Topic: autoupdate plugin (Read 3523 times) previous topic - next topic
autoupdate plugin
hi,
i'm looking for a plugin which updates my playlist.
i have all my mp3s in one directory and even if some mp3s come over in the direcotry i always must clear my playlist and add my direcotry in the playist again.
so i search a function where i can say "auto update" and he looks which directorys are newer as the last "auto update" and then he will put the new mp3s into my playlist and perhaps at the end he will sort it new...
i hope you understand what i mean. my english is not as perfect.
greets
InFlame
autoupdate plugin
This has been requested quite a few times.
I also think it is a great idea.
For now though, just drag the root directory onto your playlist amd then use "Remove duplicates" on the playlist menu.
This doesn't take that long, especially if most of the files are already in your database and haven't been changed since they were added.
autoupdate plugin
I second this.
"The brightest flame burns quickest..."
autoupdate plugin
ah, yeah! good idea!
autoupdate plugin
yes  i'd like to see that feature too
autoupdate plugin
Yea, I thought of an ingenious idea to solve this problem. I use keyboard shortcuts. Quick and simple. Ctrl+Shift+C clears the playlist then Ctrl+Shift+A adds directory, you really get used to it after a while, and I prefer it over auto-update because auto-update would make foobar load slower. Just my opinion.
autoupdate plugin
I think the other major players have this, like RealOne Player, Winamp5, Windows Media Player 9. I think it would be nice if foobar2000 had it also.
autoupdate plugin
Maybe a component that makes a menu item to load a preselected directory or directories when you click the menu command is a good idea?
It could then be extended to optionally load a directory or directories on startup?
Just a thought.
Also it doesn't seem like it would be that hard to make.
autoupdate plugin
That would be really helpful, to have automated playlist adding
autoupdate plugin
Just a thought.
No it is not that hard.  I've got a plugin in the works that pretty much does what you suggested already.  While it works....it is buggy right now.
