Topic: foo_dsp_continuator (Read 277410 times) previous topic - next topic
foo_dsp_continuator
Reply #201
g-lite, can you make "preset interface " work?
if not , someone can?
Music is my first love.
foo_dsp_continuator
Reply #202
Hey all,
I'm getting a crash when using the continuator. Towards the end of each song right when it's supposed to overlap with the  next track I get an Application Error:
"foobar2000.exe - Application Error
The exception unknown software exception (ox000000d) occurred in the application at location 0x00b8c132.
Click on OK to terminate the program"
then when I click ok, foobar shuts down.
Any ideas why this might be happening? The only other DSP I have active is equalizer if that helps at all.
Any help would be greatly appreciated
foo_dsp_continuator
Reply #203
I had something really happen once with continuator. It crossfaded into a song, but then it crossfaded into... itself or something. So I ended up hearing the song superimposed over a delayed version of itself. Stoping playback fixed it. It's like it kept filling the buffer, playing off the buffer, and forgot to change state.
foo_dsp_continuator
Reply #204
Happened to me too. I disabled the three options at the bottom, in preferences (Empty buffer up..., Disable track overlapping..., Adjust track length...) and problems seem to have dissapeared.
I am not really sure, I've just been testing for a half of day
foo_dsp_continuator
Reply #205
I has happened to me a couple of times too. Didn't realise continuator was the cause.
foo_dsp_continuator
Reply #206
This component is awesome, is there any way of being able to burn a playlist to a CD with the fade in/out included?
foo_dsp_continuator
Reply #207
Just "convert" it to WAV, activate Continuator in the converter-DSP-settings, and then burn the WAVs to CDR.
foo_dsp_continuator
Reply #208
Fantastic, thanks.
foo_dsp_continuator
Reply #209
only in 0.83
don't work in 0.9 because continuator isn't entirely ported.
foo_dsp_continuator
Reply #210
I think I have to report a bug. On 0.9.1 with continuator only active, many songs do get skipped the last 10-15 seconds instead of being crossfaded.
Can anybody tell me why?
P.S.: I want foo_crossfade back
foo_dsp_continuator
Reply #211
Uncheck:
empty buffer up ...
disable track...
adjust track lenght to...
foo_dsp_continuator
Reply #212
Uncheck:
empty buffer up ...
disable track...
already done that, unless I wouldn't have reported it.
might it be something related to having to load mp3s across a LAN?
foo_dsp_continuator
Reply #213
G-Lite, if u developing this plugin, our who develop it.
I suffer a problem, time by time, serveral time a week (while listening more over 1,000 songs), while crossfading to a new song - the song is double played in the same time with an offset.
I can't give any other clues, there is no link between the songs, the file propeties, and it seem to be randomize.
This is the properties window (note, the problem don't dissaper when i change some of the options):
foo_dsp_continuator
Reply #214
I haven't noticed this one yet.  There are a few issues with the new port, but none that bad.
foo_dsp_continuator
Reply #215
I dont know why this plugin doesnt work with my foobar 0.9.1.
I active this, use a normal setting, ie as ArielG's, and have no cross fader between tracks.
Any ideas how it works somelike DirectSound v2 in foobar 0.8.x?
Rule the Rules
foo_dsp_continuator
Reply #216
have you put it in the active DSPs in the DSP manager?
foo_dsp_continuator
Reply #217
Useless post caused by missunderstanding a sentence because of missreading a word lol.. slap me  [Fixed typos..]
foo_dsp_continuator
Reply #218
Hello
Could someone tell me if the continuator works (fades the two tracks) when for instance I use my hotkey button to jump to the next 'random' track and does it also works when foobar is set to the "random" mode and beginning the next random song?
Some monthes ago continuator was not able to do it (or maybe was it bad configured?)
That's why actually I'm using foobar v0.8.3 with the Kernel v2.5 output 'combined' with the continuator which allows me to do that trick...
foo_dsp_continuator
Reply #219
For me it only works when foobar changes track, no matter what playback order is set. But via hotkey it directly jumps to the new track.
foo_dsp_continuator
Reply #220
That's why I'm still using the old foobar version cause DirectSound v2.5 has not been ported to the 0.9.x
It there a way to get things work?
foo_dsp_continuator
Reply #221
Honestly I can't test it right now. But I have the impression, that it works for me on manual trackchange!
foo_dsp_continuator
Reply #222
Continuator crashes with files that are less than 1 second long. Foobar 0.9.3.1
No message, no anything, just disappears.
foo_dsp_continuator
Reply #223
only in 0.83
Unfortunatelly I can't code but I would really like to have the few bugs that are there to be sorted out. Maybe someone is willing to step up and fix them?!
In the earlier foobar version I used this version alot to burn crossfaded cds. When thats fixed again I will be very happy!
foo_dsp_continuator
Reply #224
only in 0.83
Same goes for me... I would also be *very* happy if this great dsp is ported properly... can't burn crossfaded tracks!
Tom.
Back off haters - strictly love we deal with.
