Topic: Vis delay? (Read 2436 times) previous topic - next topic
Vis delay?
Hi all,
Is there a way to change the Vis delay?
Im finding that by the time i get the vis data and display it, its around 1/2 a second late.
Winamp2 allows for this, does FB2K have a similar delay value that can be changed?
Vis delay?
class visualization : public service_base
public://all calls are from main thread
   virtual void on_data(const vis_chunk * data)=0;
   virtual void on_flush()=0;
   virtual double get_expected_latency() {return 0;}//return time in seconds; allowed to change when running
   //allowed to change in runtime
   virtual bool is_active()=0;
   virtual bool need_spectrum()=0;
   static const GUID & get_class_guid();
   static bool is_vis_manager_present()
  static const GUID guid =
  { 0x5ca94fe1, 0x7593, 0x47de, { 0x8a, 0xdf, 0x8e, 0x36, 0xb4, 0x93, 0xa6, 0xd0 } };
  return service_enum_is_present(guid);
Vis delay?
Ok, but how does that help with the problem?
Im still getting the vis data from FB2K late.
Vis delay?
Uhm, the function indicated in bold in my post above:
does exactly what you want. Time to turn your brain on ?
More info here if you have any more issues with that function.
Vis delay?
Time to turn your brain on?
Indeed...
Sorry, for some reason i got the impression that the function was used to get the delay time from FB2K...not a way for me to tell FB2K the delay.
