Topic: MP3 at 128kbps public listening test (Read 43568 times) previous topic - next topic
Reply #150
OT:
<nitpick mode>
It's Mac, not MAC. MAC is something your ethernet card has, while Mac is short for Macintosh.
</nitpick mode>
Then why do you use "mac" in your signature?
Really, all-caps is just a way of emphasizing...
Reply #151
Good... lots of replies
So, I reckon Gogo is wellcome? In this case, it'll be featured instead of Audition Legacy.
@Guruboolez: I don't think 6 codecs is too much considering some of them will (theoretically) sound bad. And I agree, I don't think there will be more MP3 tests happening, so it's better if this one covers most significative encoders.
Also, I agree with the idea of adding Fatboy. But, in this case, what sample will be replaced?
For those that don't remember the sample list:
http://www.hydrogenaudio.org/forums/index....howtopic=12358&
Regards;
Roberto.
Reply #152
I still think that you should consider new Lame. Perhaps a new release could be available soon...
Reply #153
How "soon"?
Reply #154
Well, probably between 1 and 2 weeks.
Reply #155
I plan to start my test on the 14th.
So please try to hurry
Reply #156
According to the fact that 3.90.3 is the same as 3.90 for abr encodings, I'd like to see the newest lame encoder in the test. After all, lame 3.90 is more than two years old now. I know it was heavily tested; but then, why not considering this public listening test as a first step for a complete checking? Even if 3.94 is beta... (recommanded version of musepack is still alpha...)
Reply #157
I would like to see whether the technical improvements since 3.90x (substep quantization and all the other quality improvement changes detailed in history.html) will really result in better quality than the time-tested version like 3.90.3  .
Reply #158
Guruboolez, may be you could do a presonal listening test between 3.90.3 and 3.94 like you did for WMA and Vorbis before previous test? This will not only help with test decision, but also provide some usefull information.
-Eugene
The  greatest  programming  project of all took six days;  on the seventh  day  the  programmer  rested.  We've been trying to debug the !@#$%&* thing ever since. Moral: design before you implement.
Reply #159
I think before a build from the 3.94 branch can be considered, all known problems (e.g. this one ) should be resolved, and a short comparison test (perhaps only individual) should be performed.
Reply #160
eltoder> if I find time enough and some motivation, why not.
Continuum> I don't see any problem in the mentioned thread with abr/cbr settings ??
Reply #161
quickly ABXed fsol.flac
with preset 128
(3.90.3 and 3.94b1)
both 14/14 but 3.90.3 is (much) better
-lazka
But I don't know the status of that.
Reply #162
That opinion on quality can be biased, he ought to use HR program for quality comparison.
ruxvilti'a
Reply #163
Well, the test is almost upon us.
I already selected the switches for each encoder. This is what we will have:
-Lame 3.95 --preset 128
-FhG Audition VBR quality 40, only mid/side stereo enabled, Current - Best codec
-iTunes VBR Highest quality, 112kbps base bitrate, joint stereo, smart encoding
-AudioActive CBR 128kbps, high quality
-Gogo 3.12 -b 128 -a
-Xing 1.5 VBR quality normal
That list can be considered soft-frozen, it will only change if some major issue is brought to my attention.
Also, it is my pleasure to inform you that all VBR codecs are in the range of 120-128kbps. So, no issues should arise about bitrate deviation.
About why Xing instead of RealOne:
RealOne and RealPlayer10 beta are two flaming pieces of garbage that refuse to install on my PC. Surprisingly, the installation process goes well and at the end it claims installation succesful, down to the requirement of restarting the PC (#%$&@!). But when I check the installation folder (whether before or after restarting), it's nearly empty and, not surprisingly, double clicking the .exe has no effect.
Since I can't be bothered to deal with such shitty software for an anchor, and I also won't risk a friendship asking a friend to try installing it on his PC, I gave up RealOne altogether and went back to Xing 1.5, that installed and ran perfectly. Real should take some hints from XingTech...
I didn't replace any sample with fatboy because noone suggested what sample to replace. So this test will have no problem cases, except the very evil and very interesting Waiting.
Next test will definitely feature evil samples.
Also, I would like to thank Gabriel Bouvigne and the rest of the (active) Lame team for rushing the 3.95 release on time for this test.
The schedule is kept, if there's no catastrophe until then, it will start on the 14th, next wednesday.
Best regards;
Roberto.
Reply #164
I would have liked fatboy...
Why no setting up a poll for which sample to replace?
Reply #165
Because it's already too late. :/
When I asked about it (Jan 3rd) there was plenty of time. Now there are only two days.
Reply #166
What about LAME 3.90.3 <-> 3.95? Will that be "only" testing & tuning by those interested in it?
Reply #167
No 3.90.3 anymore. There are already too many codecs as it is.
And since 3.90.3 has already been tested a lot (128kbps extension and 64kbps test), I decided it would be better to try something newer this time.
Reply #168
As the samples are same in 64kbps test and this one,
we can compare 3.95 vs 3.90.3 indirectly.
ruxvilti'a
Reply #169
Erm.. actually, I prefer you don't even try to do that :B
In the 64kbps test Lame was the higher anchor, so it was meant to win. Comparing lame to 64kbps samples, it's obvious it'll receive high scores. OTOH, in this test Lame will be amongst it's peers, so it's score will probably be lower even if 3.95 isn't worse in reality.
An example. The exact same Lame version, compile and settings were used in the 64kbps test and the 128 extension test. Still, at the 128 test Lame got a score of 3.66 points, while in the 64kbps test it got a score of 4.29.
Regards;
Roberto.
Reply #170
Since Lame is using the optimal 128kbps setting (--preset 128), gogo might as well use -b 128 -a -q 0. Would you allow that?
Reply #171
No problem.
Thanks for the suggestion.
Reply #172
I'd like to point that with 3.95, targetting 128kbps I think that -q1 and -q0 can really improve encoding quality.
On the other hand, they might not be representative of real-world use due to their slowness.
Reply #173
is it possible to use this setting along with aps? How much longer would that take? I mean it says in the ChangeLog that the new release is 10% faster, so what's the deal? I rather wait a bit longer and have a smaller file or a file with better quality...
Reply #174
I think that this is off-topic and would lead to endless debates.
I was speaking about 128kbps.
