Topic: Lame 3.95 vs 3.90.3 (Read 26255 times) previous topic - next topic
Lame 3.95 vs 3.90.3
Starting with mine:
ABC/HR for Java Version 0.4b, 12 styczeñ 2004
Testname: velvet (aps)
1R = C:\Music\LAMEsamples\velvet.3-90-3.wav
2L = C:\Music\LAMEsamples\velvet.3-95.wav
General Comments: Original vs Sample 1 - warm up, but still managed to ABX it at 32 tries. (I use techinque of min. 16x, 24x, 32x) Most noticeable artifacti 8.11-9.30
1R File: C:\Music\LAMEsamples\velvet.3-90-3.wav
1R Rating: 4.0
1R Comment: Slightly smeared percussion, no ATH problem
2L File: C:\Music\LAMEsamples\velvet.3-95.wav
2L Rating: 3.0
2L Comment: Smeared percussion, ATH problems
ABX Results:
Original vs C:\Music\LAMEsamples\velvet.3-95.wav
    16 out of 16, pval < 0.001
Original vs C:\Music\LAMEsamples\velvet.3-90-3.wav
    23 out of 32, pval = 0.01
Bad news. 3.95 still worse, noticeably.
I didn't even try to ABX these against themselves, the difference is glaring.
EDIT: Yes, glaring. Glaring PLACEBO. Failed ABX, pval ~0.4 at 32 tries.
Maybe I've got tired of this percussion, I'll redo this tomorrow.
EDIT2: Failed again, similar result.
ruxvilti'a
Lame 3.95 vs 3.90.3
Nice initiative. Thanks
Lame 3.95 vs 3.90.3
Oh, I see that there's 3.95.1 out now.
I'll retest with this later. (although the chance is slim the result may be different)
Next sample tomorrow.
Bug report - Lame 3.95.x can't decode at all. (jon33 compile)
Even can't decode its own files!
ruxvilti'a
Lame 3.95 vs 3.90.3
Verified.
Lame 3.95 vs 3.90.3
foobar 0.77a ABX, replaygain, no DSP
Sony MDR-P70 headphones, somewhat noisy PC, Terratec PCI soundcard 5 years old
the candidate: fatboy
1) --preset cbr 128
-wav vs. 3.90.3
outrageous, mp3 sounds very "scratchy".. 8/8, 0.4% guess prob.
-wav vs. 3.95.1
much better than 3.90.3, still easy to pick from wav. 8/8, 0.4%
-3.90.3 vs. 3.95.1:
3.90.3 very severe artifacts, 3.95.1 much better.  8/8, 0.4%
clear winner 3.95.1
2) --preset 160 (ABR)
wav vs. 3.90.3 (191kbit):
still very scratchy vocals, slightly better than 128CBR.  8/8 0,4%
wav vs. 3.95.1 (204kbit):
needs utmost concentration, scratching is gone  10/16, 22.7% guess prob.
3.90.3 vs. 3.95.1:
easy. 8/8
clear winner 3.95.1
3)--preset medium
wav vs. 3.90.3 (247kbit):
scratchy vocals, big letdown for that bitrate.  8/8
wav vs. 3.95.1 (237kbit):
4/16, 98,9% of guessing. transparent for me
3.90.3 (247kbit) vs. 3.95.1 (237kbit):
scratchy vocals in 3.90.3. 8/8
clear winner 3.95.1
4) --preset standard
wav vs. 3.90.3 (265kbit):
impossible
wav vs. 3.95.1 (268kbit):
impossible
both transparent to me
3.90.3 is very disapointing for this sample at medium bitrates, 3.95 does good
thanks, need a pause now
edit: added bitrates for ABR 160
Lame 3.95 vs 3.90.3
huh, astralstorm, please edit your post until you came up with a decision.
it is a bit ... biased now.
my feelings are too.
Sony666's results are very promising though. I think, that if there are any major differences, they will be rather in the low bitrate area.
testing preset medium with 3.90.3 is a bit unfair, because that wasn't tuned for 3.90.x.
it was added afterwards and tuned for 3.93, I think.
EDIT: typos
Lame 3.95 vs 3.90.3
more samples from http://lame.sourceforge.net/gpsycho/quality.html
Metallica - Fade To Black (ftb_samp.wav)
1) --preset cbr 128
-wav vs. 3.90.3:
very small "warbling" effect at ~0.4s, only listenable with headphones, but 8/8
-wav vs. 3.95.1:
11/16 (10.5% of guess.) hmmm.... very hard to diff, if possible at all. need direct comparison vs. 3.90.1
3.90.3 vs. 3.95.1:
8/16 (59.8% guess).. bleh, I could have sworn the guitar attack at very start was more distorted with 3.90.3, but...
Conclusion: both do excellent on this real world sample. I was very surprised with 128k CBR quality  higher bitrates useless to abx here..
the "infamous" velvet
1) --preset cbr 128
-wav vs. 3.90.3:
obvious.. can't handle the sharp attacks, hissing...  8/8
-wav vs. 3.95.1:
better handling of sharp attacks, still hissing  8/8
3.90.3 vs. 3.95.1:
14/16 (0.2% guess) 3.90.3 has a slight error in first base drum attack
3.95.1 ahead
-wav vs. 3.90.3 (163kbit):
base drum has obvious errors  8/8
-wav vs. 3.95.1 (171kbit):
base drum errors are gone, trying to diff via hissing... yes. 8/8. hi-hat(?) sounds softer in original wav, but encoding is good here
3.90.3 vs. 3.95.1:
easy, 3.90.3 has erros in base drum that sound a little like clipping  8/8
3.95.1 clear winner for me
3) --preset standard
--wav vs. 3.90.3 (231kbit):
took long, long time to figure this out... slight unnatural hissing in encode. 13/16 (1.1% guess)
-wav vs. 3.95.1 (188kbit):
not hard to pick with the training from 3.90.3, slight unnatural sharpness. same as above  7/8 (3.5% guess)
-3.90.3 vs. 3.95.1:
7/8 (3.5%)... 3.95.1 sharp hissing seems a tiny little more obvious. I will dream of this sample tonight.
3.95 better at medium bitrates, --aps.. very hard.. numbers say 3.90.3 but wait for other opinions on that
Lame 3.95 vs 3.90.3
I used the Waiting sample using the --preset standard command line on both v3.90.3 and 3.95.1 - I found v3.95.1 to be slightly better than 3.90.3 - hard to ABX the two - had to rest, then I got it
ABC/HR Version 0.9b, 30 August 2002
Testname: Waiting --preset standard
1L = Z:\Music\Test Samples\3.90.3\Wavs\001 Waiting.wav
2R = Z:\Music\Test Samples\3.95\Wavs\001 Waiting.wav
General Comments:
Tested 3.5 to 5 sec
1L File: Z:\Music\Test Samples\3.90.3\Wavs\001 Waiting.wav
1L Rating: 4.4
1L Comment: Smearing, seems worse than sample 2, very close
2R File: Z:\Music\Test Samples\3.95\Wavs\001 Waiting.wav
2R Rating: 4.7
2R Comment: Smearing as well, not as bad as 1, not anoying
ABX Results:
Original vs Z:\Music\Test Samples\3.90.3\Wavs\001 Waiting.wav
    13 out of 14, pval < 0.001
Original vs Z:\Music\Test Samples\3.95\Wavs\001 Waiting.wav
    10 out of 10, pval < 0.001
Z:\Music\Test Samples\3.90.3\Wavs\001 Waiting.wav vs Z:\Music\Test Samples\3.95\Wavs\001 Waiting.wav
    34 out of 45, pval < 0.001
Lame 3.95 vs 3.90.3
Testname: Fatboy --preset standard
1L = Z:\Music\Test Samples\3.90.3\Wavs\Fatboy Audio Quality Test File.wav
2L = Z:\Music\Test Samples\3.95\Wavs\Fatboy Audio Quality Test File.wav
General Comments:
Very hard to call which encoder is really better at this sample - 1 seams to have problems with a sort of crackle, but 2 seems slightly distorted throughout - actually had trouble w/ 2 for a sec cause of room noise - i would call 2 the winner cause it doesnt seem as harsh as 1 does in places
1L File: Z:\Music\Test Samples\3.90.3\Wavs\Fatboy Audio Quality Test File.wav
1L Rating: 3.9
1L Comment: Slight crackle sound, not bad, close to origional
2L File: Z:\Music\Test Samples\3.95\Wavs\Fatboy Audio Quality Test File.wav
2L Rating: 4.3
2L Comment: Less distortion then 1, pre-echo, but no crackles
ABX Results:
Original vs Z:\Music\Test Samples\3.90.3\Wavs\Fatboy Audio Quality Test File.wav
Original vs Z:\Music\Test Samples\3.95\Wavs\Fatboy Audio Quality Test File.wav
    16 out of 18, pval < 0.001
Z:\Music\Test Samples\3.90.3\Wavs\Fatboy Audio Quality Test File.wav vs Z:\Music\Test Samples\3.95\Wavs\Fatboy Audio Quality Test File.wav
Lame 3.95 vs 3.90.3
Don't forget that there are 2 vbr modes
Lame 3.95 vs 3.90.3
from http://sound.media.mit.edu/mpeg4/audio/sqam/
harp40_1.wav (harpsichord)
1) --preset cbr 128
-wav vs. 3.90.3: obvious distortions, 8/8
-wav vs. 3.95.1: obvious distortions, 8/8
-3.90.3 vs. 3.95.1: unable to find diff, would be pure guess
-wav vs. 3.90.3 (144kbit): less annoying than 128k, still 8/8
-wav vs. 3.95.1 (145kbit): less annoying than 128k, still 8/8
-3.90.3 vs. 3.95.1: 3/8, pure guess
3) --preset medium (VBR)
-wav vs. 3.90.3 (134kbit): 8/8, obvious distortions like 128k
-wav vs. 3.95.1 (111kbit): 8/8, obvious distortions
-3.90.3 vs. 3.95.1: 2/8, both deliver equally bad results for that VBR preset
-wav vs. 3.90.3 (159kbit): 10/16, slight distortion at very first note, hard to find
-wav vs. 3.95.1 (144kbit): 16/16 yes..same as above, training from 3.90 helped finding it
-3.90.3 vs. 3.95.1: 10/10, 3.95.1 has slightly more annoying distortion
conclusion: If I was a Harpsichord fan I'd stay away from mp3 . But I dont even know what they look like.
edit:
5) --preset fast standard
-wav vs. 3.90.3 (159kbit): very easily noticeable background noise added during first sec, 8/8
-wav vs. 3.95.1 (165kbit): 15/20 something is not right about background noise during 1st second, hard to find
-3.90.3 vs. 3.95.1: 8/8, 3.90.3 sounds "dirty" during first second, 3.95 clearer
Lame 3.95 vs 3.90.3
v3.90.3 seems to edge out v3.95.1 in Waiting using --preset fast standard - read the comments below...
Testname: Waiting --preset fast standard
1R = Z:\Music\Test Samples\3.95.1 Fast.wav
2L = Z:\Music\Test Samples\3.90.3 Fast.wav
General Comments:
Neither clip sounds great, comparing the encoded files to the origional was easy with or without boosted trebble, 2 seems to have a slight edge
1R File: Z:\Music\Test Samples\3.95.1 Fast.wav
1R Rating: 4.3
1R Comment: Slightly worse than sample 2, suffers from a loss of high end - seems like background hiss is removed, smearing, sounds harsh in places, such as the during the "at all"
2L File: Z:\Music\Test Samples\3.90.3 Fast.wav
2L Rating: 4.6
2L Comment: Very slight loss of clarity, loss of "air" in the file - easy to tell w/ boosted trebble, the "for.....this....moment" part of the song sounds smeared
ABX Results:
Original vs Z:\Music\Test Samples\3.95.1 Fast.wav
    18 out of 21, pval < 0.001
Original vs Z:\Music\Test Samples\3.90.3 Fast.wav
    15 out of 18, pval = 0.004
Z:\Music\Test Samples\3.95.1 Fast.wav vs Z:\Music\Test Samples\3.90.3 Fast.wav
Lame 3.95 vs 3.90.3
LARGE difference in quality here - v3.90.3 has the clear advantage in this instance.
Testname: DaFunk --preset cbr 128
1L = Z:\Music\Test Samples\3.95.1 CBR 128.wav
2R = Z:\Music\Test Samples\3.90.3 CBR 128.wav
General Comments:
Very supprised between the large difference in qual between 1 and 2 here - 2 very close to the origional while 1 sounds distorted.
1L File: Z:\Music\Test Samples\3.95.1 CBR 128.wav
1L Rating: 3.2
1L Comment: Kind of ringing / warble in the background - anoying, much worse than sample 2
2R File: Z:\Music\Test Samples\3.90.3 CBR 128.wav
2R Rating: 4.2
2R Comment: Even at 128kbps this sounds decent - the warble that is present in 1 is almost completely absent - actually had to concentrate for a sec to ABX from the origional - crisper than 1
ABX Results:
Original vs Z:\Music\Test Samples\3.95.1 CBR 128.wav
Original vs Z:\Music\Test Samples\3.90.3 CBR 128.wav
    12 out of 12, pval < 0.001
Z:\Music\Test Samples\3.95.1 CBR 128.wav vs Z:\Music\Test Samples\3.90.3 CBR 128.wav
EDIT - Added encspot info - it seems that v3.95.1 uses many more short blocks than 3.90.3 (On this clip, 3.90.3 uses 7.9% short blocks while 3.95.1 uses 25.3%) - I have seen this in many other clips as well.
v3.90.3 --preset cbr 128[/u]
Bitrates:
128    ||||||||||||||||||||||||||||||||||||||||      99.9%
Type                : mpeg 1 layer III
Bitrate            : 127
Mode                : joint stereo
Frequency          : 44100 Hz
Frames              : 791
ID3v2 Size          : 0
First Frame Pos    : 0
Length              : 00:00:20
Max. Reservoir      : 486
Av. Reservoir      : 281
Emphasis            : none
Scalefac            : 37.4%
Bad Last Frame      : no
Encoder            : Lame 3.90
Lame Header:
Quality                : 58
Version String        : Lame 3.90
Tag Revision          : 0
VBR Method            : cbr
Lowpass Filter        : 17600
Psycho-acoustic Model  : nspsytune
Safe Joint Stereo      : no
nogap (continued)      : no
nogap (continuation)  : no
ATH Type              : 2
ABR Bitrate            : 128
Noise Shaping          : 2
Stereo Mode            : Joint Stereo
Unwise Settings Used  : no
Input Frequency        : 44.1kHz
v3.95.1 --preset cbr 128
Bitrates:
Bitrate            : 127
Mode                : joint stereo
Frames              : 791
ID3v2 Size          : 0
First Frame Pos    : 0
Length              : 00:00:20
Max. Reservoir      : 482
Av. Reservoir      : 175
Emphasis            : none
Scalefac            : 1.1%
Bad Last Frame      : no
Encoder            : Lame 3.95
Lame Header:
Quality                : 57
Version String        : Lame 3.95
Tag Revision          : 0
VBR Method            : cbr
Lowpass Filter        : 17500
ATH Type              : 4
ABR Bitrate            : 128
Noise Shaping          : 1
Lame 3.95 vs 3.90.3
If I'm reading these right, it would seem that 3.90.3 does better on some samples, with 3.95.1 doing better on others (when using APS).
flac>fb2k>kernel streaming>audiophile 2496>magni>dt990 pro
Lame 3.95 vs 3.90.3
Where can I download the DaFunk sample?
Lame 3.95 vs 3.90.3
Just tested the Layla sample at --preset cbr 128 :: v3.90.3 seems to be the distinct winner of this one as well - might try at --preset standard in a few min..... EDIT - tried and failed
Testname: Layla --preset cbr 128
1R = Z:\Music\Test Samples\Layla 3.90.3 cbr 128.wav
2L = Z:\Music\Test Samples\Layla 3.95.1 cbr 128.wav
General Comments:
Started the ABX test focusing in the 3.5 - 5 sec area of the song, used it to compare the 2 files to the original (easy at 128kbps  Could not distinguish between the 2 mp3s in that area, focused on the 0-2 sec range and found a large difference.
1R File: Z:\Music\Test Samples\Layla 3.90.3 cbr 128.wav
1R Rating: 3.9
1R Comment: Does not exhibit the obvious under water sound of sample 2 in the 0-2 sec range, decent overall, rest of file sounds similar to 2
2L File: Z:\Music\Test Samples\Layla 3.95.1 cbr 128.wav
2L Rating: 3.0
2L Comment: Very bad under water sound from 0-2 sec, rest of file sounds less crisp than origional
ABX Results:
Original vs Z:\Music\Test Samples\Layla 3.90.3 cbr 128.wav
Original vs Z:\Music\Test Samples\Layla 3.95.1 cbr 128.wav
Z:\Music\Test Samples\Layla 3.90.3 cbr 128.wav vs Z:\Music\Test Samples\Layla 3.95.1 cbr 128.wav
Lame 3.95 vs 3.90.3
Hmm, is 3.95.1 generally worse at 128 kbps CBR? Viper, can you give 128 kbps ABR a try?
Lame 3.95 vs 3.90.3
Sure.... results are pretty much the same as CBR, except both clips sound better overall
Testname: Layla --preset 128 ABR
1R = Z:\Music\Test Samples\Layla 3.90.3 128kbps ABR.wav
2L = Z:\Music\Test Samples\Layla 3.95.1 128kbps ABR.wav
General Comments:
Sample 2 sounds distinctively worse in the 0-2 sec range, both samples sound better than CBR - would bet sample 2 is v3.95.1 (sounds similar to CBR)
1R File: Z:\Music\Test Samples\Layla 3.90.3 128kbps ABR.wav
1R Rating: 4.1
1R Comment: Not bad sounding, better than sample 2
2L File: Z:\Music\Test Samples\Layla 3.95.1 128kbps ABR.wav
2L Rating: 3.6
2L Comment: Warble in the 0-2 sec range, worse than sample 1
ABX Results:
Original vs Z:\Music\Test Samples\Layla 3.90.3 128kbps ABR.wav
Original vs Z:\Music\Test Samples\Layla 3.95.1 128kbps ABR.wav
    14 out of 15, pval < 0.001
Z:\Music\Test Samples\Layla 3.90.3 128kbps ABR.wav vs Z:\Music\Test Samples\Layla 3.95.1 128kbps ABR.wav
Lame 3.95 vs 3.90.3
They look pretty elegant:
http://www.henrylim.org/Harpsichord.html
Lame 3.95 vs 3.90.3
Tested the 41_30 sample with both encoders at --preset standard - I'll have to call this one a tie.
Testname: 41_30 --preset standard
1R = Z:\Music\Test Samples\3.95.1 41_30 --preset standard.wav
2R = Z:\Music\Test Samples\3.90.3 41_30 --preset standard.wav
General Comments:
Focused on the 0 - 2.3 sec range of this clip - both encoders suffer from smearing, but I can not ABX the difference between the 2 - I thought I could hear a difference at first, but couldnt ABX it - I'll have to call this one a tie
1R File: Z:\Music\Test Samples\3.95.1 41_30 --preset standard.wav
1R Rating: 4.5
1R Comment:
2R File: Z:\Music\Test Samples\3.90.3 41_30 --preset standard.wav
2R Rating: 4.5
2R Comment:
ABX Results:
Original vs Z:\Music\Test Samples\3.95.1 41_30 --preset standard.wav
Original vs Z:\Music\Test Samples\3.90.3 41_30 --preset standard.wav
Z:\Music\Test Samples\3.95.1 41_30 --preset standard.wav vs Z:\Music\Test Samples\3.90.3 41_30 --preset standard.wav
    15 out of 24, pval = 0.154
Lame 3.95 vs 3.90.3
Fresh new.
Heh, I like Pink Floyd - this one sound like a fragment of a piece from album "Saucerful of Secrets".
Highly psychedelic.
ABC/HR for Java Version 0.4b, 14 styczeń 2004
Testname: main_theme (preset standard)
1R = C:\Music\LAMEsamples\main_theme.3-90-3.mp3.wav
2R = C:\Music\LAMEsamples\main_theme.3-95-1.mp3.wav
General Comments: Well well, it seems that without Sensaura on (resamples -> 48 kHz) it is much easier to ABC/HR anything. I didn't even bother to ABX with it on.
1R File: C:\Music\LAMEsamples\main_theme.3-90-3.mp3.wav
1R Rating: 4.0
1R Comment: 5-7s: Sharper transition center->right, ABX vs orig is based sollely on this. Failure ABXing with 2 on that, but detected warbling in plates 3-5s
ABX Results:
Original vs C:\Music\LAMEsamples\main_theme.3-95-1.mp3.wav
    8 out of 17, pval = 0.685
Original vs C:\Music\LAMEsamples\main_theme.3-90-3.mp3.wav
    12 out of 16, pval = 0.038
C:\Music\LAMEsamples\main_theme.3-90-3.mp3.wav vs C:\Music\LAMEsamples\main_theme.3-95-1.mp3.wav
    18 out of 24, pval = 0.011
ruxvilti'a
Lame 3.95 vs 3.90.3
Fresh new.
Highly psychedelic.
I took that sample from "More"
Lame 3.95 vs 3.90.3
so, from skimming over this thread, I'm guessing that 3.95 is a "meh" release since quality is more or less the same while file sizes have increased
Lame 3.95 vs 3.90.3
OT:
That Harpsichord is fake! Is made of LEGO pieces!
Although it does look like the real thing
On Topic:
I think that this version of LAME is not going to do very good on Roberto's test
