Topic: Which codec do you use? (Read 20179 times) previous topic - next topic
Reply #50
In the case of M$ there's also the factor "blatant stupidity of the IBM people". If they had played their card rights at least OS/2 would have still been around in an "active way" (now it's a bit marginalised)
No inspiration
Reply #51
I was happy enough to start with a trial copy of Audiograbber (56 kbps ugh....) making me look for  "free MP3 encoder" the next instant. That search landed me on r3mix, and made me appreciate at least higher quality sounds.
I'm currently using Lame MP3 (R3mix), MPC -standard and - extreme and OGG 160 kbps , though I think about switching everything to OGG 160 for space reasons (maybe even 128, my hearing is not too good, I'm too scared to test frequency response  )
Reply #52
i use mpc.... mainly because it uses very little cpu (for playing at least) and the quality is extremely good... if not the best (i suppose thats quite debatable)....... also there actually is quite a bit of music out there just gotta know where to look (email me or msg me or something and ill tell you... this really isnt the place to say)....
anyways yes i have tried ogg and aac and everythign
mpc is more complete than ogg (as far as stages of developments) its more stable than aac (at least in my experience) and its higher quality than mp3....
feel free to argue...
Reply #53
I'm using Ogg for most of my music. The 128kbit/s preset works better than mp3, without taking that much more size. The encoder also works pretty fast, which is important to me.
Reply #54
I started a long while back with l3enc at 128.
For a while, I played with VQF, but eventually decided it just wasn't that good (and far too slow).
When MpegPlus first came out, I tested that for a while, but decided compatibility won out.
Then I got my hands on lame, and started using that (still at 128kbps... shame on me).
I started experimenting with vorbis at beta 2, and around beta 4 I started encoding more and more at 160kbps.
These days, I have completely transitioned from mp3 to vorbis, at 160kbps using garf's tuned encoder #2.
Oh, and I use EAC for ripping, it is all good.
gnoshi
happiness comes in brown paper bags.
Reply #55
I was the sinner who voted "mp3 FhG" in the poll. Yes, that "1" was me!
It's great to go against the flow! ;-)
But I have to confess that I've used --alt-preset normal for my last encoding and been very pleased. It's just I don't always have three hours to encode an album (PII 300MHz).
I can neither share mpc, nor play it on my portable hardware (which I don't even own yet, but it's on my Christmas list! ;-)). So it's not even an option.
David.
Reply #56
Try using the --r3mix preset to encode with Lame.  It's not as good quality as Dibrom's, but it encodes very quickly (about an hour per full CD on my P2/233) and the quality is still very good.
Reply #57
I guess David knows about the --r3mix preset, gutzalpus
Reply #58
I use Ogg Vorbis/Garf's tuned -b350 mode. The quality is excellent (definitely better then MP3 320kbps) and the bitrate is acceptable - it varies between 300-320kbps most of the time. Also, with Vorbis you get flexible tagging system (unlike ID3), and gapless songs work flawlessly.
Reply #59
My requirements are probably vastly different from most in this thread. I restore the material from very old phonograph records, dating as far back as the very first records. I exchange this material with others via e-mail attachments. Most of the recipients use 56K modems.
I am concerned with quality but quality is limited in this old material. I want quality versus small file size.  MP3 at low bit rates wasn't satisfactory. VQF and WMA were satisfactory. But I feel the need to support the Ogg Vorbis project and my results have been more than satisfactory - good quality vs small file size.
I am elderly and I'm sure my hearing is deficient. I have a decent amp and speakers on my PC and I like what I hear with Ogg! I'm not in a position to evaluate the results of my work other than by using my ears.  I've been using the RC2 Drag & drop encoder and am anxiously awaiting a later release.
Reply #60
I am undoubtedly a Vorbis freak in every way. I have compressed 300+ CDs to high bitrate Vorbis and I am quite happy with em. Not to mention 20+ divx avi clips with vorbis audio. I had to rework nandub a bit to pull that off.  Granted I have an MP3 player(sans firmware update option. ) But I use it less and less now that I have my laptop. Only on long trips or times I can't have the good ole LT with me do I actually mess with the MP3 player. If I want lossless encoding I will keep the stuff PCM encoded on the CDs. But if I want compressed stuff to play on my PC Vorbis is king for me! In fact I am listening to a Vorbis encode of a Saint Etienne track right now and must say that it rocks!
Reply #61
hehe when i had my pentium 75 it was l3enc. ugh took around 1 hour to encode at 128kbit. then audiocatalyst with xing. then i got into lame at 3.70 time. i have used mpc and ogg, but im sticking with lame 3.90 rev7 and monkeys audio. im using winamp + MAD decoder and a compaq ipaq pocket pc 3630 with a 1 gig ibm microdrive and a rio volt for portable playing.
Reply #62
I have started encoding using some MPlifier. Then I learned what an 'artifact' sounds like (on some Pink Floyd track). But I wasn't concerned much about MP3 back then. Then Came Xing's Audiocatalyst (damn' it was fast). Then I have found about LAME, played around with non-tuned GPSYCHO VBR (--vbr-new -V3 -ms) and --r3mix. Then I've found this site and it convinced me to switching to --dm-preset (now --alt-preset). I have some portable MP3 player, so MPC od AAC are both of no interest for me, but --alt-prset standard (rev7) sounds great for me now.
Good Job, Dibrom -thank you!
