Topic: .3gp to .mov (Read 3567 times) previous topic - next topic
.3gp to .mov
Hi all,
i need to translate a 3gp/h263 baseline file into a quicktime/h263 baseline file in order to grab some frames with the Java Media Framework on a solaris. I 've been looking through it but i don't know what changes are needed to make in the 3gp file format, any idea, any suggestion, any sample???
Thanks in advance!!
Juan.
.3gp to .mov
hm simply try opening the .3gp in quicktime and pass trough to .mov
dunno if this is possible but i guess the chance that it works is great
.3gp to .mov
No it does not work :-) I already tried it, i got a parsing error.
Thanks anyway.
.3gp to .mov
Sorry i didn´t understand your reply at first, i cannot make use of quicktime due to the fact that mu application must run on a solaris machine.
.3gp to .mov
Open the file in QuickTime, choose File -> Save as... and in the following dialog choose to save as "Self-contained."
The above requires QuickTime Pro. If you have a Windows machine, you may be able to do it using the 3ivx filter suite.
EDIT:
I see you wish to do it on a Solaris machine. FFmpeg will do the trick. Download and compile it, and issue the following command:
ffmpeg -acodec copy -vcodec copy -i infile.3gp outfile.mov
