Topic: Foobar2k Settings (Read 5409 times) previous topic - next topic
Foobar2k Settings
Are these the right settings for foobar because all i need to do is convert to wav from mp3..
Foobar2k Settings
Wouldn't it be easier to encode to MP3 from foobar directly? The commandline encoder will do the trick. Also, I'd disable 'use replaygain' there and use mp3gain on the resulting files.
Foobar2k Settings
Seems to me that Novus wants to decode MP3 > WAV, not encode.
For decoding, those setting would be fine..
Foobar2k Settings
what about now..sorry guys, im new to this program and just trying to get the best results
Foobar2k Settings
Your settings will convert any file to a WAV file.
If you are trying to burn a CD, it is easier to use the foobar CD burner.
Also a general tip: holding the Alt key while pressing Prt Scr will capture only the current window, rather than the whole screen.
