Topic: Log in problem (Read 3134 times) previous topic - next topic
Log in problem
sorry, I can't post this in Off Topic coz its about HA.org, it doesn't fit anyware
today, when i try to access HA.org, this error occured
Warning: mysql_connect(): Too many connections in
/home/hydrogenaudio.org/public_html/sources/Drivers/mySQL.php on line 67
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in
/home/hydrogenaudio.org/public_html/sources/Drivers/mySQL.php on line 70
ERROR: Cannot find database hydrogen_ipb
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in
/home/hydrogenaudio.org/public_html/sources/Drivers/mySQL.php on line 103
    There appears to be an error with the Hydrogenaudio Forums database.
    You can try to refresh the page by clicking here, if this does not fix the error, you can
contact the board administrator by clicking here
    Error Returned
mySQL query error: SELECT moderator.mid as is_mod, moderator.allow_warn, m.id, m.name, m.mgroup,
m.password, m.email, m.restrict_post, m.view_sigs, m.view_avs, m.view_pop, m.view_img,
m.auto_track,
                              m.mod_posts, m.language, m.skin, m.new_msg, m.show_popup,
m.msg_total, m.time_offset, m.posts, m.joined, m.last_post,
                          m.last_visit, m.last_activity, m.dst_in_use,
m.view_prefs, m.org_perm_id, m.temp_ban, m.sub_end, g.*
                          FROM ibf_members m
                            LEFT JOIN ibf_groups g ON (g.g_id=m.mgroup)
                            LEFT JOIN ibf_moderators moderator ON
(moderator.member_id=m.id OR moderator.group_id=m.mgroup )
                          WHERE m.id=3989
mySQL error: Too many connections
mySQL error code:
Date: Saturday 24th of January 2004 06:15:32 AM
We apologise for any inconvenience
Log in problem
I got the same error. Maybe some new record in MySQL usage is reached ?
Log in problem
The same here. But I tried again and everything was OK.
Log in problem
oops, since when there is a "Site Related Discussion"!
I think I have to go for an eye checkup
what happened, this problem occurs after HA.org update the forum?
