Topic: [USELESS] Open source discussion (Read 8310 times) previous topic - next topic
EDIT : this topic is split from http://www.hydrogenaudio.org/forums/index....howtopic=16131& /EDIT
To replace EAC ??  Why is this such a matter of principle not to use closed source software? Especially if it is freely available.
Edit: If you're looking for an open source ripper for improving it that would have been fine. You might even speak to Andre and you'll have access to code if you have such purposes. But as far as I could understand this is not the case. Then why do you need the source for? Why do you want to replace EAC with something strictly open source? This makes no sense. You're entitled to your way of thinking and purposes but HA is not a place of zealotry.
But just for the sake of replacing it with something open source? This makes no sense. You're entitled to your way of thinking and purposes but HA is not a place of zealotry.
I don't think he was being zealous at all. It's just a personal opinion and he is trying to get help without making any claims. On the contrary, "This makes no sense" is an unsuitable sentence IMHO
I too prefer using Free Software whenever I can. Does this make me a zealot ?? I don't think so. It's a philosophy that you may not understand, but others are free to think that way without being zealots...
Yatta!
Surely this won't make you a zealot ... but
1. EAC is practically free (but you are free to donate something like I did)
2. Not using closed-source software although it is proven to be the best available must have a reason ...
So perhaps Cey can tell us what his reasons are ...
The name was Plex The Ripper, not Jack The Ripper
@mlejeune : But EAC is already free!? I could understand such a philosophy if he provided any such arguments. For instance my philosophy is all intellectual property should be freely communicated (this does not mean open source). I'm very curious to hear the argument behind Cey's philosophy because it sounded as one of those open source zealots to me.
Yes I could as well be wrong, no offense.
I can see only one post here actually trying to help the user and answer what he asked.
Why abandon eac if it works for you? Open source isn't always better.
Ps. Cdparanoia isn't the default ripping method in cdex. You need to change the preferences if you want to use cdparanoia for ripping.
No, open source isn't always better.  There are many cases where closed source is better.
But, the way I see it, if open source is at least as good, then why not use it?
Sure, EAC is good.  But it's also under the control of one entity.  If they change their mind, then EAC disappears.
Also, EAC is one of those programs that is in perpetual beta.  Actually, for EAC, it seems to be more like in perpetual 'pre-beta'.  Sure, it works, but....  There just comes a time a program should go to a full release number.
And as I told rjamorim, I didn't even know cdex used cdparanoia but had assumed it used some home brewed method.  Thanks for telling me that it's not enabled by default, too.
Free for how long?  No, I'm not saying they plan on doing that, but it does happen on more than a few occasions.
I've even beta tested a number of programs that were supposed to be free but as soon as the beta testing was done, it was released commercially instead.
If an open source program is just as good, then why not use it?  Open source isn't inherently better, but it does have some advantages.
And no, I'm not planning on helping any coding work on some open source project.  My coding skills pretty much ended in the days of DOS.  I've never done any Windows coding at all.
And I don't need the source.  Just knowing that it is available is good enough.  Knowing that it exists in case the author gets killed in a car wreck or something is good to know.
Free for how long? (...)
Well, IIRC, EAC has been in beta/pre-beta stage for more than 4 years now, and I doesn't seem likely that it will go near final release anytime soon.
Also, EAC is already very famous and respected. I think that this would be the best time to start charging, don't you think?
This "they might charge someday" argument that Open Source "fans" always bring up doesn't seem to apply here.
The truth is that there are better free-closed-source programs than Open Source.
Believe me, I am following EAC's development for nearly all the time now and it is very close to some "release" status ... it cannot get much better than it gets with the next release
Yeah, I am also aware of the upcoming release.
But I was not talking about a "technical milestone", I was talking about a "regular" milestone. Cey said that sometimes when beta software reach a milestone release, usually 1.0, they start charging.
EAC is pre-beta as we all know, and it works better than a lot more software supposedly in much better stages of development. But normal people would not pay for a thing labeled "beta" or even "pre-beta". There is even people who would not use such a thing.
I meant to tell Cey that I don't see EAC reaching the 1.0 milestone anytime soon, regardless of any major developments.
BTW, since you are so aware of EAC's development, could you shed some light on the missing "Detect TOC Manually"? Is it gone forever? Or will it be back in an improved form in the next release?
I went to the EAC forum, but saw nothing about it.
EAC is famous and respected etc.  I haven't said or implied otherwise.
And they probably wont take it fully commercial.  Possibly shareware with a few limited features for non-paying customers, etc.  As I mentioned, I've had that happen with me before.  Both in stuff I've beta tested and in stuff that I had used for a while.  (ISOBuster springs to mind, but that's certainly not the only case.)
People and situations change.
But I'm not really worried about that.  I was *not* the one who brought up the subject of EAC being free etc.  I was just responding to what 'atici' said.
I think I've been reasonably clear, but maybe not.
1) If an open source project works just as well, then why not use it?  Just because something isn't famous doesn't mean it doesn't work.
2) I have said several times that being open source is not inherently any better or any worse than closed source.  Just because something is closed source doesn't mean it's bad and just because it's open source doesn't mean it's good.
But, if an open source project works just as well, then *why* not use it?
At least that way you get some assurance about development still being possible if the main developer wants to make money from it, or gets killed in a car crash, or just looses interest, etc.  There aren't any guarantees, of course, but at least with the source available there is a chance for development to continue, where as with closed source there is little chance.
In spite of what many in here are wanting, this sin't about open source vs. closed source.  So get over it.
I just feel that if an open source program works just as well as a closed one, and is actively developed, then why not use the open source program?
Look at cdex for example.  It's far more actively developed than EAC and is more responsive to bug fixes, user suggestions etc.  Is that inherent in OpenSource.... No.  But it is a case where an open source program happens to be a good and worth using.  So why not use it?  (Well, in this case because I didn't know CDEx had decent ripping abilities.  I thought it was just basic abilities like oh-so many other rippers.  I've never tested it with damaged cds.)
So far, the only two responses that have been at all helpful have been "rjamorin" for pointing out cdex did more than blindly ripping, and "Latexxx" for pointing out that the cdparanoia stuff wasn't enabled by default in cdex.
If you don't have something helpful to say, then, well, it isn't helpful.
I don't think there is anything as good as EAC.  Suggestion:
Use EAC until they cancel or start charging for it then look for a free alternative.
I remember people saying what you're saying 2-3 years ago, and EACs still free and available.  If we'd listened to them at the time, there'd just be that many more crappy rips floating around.  For all anyone knows EAC could be open sourced in the future or it could go commercial.
I didn't say or imply that when a program reaches the 1.0 milestone they start charging for it.  Thast does indeed happen on some occasions, but it also happens at other version numbers too.
I do tend to get tired of using perpetual alpha & beta software, though.
Again, I wasn't the one who brought that I should keep using EAC because it's free.
I didn't mention that at all until somebody brought up that subject of EAC being free and why in the world would I want to leave a free program, etc. etc.
(As I've pointed out, there are several reasons why development could stop.  Including the author getting killed or just losing interest, etc.)
Still, I do understand what you are saying about waiting to find another program until I need to.
There is some sense in that.
But I'd rather at least look around and see what exists.  I may chose to keep using EAC, but I'd still like to know what my alternatives are.
Amazing isn't it. All he did was ask if there was an open source cd ripper that was of similar quality as EAC. And what happens? He get's bombarded with questions about why he doesn't want to use EAC.
Who the hell cares what he uses? It's his business what he uses to rip CD's. He just asked if there was anything out there. Geeez....
Why does everybody think they need to tell everyone else what to use? If you have an answer, then offer it, if you don't, then go on to the next thread.
Edit: spelling
flac>fb2k>kernel streaming>audiophile 2496>magni>dt990 pro
Why are you so surprised?
It is only natural, IMHO, that is a person should ask something like that (going against forum "dogma") it is what he will get.
I don't buy the "it's his business" argument. Of course, he will end up using whatever he wants but when he asks for public opinion he should be prepared for different opinions.
If anybody here knows an open source ripper that has most of the featues of EAC (e.g. CUE sheet handling), and rips as reliably as EAC (drives that cache audio are particularly problematic) then I'd love to know it. But I haven't seen such a program yet.
Exactly.
@Cey:
I don't really see a point in worrying whether Andre Whiethoff will or will not break our hearts some day (he will) or will he be struck by a lightning bolt and leave us doomed to the world of lousy rips.
EAC's development will stop someday, that is for sure.
But, does it really keep you from "enjoying" it?
You say that you want to know about alternatives, but what for?
What alternatives do you need right know?
It sounds like yet another way to rationalize "excessive love" for Open Source.
And I know that it is not you who started this debate not is it the focus on this discussion, but I had to tell you that I think you are missing the point here.
If you are so worried about the viability of the future, why are you even ripping and encoding? ALL of the formats you mention are subject to the same fate. Even Vorbis, being Open Source has absolutely nothing to do with its development pace.
Exactly.
Well, I didn't know whether there were any good alternatives, which is why I asked.  See how simple that is...  And oddly enough, it does appear that cdex has better ripping than I though.  See how amazing that is...?  I learned something new by asking a question!
@Cey:
Actually I didn't say that.
But that is kind of the point.  If that happens, then development will stop and EAC will cease to work well for future cd's and drives.  It wont work well in the future, just for the past stuff.  As new drive designs come along, changes have to be made in EAC to keep up.  Same with some cd's.
Does my driving a car keep me from knowing about alternatives, such as pickup trucks or SUV's?  Knowing about alternatives is a pre-requisite for even the possibility of *DIS*liking those alternatives.
Before you can make a choice, you have to have alternatives.  Right now, there appears to only be EAC.  At least rjamorin told me that cdex can do some reasonable ripping, which gives me an alternative.
Well, considering you don't really know me, you aren't really in a position to make a statement like that.
Although I do like some of the ideas of open source, the reality is that most of the stuff I use is not open source.
BUT when a good, suitable open source alternative exists that I happen to like, then I don't see any point in continuing to use closed source, either.
*I'm* not the one worried about it.
I just asked a nice simple question:  Was there an open source alternative to EAC.
And as I've said before (in talking about cdex), no, being open source doesn't automatically mean that the development is better.  In cdex's case it is, but to use your OggVorbis example below, no development is nearly non-existant.  That isn't related to open vs. closed source.
What???
I don't remember mentioning *any* audio formats.
But yes, you are right... just because Ogg Vorbis is open souce has nothing to do with its development pace.  Or, rather, it's lack of pace.  To be honest, I generally use LAME rather than Vorbis.  And that has to do with its availablity and quality, not because its open source.
Perhaps this thread should be split into two parts?  One for discussion about open source rippers and a second one for a religious debate on open source vs. closed source.  I wont be visiting the second thread....
His original post didn't ask for an opinion. He asked if there were any open source CD rippers.
I agree completely. And that's why I disagree about all this bitching about his choice in rippers.
Quoting him:
I'm looking for open source cd rippers for Windows.
He never asked "which ripper you think is best" or something like that.
Sorry but that's BS. Who' bitching him to use EAC? I never mention myself using EAC anywhere.
I just don't understand the reasoning behind the desire to replace, as Cey puts it, (that means he is using it) EAC just because it's not open source. This just reminds me of a common form of zealotry these days.
Surely Cey can do whatever he wants, noone is forcing him to use a particular piece of software here but questioning his argument is sth. I feel I am entitled to do. A thunderbolt striking Andre is rather dubious, and I guess that's the best argument I could get
Why do you need to understand it? Was that a requirement? He aksed if there were any open source rippers. No for anybody to agree with his choices.
If there is any zealotry here, it is EAC zealotry. That's obvious.
Why do you need to understand it? Was that a requirement? No for anybody to agree with his choices.
That's what you think. I believe it behooves us all to correct/remind by counter-argumentation if any single person in the world takes sth. for granted without sufficient evidence or good argument on his part. Check out: William Clifford's Ethics of Belief
Pure BS. Go back and read what I said.
What gives you that right?
Besides, he didn't  use any argument at his first post. At all. He made a very simple question, and a bunch of people fell over him for deviating from the pattern.
