Topic: Conversion Tagging (Read 2930 times) previous topic - next topic
Conversion Tagging
I am just starting out with foobar and have spent quite a while searching for this but I cannot find the answer:
When converting a file (AAC as an example) how do you get it to name the files with the tags that freedb picked up when the cd is put in?
Conversion Tagging
So you can't tag songs while ripping from cd?
Conversion Tagging
Go to "Preferences->Components->Diskwriter", customize the "Output file name formatting" to your liking.
Conversion Tagging
It is not recommended to use foobar2000 for ripping. It doesn't use any error correction, so you're going to be much better off with EAC.
However, the tags should be preserved during transcoding (in this case, from a CD).
Which component and what settings are you using to encode the files?
Conversion Tagging
I am trying to use FAAC to convert from cd's with pretty much default settings.  I am trying to create .AAC files
