Topic: .ape files corruption (Read 8572 times) previous topic - next topic
you forgot the quotes again:
E:\Musica\Album>sweep for %i in (*.flac) do e:\musica\album\flac -t "%i"
Josh
uh..i putted the quotes in the (*.flac) part...thank you for your help, now i will try this format.
it doesn't work, and i don't know why..the quotes are correct now but flac decoder can't open files.
E:\Musica\Album>sweep for %i in (*.flac) do e:\musica\album\flac -t "i%"
E:\Musica\Album\ZERO7-~1\SIMPLE~2>e:\musica\album\flac -t i%
flac 1.1.0, Copyright © 2000,2001,2002,2003 Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
i%: ERROR initializing decoder
    state = 2:FLAC__FILE_DECODER_ERROR_OPENING_FILE
my folder tree is like this:
e:
--musica
----------album
flac.exe
sweep.exe
-----------------album 001
01.flac
02.flac
-----------------album 002
01.flac
02.flac
01.flac
02.flac
-----------------album 004
and so on.
Make sure that you use "%i" and not "i%"
whoops  i'm going blind
Looks like Drago has sorted his problem now, but I thought I would add my .ape file corruption experience to this thread.
My audio server is a Athlon 900 with 256mb ram, Hitachi 120Gb drive, not overclocked, but I do use a home made fanless power supply which does not always give the most stable of outputs. This stays on permanently and I control what I listen to through my network.
I started to encounter occasional bitstream errors shortly after ripping most of my cd's. To check whether it was a problem with my audio server, I played the track back through a different PC and also copied the file to the PC and played it straight from the hard disk. With one or two tracks it played fine, but generally I would still encounter errors, so I deduced the file was corrupt.
I had slowly been creating a list of all the files with errors so I could have a big session to re-rip them.
However, a couple of days ago I was tidying the wiring up in my audio server and swapped the hard disk cable from a round one back to an 80 conductor flat ribbon.
Since then I have not encountered any new errors, and the previously 'corrupt' files all seem ok.
Whether this is due to a re-boot or the cable swap I am unsure, but I would be interested to hear if anyone else has encountered something similar.
Phill
