Topic: How to know if menu is triggered from playlist (Read 2121 times) previous topic - next topic
menu_item class in 0.7SDK
virtual void context_command(int n,const ptr_list_base<metadb_handle> & data,bool is_playlist)=0;
menu_item class in 0.8SDK
virtual void context_command(unsigned n,const ptr_list_base<metadb_handle> & data)=0;
"is_playlist" has gone in 0.8 SDK
Is there other way to know if context command is performed from playlist?
is_playlist switch was a bad misfeature of old API and has been removed. Put your playlist-specific context items in playlist/selection menu instead.
Changed in beta3, now a more generic way to determine where contextmenu parameters are from (GUID instead of bool).
It fits my needed,so I could update my plugin for 0.8.
another question
in 0.8 change log
- file size tracking
Are there any APIs for this new feature?
