Topic: AviSynth 2.5.4 and AVSEdit 1.0 Released (Read 3910 times) previous topic - next topic
Hi folks!
We are very proud to present you with another release of AviSynth, and the first release of AVSEdit.
AviSynth 2.5.3 -> 2.5.4 changes:
Additions:
    * Added Overlay() for doing advanced video overlays/layers. Overlay allows to place arbitrary video on top of eachother. Clips can have different sizes, have alpha masks and even different colorspace. A large variety of blend modes are available.
    * Added SSRC(int samplerate) very high quality SSRC resampling. Audio is always converted to float.
    * Added SuperEQ(). SuperEQ is a very precise 16 band equalizer.
    * Added ConditionalReader(). This enables users to load per frame settings into variables accessible to conditional variables.
    * ShowAlpha now returns RGB, YUY2, or YV12 via the pixel_type argument. The latter two can be used to layer an RGB clip with alpha transparency data onto a YUV clip using the 3-argument form of Overlay().
    * Added IsYUV(clip) to script language (it was only present in the documentation).
    * Added internal audiocache by WarpEnterprises. Added automatically by the filters that need it.
    * Added Histogram(mode="stereo") shows a clasic stereo graph from the audio in the clip. Some may know these from recording studios. This can be used for visualizing stereo width and potential phase problems.
    * Added Histogram(mode="stereooverlay"). Draws the stereograph on top of the original image. YV12 only.
    * Added ChangeFPS(linear=true/false). This will make AviSynth request frames in a linear fashion, when skipping frames. Default:true.
    * Added Tone(float length, float frequency, int samplerate, int channels, string type). This will generate sound.
          o Length is in seconds. Type can be "Silence", "Sine" (default), "Noise", "Square", "Triangle" or "Sawtooth".
          o Defaults are Tone(10.0, 440, 48000, 2, "sine").
Bugfixes:
    * Fixed out-of-bounds read in Normalize.
    * Fixed compiler warnings in avisynth_c
    * Better seeking precision in audio in DirectShowSource.
    * Fixed crashes and Audio corruption in ConvertToMono().
    * Fixed UnalignedSplice if only audio was present.
    * Fixed Trim crash, if only audio was present (throws an error).
    * Fixed slowdown on multiple Directshow Sources.
    * Fixed green bars in small video with mode="levels" and mode="color". For Histogram
    * Fixed overflow in ConvertAudioTo32bit().
Optimizations:
    * Optimization: MMX in Dissolve.
Changes:
    * Added Kevin Atkinsons avisynth_c 0.20 (stdcall) API.
    * Updated installer. (Thanks to V_ICE for inspiration).
    * EMMS is now executed between all filters to avoid potential FPU-states to be carried from one filter to the next.
    * If any filter should request audio that is out of bounds, if will no longer be passed to the filter above, but the invalid parts will be filled with silence.
    * Documentation restructured and much has been updated.
    * Added C-versions of conditional planedifference filters, for non-ISSE machines.
As always files can be downloaded from Sourceforge.
AVSEdit requires the DOT-net framework v1.1, and an installed version of AviSynth.
Regards, sh0dan // VoxPod.  AviSynth 2.5 developer.
seems like a lot of progress, great work as usual, care to elaborate shortly on what avsedit is about? (some sort of script maker or maybe avs editing gui for example?)
Some additional info about AVSEdit:
AVSEdit is the "official" AviSynth editor and it is a standalone version of DVX's AviSynth editor. Many features are added, and a basic user guide can be found here.
If you want to install it separately, it can be found here.
