Topic: EAC Setup (Read 2702 times) previous topic - next topic
EAC Setup
I apologise if this has been asked before, by I couldn't search for EAC threads as it has less than 4 characters.
Ive just downloaded EAC and Im trying to use it to record mp3s using LAME with the --alt-preset standard command line option.
When I go to Compression Options --> External Compression:
I add --alt-preset standard to the 'additional command line options' but I cant get it to use this option instead of the bit rate chosen in the 'Bitrate' pull-down menu. Is the VBR 192kbps the same as --alt-preset standard ?
Im sorry if this is a really stupid question but I would be really grateful for any help.
Gordon
EAC Setup
Try this:
- uninstall your current EAC
- open Regedit (RUN -> regedit.exe) and delete the key "HKEY_CURRENT_USERSoftwareAWSoftware"
- download the latest LAME stable version from http://mitiok.cjb.net/ and extract it into some folder
- download the current EAC and install it (www.exactaudiocopy.de)
It should ask where your lame.exe is, and automatically configure itself for MP3 extraction, using --alt-preset standard.
This is the hard way, but effective.
EAC Setup
Cheers for the help.  Ive got it to work now.
Gordon
