Topic: Otachan's in_!mpg123 (Read 220572 times) previous topic - next topic
the gapless playback doesnt seem to work for me, is there an option i need to select to enable it?
*sigh*
maybe search the forums?
or activate sufficient "buffer ahead on track change" in out_ds?
And there's one more thing: do the files have the correct encoder delay and correct encoder padding info written in their LAME tags?
Only then will the files be decoded gaplessly. Files encoded with recent versions of LAME, for example, will do nicely.
i encode with 3.90.3 and the gapless decoding works fine in foobar. i dont get it.
And are you sure, that in_mpg123 is in use???
You have to remove/rename in_mp3 or remove the MP3 extension from in_MP3!
If both in_mpg123 and in_mp3 are in the plugins folder, Winamp will always use in_mp3!
You can test it out when choosing "File Info" in the PL.
EDIT: BTW, thanks to kjoonlee for updating the mpg123 information post again.
otachan ot66 is out!!!
a bug with IDv2.4 seems to have been fixed.
Reply #33
There seems to be a bug with either Winamp 5.03 or the latest in_mpg123.dll plugin. Every time i right-click and select "view file info" from within Winamp 5.03, i get a message "Winamp has encountered a problem and needs to close."
This happens with and without mp3infp 2.44 (latest) installed.
Anyone else experiencing this?
myspace.com/borgei - last.fm/user/borgei
Reply #35
Ver oc66 STILL has a BUG.
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 46 61 69 6c   ion Fail
0010: 75 72 65 20 20 77 69 6e   ure  win
0018: 61 6d 70 2e 65 78 65 20   amp.exe
0020: 35 2e 30 2e 30 2e 33 20   5.0.0.3
0028: 69 6e 20 6e 74 64 6c 6c   in ntdll
0030: 2e 64 6c 6c 20 35 2e 31   .dll 5.1
0038: 2e 32 36 30 30 2e 31 32   .2600.12
0040: 31 37 20 61 74 20 6f 66   17 at of
0048: 66 73 65 74 20 30 30 30   fset 000
0050: 31 39 65 63 64 0d 0a      19ecd..
It's My Life,
It's Now Or Never,
I Ain't Gonna Live Forever,
I Just Want To Live While I'm Alive.
Reply #36
you should try VC++ 7.1 version
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot66vc71.zip
Sorry for my English.
Reply #38
It seems doesn't work under win98 with winamp 5.02.
I made a fresh installation with EVERY plugin and option that come in winamp installer off, then deleted in_mp3.dll and replaced by in_mpg123.dll.
Worked perfect under winxp.
After that just copied the winamp directory to a win98 machine. It didn't recognize the plugin.
Made some test, I installed some plugins, all of them worked perfect under XP and 98, but under Win98 im_mpg123 was not recognized at all.
Reply #40
@jormartr:
Are you aware that in_mpg123 is available in different "flavours", compiled to support different instructions sets (bare X86, SSE, SSE2)?
Couldn't be the case that on the Win98 machine you have a processor that doesn't support SSE and/or SSE2 and you're using the worong version of in_mpg123?
Sergio
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
Reply #41
  Obviously that was the reason...
Reply #42
You can use something like WCPUID or CPU-Z to check which instructions sets your processor supports.
"ONLY THOSE WHO ATTEMPT THE IMPOSSIBLE WILL ACHIEVE THE ABSURD"
        - Oceania Association of Autonomous Astronauts
Reply #43
Whats the difference between "INT" And "Float" Bitrate options?
For example.. Should I be using 32bit int or 32bit float on my audigy?
Reply #45
32bit float = 24bit int
if you use KX Project or something similar, you can use both of them.
Reply #48
What is KX Project?
