Topic: Winamp-VIS-plugs in foobar (Read 170846 times) previous topic - next topic
Reply #300
Any idea what has happened to potatoriffic?  Its appears to have gone....Is there a mirror I can use to download vis_bacon?
Reply #301
I've got the site on a free and somewhat unreliable host, so stuff like that happens from time to time.  It seems to be working again at the moment.
Reply #302
When create foo_uie_bacon ? :-/
re, Deer
WBR,  Vitaliy I. Bogdanets
Foobar2000 - The way it's meant to be played
Reply #303
if you read back a page you will see that there will not be a uie version as some (read most) winamp vis's create the window themselves
Reply #304
"(AVS) Works okay, but it's only available with Winamp." (from potatoriffic site)
I will remove winamp from my system, but I will keep AVS with foo_beacon.
It's possible?
Reply #305
Just FYI, I wrote a Winamp visualization emulator about 5 years ago.. An old version can still be downloaded at:
chronware.virtualave.net/shizsetup.exe
This captures the audio playing from _any_ Media player.. or a microsophone, or line-in, etc... so nothing else required.  I'm in the process of updating this program now..(lame trial period will be deactivated, among lots of new stuff)
Reply #306
It's possible?
[a href="index.php?act=findpost&pid=256494"][{POST_SNAPBACK}][/a]
Sorry I somehow missed your post earlier.  To keep AVS on your system after uninstalling Winamp, it appears you have to copy the AVS DLL and all of the stuff associated with it to a different folder before removing Winamp, since Winamp's uninstall program will delete AVS if you let it.  I don't have a list of all of the associated files and stuff right now because I just ran the uninstaller.
Reply #307
foo_vis_bacon has experienced some movage and now resides here.  I've had 52 MB of space on a university server for the last year and a half and didn't know about it until a week ago.  This should be more reliable than hosting on f2g...
Reply #308
Wow, nice plugin as milkdrop was just the thing i wanted in visualisation world. but i have 2 questions:
1. Is it possible to get rid of the caption of the visualisation windows? That would be very cool.
2. Is it possible to get the visualisation window to be opened in foobar? Like in the sidebar for example?
Inter Deum et Diabolum semper Musica est", Tanzwut
Reply #309
With most plugins, the second one is a no, as has been discussed earlier in this thread.  The first one might be a little more doable, but I can't say because it isn't something I've tried yet.
Reply #310
does this pluggin actually work.  if yes, how do I use it?
Reply #311
It works varyingly well depending on which Winamp plugin you want to use.  www.msu.edu/~singergr/bacon.html has about all the setup info you'd need, complete with bandwidth-munching PNG screenshots (mmm... bandwidth...).
Ack, I just remembered.  The, "No delay," mode for flush handling is broken in foo_vis_bacon minus 0.19 and minus 0.2.  I've actually fixed the bug (someone sent me an e-mail saying foo_vis_bacon crashed when they closed foobar and that's how I noticed the bug), but I never did get a formal release set up at the time (their crash log didn't have symbol info and fixing the no delay bug didn't solve their problem) and, well, I've been distracting myself for the past few days poking around with stuff in Linux and hence haven't done it since.  If I don't have a fixed build up by tomorrow, kick me.
EDIT:  foo_vis_bacon minus0.18 uploaded with close issues fixed.  That should be it for issues other than those documented in the plugin list.
Reply #312
Nice plugin, works great with milkdrop.  Would have been good to have as a uie, but its still cool.
Reply #313
Thanks for this plug in.
Please consider updating the first post in this thread for people's first visit.
Reply #314
hehe this pwnz !!! thnx
any way to "attach" it ...like a panel ?
Reply #315
This has been discussed before.  It probably isn't going to be implemented because the only plugins with which it would be known to work cleanly would be Milkdrop and AVS.  Everything else would have problems doing that, especially if fullscreen stuff gets involved.
Reply #316
how about a separate one then...with only milk and avs for panels
foo_milkavs_panels.dll
would (if possible) pwnz even more !!
u guys r0x
Reply #318
Winamp 5.12 updated milkdrop version to 1.04c; still working, but can't be configured via foo_vis_bacon (crash foobar). Same issue with Nullsoft Tiny Fulscreen v.2.06.
Reply #319
Confirmed.  No idea why and I'm not sure if I remember how all of my code works now.  :|
EDIT:  Meh, found the bug and can give it a really quick workaround.  Trying to figure out another bug I don't remember seeing at the beginning of the year where Milkdrop gives the focus back to the desktop if you put it in fullscreen mode.
Reply #320
Lazy workaround for crashes in new Milkdrop version posted.  Other bug that I just talked about only appears to happen in the debugger, so I'm ignoring it.
Reply #321
I'm using foobar 0.8.3 with baconwrap minus0.189 and MilkDrop 1.04 (downloaded from the Milkdrop site - I don't have Winamp installed).
I'm guessing MilkDrop is one of the plugins that "Always on top" doesn't work for.  Or is there a workaround?
Reply #322
It does not appear to work with the old 1.04 version from the Milkdrop site if the, "Integrate with Winamp," option is disabled.  Unfortunately, to work around a crash with the new 1.04c Milkdrop version, I made this option unavailable with foo_vis_bacon minus0.179.  If you're sure you're never going to use Milkdrop 1.04c, just use foo_vis_bacon minus0.18 (now available on the foo_vis_bacon site again).
I guess I'll have to find a real solution to that crash...
Reply #323
[a href="index.php?act=findpost&pid=353614"][{POST_SNAPBACK}][/a]
It worked.  Thanks.
Reply #324
AWESOME plugin
is there a tip to run under foobar2000 ACIDPUNKD?
