Topic: Confused by foo_dbsearch (Read 2504 times) previous topic - next topic
When i search the database using foo_dbsearch, how can i set the default action to simply send the file to the end of the current playlist?
Example
Install foo_utils, it provides the "Edit/Add to playlist" command. Older versions of foo_dbsearch directly contained this command, but seeing that it is a rather general command, I moved this and other similar commands to a new plugin - this is also for the people that do not want to use foo_dbsearch.
