Topic: foo_utils (Read 153636 times) previous topic - next topic
Re: foo_utils
Reply #150
Not at the moment
Re: foo_utils
Reply #151
Hello  NEMO7538,
thanks for the answer! Any plans to include that feature (I guess in foo_utils)?
Re: foo_utils
Reply #153
I was having an issue where my playlist (DUI) wouldn't center when jumping to a track, it would either highlight the track at the top or bottom of the screen depending on which way it had to jump to get there. Removing foo_utils fixed it for me. Don't know if it's easily reproducible, a quirk of my system, or a weird interaction with another component, but thought I'd put it out there in case anyone else runs into it. People in this thread were having similar issues with other plugins...
Re: foo_utils
Reply #154
That is odd. The plugin does not even interact with the playlist view by any means that should cause such behaviour.
Re: foo_utils
Reply #155
There was probably no cause and effect in play. As I mentioned in the other thread, it's likely a coincidence.
Re: foo_utils
Reply #156
Yeah, sorry foosion, looks like Jailhouse is right... I've been having the issue for 2 weeks straight, took out utils and it worked perfectly fine for the first time. Worked again the next time I started foobar. And now it's back to not working with nothing changed. Not sure what about the act of removing utils made it want to work for a second, but I guess it wasn't actually related to your plugin. Very odd (and annoying) bug...
Re: foo_utils
Reply #157
Hey, I'm trying to output the current song and artist to a simple text file, but I can't find any documentation on how to use this component? How and what and huh?
Re: foo_utils
Reply #159
Nope.  NEMO7538 develops foo_plorg and it would have to be added there.
Hello marc2003,
thanks for your hint! As NEMO7538 is not planning to enable a visual indication for read-only playlists in foo_plorg - do you have any alternative how to visualize locked playlists (outside/inside foo_plorg)?
Thanks, MojoBass
