Topic: Different sorting (Read 2451 times) previous topic - next topic
Different sorting
Well, I could say this is the only thing missing so that I'd consider this program perfect, 100%.
Is there a way I could sort the songs by path and filename (and not by path+filename)? All my music are on a folder called E:\MP3. My "Albumless" songs are in this directory. Then I have a folder called Albums where I have full albums. Foobar2000 sorts like this ( \ is E:\MP3 )
\aa.mp3
\ab.mp3
\ak.mp3
\Albums\First\song.mp3
\Albums\Second\song.mp3
\b.mp3
\c.mp3
etc.
Well, I wish Foobar didn't split my "Albumless" songs with Albums dir. So I wish it were like this
\aa.mp3
\ak.mp3
\b.mp3
\c.mp3
\z.mp3
etc.
So my question is... is there a way I could sort this way without changing the whole structure of my MP3 directory? It would be like Winamp's sorting (path and filename) scheme. If there is, it will be really sweet!
Thank you very much.
[EDIT] Just one more question, where are the filetype association? (besides when installing)
Liberate tutemae ex inferis
Different sorting
In foobar directory there is a file: fooassoc.exe. Just run it and you can associate extensions.
Different sorting
You can get the path minus the filename by using $left(%_path%,$sub($len(%_path%),$len(%_filename_ext%))). That way you can change the sort order to sort first by path, then by filename. Basically, change "Preferences --> Core --> Sort incoming files by:" to
$left(%_path%,$sub($len(%_path%),$len(%_filename_ext%)))|%_filename_ext%
I think that should work.
Different sorting
Gee! That really worked! Thanks a lot Blind!
Different sorting
wow i think use the code you can do almost everything you want:)
but many people don't know how to write it.
