Topic: Vorbis quality – wrong direction? (Read 56809 times) previous topic - next topic
Reply #50
The Modest Tuning Beta2 won my own test.  Apparently it's superior to other Vorbis encoders on this kind of sample. (sharp attack, symbal)
Although aoTuV b1 is also thinkable as a good choice for its reasonable bitrate.
Reply #51
However, it was not so good because the average bitrate of MTb2 is too high (around 160-170kbps).
Perhaps next time you could compare it to 1.01 -q5 as well?  Results would be interesting, IMO.
Reply #52
It certainly is surprising that lossless coupling is doing so badly compared with uncoupled.  Theoretically, you'd expect they should be the same!
Reply #53
Indeed, it's very odd. However, I was able to ABX between LC and UC with score at 15/20.  Also, they don't actually seem to be same.
Reply #54
Monty made a good point in IRC that this is to be expected since compilers do random things to FP computations
Reply #55
[span style='font-size:15pt;line-height:100%']...One year later[/font][/span]
Just for curiosity, I've tried another comparison, using the same samples, in order to check vorbis's progress during three years, and especially during the last one.
I kept vorbis RC3 (march 2002), vorbis 1.01 (march 2003), and add the most advanced vorbis encoder: aoTuV beta 3. I'd like to check the amount of noise/coarseness audible with aoTuV compared to an old encoder which wasn't too affected by this problem.
results:
ABX log/scores are here.
There are still audible issues with aoTuV at this bitrate, but they are much lower than vorbis RC3. One exception: the last sample, which RC3 performed differently (and to my ears: better) on brass (micro-attacks sample).
Bravo to Aoyumi!
Reply #56
Wow.  That is some nice improvement.
It looks like aoTuV is pushing Vorbis in the right direction instead of regressing it
Nero AAC 1.5.1.0: -q0.45
Reply #57
[a href="index.php?act=findpost&pid=273435"][{POST_SNAPBACK}][/a]
The handling of a micro attack is one of the big subjects truly.
I know that QuantumKnot is performing the trial for solving this problem.
Probably, I am looking forward to it.
