Topic: Bug with APEs & embedded cuesheets? (Read 3051 times) previous topic - next topic
I think I found a small bug.
I have lots of big .APE files of my albums with embedded cuesheets. Now, if I right-click on any song of an album try to edit tags in the "Show file info" window, everything works fine, except for when I want to completely delete a tag. It just re-appears when I click "Re-load info from file". Removing tags works fine when I edit APEs without embedded cuesheets. I found out about this when I recently wanted to remove all of my "comment" tags from the files using the masstagger.
Am I doing anything wrong?
Thanks in advance and sorry for my crappy english.
You have to 'update file'
'reload file info' does just that, it reloads what you deleted
I of course click "Update file"
Have you tried it for yourself?
Extract the cue, do all the necessary operations on the cue and reintegrate it.
Regards,
The Link
Regards,
The Link
That's what I used to do. It's kinda much work with 300+ APEs though, so I thought there has to be a better solution :/
Did you try with Case's tag? Together with his sweep utility you are able to do it recursively on directories.
Do a search on the forum, there are plenty of examples how to use the two together.
True... I'd really like to know why it doesn't work in foobar though
