Topic: OptimFROG Lossless/DualStream SDK available! (Read 2305 times) previous topic - next topic
Hello,
Thank you for your continued interest and appreciation for OptimFROG!
The OptimFROG SDK is available now for you to download.
This OptimFROG interface is an experimental version for the moment and may change without notice in the future releases, until it will become a stable version.
This interface is simple to use and provides full functionality of OptimFROG for both Lossless and DualStream files (decode only for the moment) in the C++ and C languages with BCC, MinGW and VC compilers and the possibility to use it with any Windows compiler.
File information retrieval, ID3v1.0, ID3v1.1, and APEv2.0 tags reading, 64 bit file support, fast seek, custom reading stream functions, bitstream error resilience are only a few relevant features of this interface and OptimFROG.
With OptimFROG you obtain asymptotically the best lossless audio compression ratios.
The OptimFROG interface package contains the following files:
foo_ofr.cpp - source code file for the foobar2000 decoder plug-in
foo_ofr.dll - built foobar2000 decoder plug-in binary
foo_ofr.dsp - Visual C++ 6.0 project file for the foobar2000 decoder plug-in
foo_ofr.dsw - Visual C++ 6.0 workspace file for the foobar2000 decoder plug-in
foobar2000_SDK - the directory where you must unzip the SDK.zip (foobar2000 SDK)
MakeBCC.bat - batch file to compile the sample command line decoders with BCC
MakeMinGW.bat - batch file to compile the sample command line decoders with MinGW
MakeVC.bat - batch file to compile the sample command line decoders with VC
OFROGDec.cpp - source code file for the sample command line decoder
OFROGDec.dsp - Visual C++ 6.0 project file for the sample command line decoder
OFROGDec.dsw - Visual C++ 6.0 workspace file for the sample command line decoder
OFROGDec.exe - built sample command line decoder
OFROGDecSim.cpp - source code file for the simple sample command line decoder
OFROGDecSim.dsp - Visual C++ 6.0 project file for the simple sample command line decoder
OFROGDecSim.dsw - Visual C++ 6.0 workspace file for the simple sample command line decoder
OFROGDecSim.exe - built simple sample command line decoder
OptimFROG.dll - the OptimFROG interface dynamic library
OptimFROG.h - the OptimFROG interface C++ and C header file
OptimFROG.html - this documentation file
OptimFROG.lib - the OptimFROG interface import library for VC and MinGW (COFF format)
OptimFROGB.lib - the OptimFROG interface import library for BCC (OMF format)
Please report any problems or bugs, to help improve the OptimFROG interface and the OptimFROG product itself. You may send a report of the problem or bug at FlorinGhido@yahoo.com, attaching example illustrating files as needed. If the total size of the files is greater than 200 kB, please do not send them attached, but we will arrange in the next e-mails how can I get them.
Download it directly at:
http://LosslessAudioCompression.com/Downlo...G_SDK_Win32.php
or at the Downloads page.
You may see all the release details and the online documentation at:
Thanks again,
Florin Ghido
Topic removed from validated news. If you want it back there, please write a shorter version, or edit parts of it out and put in a separate post (reply). We don't want all this on the front page.
Sorry , I missed the fact that the post will take too much space on the front page...
I made a much shorter version and put it on the Validated News page in a separate post.
Please read TOS #14.
