Thank you for such a quick response! I've just tested the method outlined above, and it works just fine.
Additionally, for anyone who might be interested in using this method with Speek's Batchenc frontend, simply copy the entire contents (all files and subfolders, as they are shown) from the extracted "producer" directory to wherever your the Batchenc frontend is located. Copy "ap.rpad" (as Karl described it, above) to the "audiences" sub-directory. Conversion can then be invoked through Batchenc with this line:producer.exe -i <infile> -o <outfile.rm> -ad ap.rpad -lc e,d
Still no luck in getting this to a format iTunes/iPod will accept... but it's a start!
dtdrive seems to be finding the DLLs, since I can successfully transmux an AAC-RM to M4A using dtdrive file.rm -W file.m4a. But when an ACELP-RM is used as input with the same line, the following is displayed:*******************************************************************************
****** Begin File=file.rm Protocol=Unspec. ShortName=Unspec. ******************
====== Begin File Header ======================================================
Flags = 9
IsRealDataType = 1
StreamCount = 1
AllAudioCodecs = sipr
Audiences = ap;
audioMode = music
Creation Date = 3/26/2004 16:59:17
Generated By = Helix DNA(TM) Producer 10.0 for Windows, Build 10.0.
0.195
Modification Date = 3/26/2004 16:59:17
videoMode = normal
====== End File Header ========================================================
------ Begin Stream Header = 0 ------------------------------------------------
ActualPreroll = 960
AvgBitRate = 16000
AvgPacketSize = 320
Duration = 30720
EndOneRuleEndAll = 1
EndTime = 30000
MaxBitRate = 16000
MaxPacketSize = 320
Preroll = 1920
StreamNumber = 0
ASMRuleBook = priority=5,averagebandwidth=16000,PNMKeyFrameRule=T;
priority=5,averagebandwidth=0,PNMNonKeyFrameRule=T,O
nDepend="0",OffDepend="0";
intrinsicDurationType = intrinsicDurationContinuous
MimeType = audio/x-pn-realaudio
StreamName = Audio Stream
OpaqueData = <Buffer>
RMFF 1.0 Flags = <Buffer>
------ End Stream Header = 0 --------------------------------------------------
Drive time: 0.016000 seconds.
Failed.
- M.
