change that occurs due to the value in the SoundCheck field. What iTunes says the volume of the song is is irrelevant, what matters is how much the iPod changes the volume based on the data in the soundcheck field. Knowing that an iTunes volume change of -8.6dB = 1c75 is fine and dandy, if ReplayGain tels us that we need to throttle the volume down by -8.6dB, but we're then assuming that iTunes knows the iPod's sound characteristics. It'd just be nice to actually measure the blamed thing, I mean.
Reply #71
Been using 3.1 for several days, haven't had any further corruption problems.  Thanks for moving this thing along.
A few suggestions:
1) Rather than requiring usage of iTunes to switch the iPod to drive mode, do this yourself.  Of course I have no idea how this is done.
2) Would love to see playlist building/sync, glad to know its on your radar.
3) Perhaps the iPod playlist&db should be visible only when its connected, ala iTunes?  I haven't thought thru this long...maybe having it always viewable is a nice feature.
4) Deletion... I presume you are doing this as part of "full sync"?
5) Long term: you've done a nice job here, this could perhaps become the hub of generic device sync with profiles for iPod, Creative players, etc.
6) Sort of new to it, but curious: what will Lua support enable?
-Reardon
Reply #72
A few suggestions:
Ditto!  Actually, I have never had to use iTunes to put my iPod into drive mode, so I guess I don't really understand the problem.  If anyone knows of source code to do this or more information about how iTunes works, I would appreicate a pointer to it.
Yeah, this should be easy (thanks to Otto42!).  I haven't used playlists much on my iPod, so this wasn't a priority until after I got read, write, and sync working.  Basically, I expect that the Foobar created iPod playlists will take the name of the Foobar playlist, and the order of songs.  So you should be able to create as many playlists as you want, and foo_pod will be able to determine if the files already exist on the iPod and transfer them, otherwise just create and populate the playlist on the iPod.
It will probably be an option for the foo_pod specific playlist to open/close automatically when the iPod is present.
I actually already have full sync working, and it is sweet.  Of course, this is coming from someone that has almost no experience with iTunes, so it probably won't be a big deal to everyone else.  I'm just doing some final testing now to make sure it is reliable (no problems so far).
In 0.3, I added the "Delete All iPod Music" feature, so it is already possible to delete files, albeit in a rather heavy handed manner.  Playlist Sync will make file transfer/deleting practically transparent to the Foobar user.
Start up a "Buy Aero a xxx player" collection, and I'll consider it!
I implemented this for the iPod since:
  • I have one.
  • Transferring music to the iPod isn't very easy.
  • There is a good library (iPodDB) available that makes it easy to interface Foobar with the player.
  • The existing software is either commercial (XPlay/Anapod), not very reliable (EphPod), or I just don't like (iTunes).
So to add support for additional players, I would want the majority of those requirements met.
Everything!  I intend that all functions of foo_pod will be customizable via Lua scripting.  A couple of examples off the top of my head:
1. You could write a script that detects when the iPod is docked, start a sync of a playlist or directory, then eject the iPod afterwards.
2. As discussed in earlier posts, you will be able to dynamically modify the metadata as it is being put into the iTunesDB file.  So if you want the album field to show up as the artist on the iPod, you could easily do that.
3. It will make it possible to easily do smart playlists.  For example, you could automatically create playlists based on genre, or any other attribute of the songs.
Lua is really just going to make it easy for power users to do whatever they want on the iPod, just by writing simple scripts.  It will take a little bit of work to add to foo_pod, so Lua support is probably my lowest priority right now, although when it is implemented, it will really make foo_pod a unique iPod utility.
Thanks for your comments!
Reply #73
I'm not sure if this is what you mean, but to put the ipod into disk mode without itunes you can hold down menu + play/pause to reboot the ipod and then old down the skip forward and skip backwards keys as the ipod is reloading.
Reply #74
I'm not sure, but Otto42 had some insight in an earlier post:
So I'm guessing that problems people have with the iPod not auto-mounting are due to using iTunes (without the disk mode option enabled) or the iPod Service switching the iPod out of disk mode.  Since I don't use either iTunes or the iPod Service, I never experience this problem, although if I understand Otto42 correctly, the solution is to just set Enable Disk Mode in iTunes.  Does anyone know of a reason why you would not want Enable Disk Mode enabled?
