Topic: LAME 3.90.2 3.91 3.92 comparison tool? (Read 3709 times) previous topic - next topic
I was wondering if there is any tool that will allow me to compare vbr mp3s.
Why?
I have encoded an album (Sheryl Crow Globe Sessions) with LAME v3.90.2-IC (from here), v3.91, and v3.92 (both from Mitiok's page).
All the v3.91 and v3.90.2-IC mp3s have different bitrates and sizes when compared to their v3.92  twins.
For instance:
-F --alt-preset extreme, RazorLame 1.1.5
Track 10, v3.90.2-IC - 223kbps (winamp & EncSpot), 7.90MB
Track 10, v3.91 - 223kbps (winamp & EncSpot), 7.90MB
Track 10, v3.92 - 219kbps (winamp & EncSpot), 7.74MB
Track 04, v3.90.2-IC - 228kbps (winamp & EncSpot), 7.86MB
Track 04, v3.91 - 228kbps (winamp & EncSpot), 7.86MB
Track 04, v3.92 - 222kbps (winamp & EncSpot), 7.66MB
What I would like to do is find some tool that shows me vbr throughout the timeline of the songs, so I can see where the differences are and take a listen to those areas.
In addition can anyone suggest why they are different?  What changes to 3.92 would create these differences?  As I assume the Mitiok files used the same compiler(3.92 and 3.91)
Thanks for any assitance.
Jon
Encspot 2 pro would show this, but it's not free.
This issue has been under lots of discussion.. Differences emerge because of different compilers/compiler settings.
Juha Laaksonheimo
thanks.
Can it be assumed that because the number of higher bit rate frames are lessened in 3.92, it is inferior at encoding?  Or more efficient?
I took a look at the info for Track 4:
v3.92 -
128kbps 3%
160kbps 15%
192kbps 27%
224kbps 24%
256kbps 16%
320kbps 15%
avg bitrate 222
max reservoir 511
av reservoir 79
scalefac 16.2%
v3.91
128kbps 2%
160kbps 11%
192kbps 26%
224kbps 26%
256kbps 18%
320kbps 17%
avg bitrate 227
max reservoir 511
av reservoit 80
scalefac 17.3%
Lower the av reservoir the better correct?  I don't quite understand this, something about overflow....
Could you maybe explain reservoir, and scalefac(tor)?  Or point me in the right direction to find some info.
thanks!  just trying to get a better handle on this stuff.
Robert Hegemann (one of the LAME developers) told me that he changed some compile options for ICC (Intel C Compiler) in LAME 3.92. The quality of the MP3s is not affected by this.
Don't understand how the mp3 is "not affected" by a lower average bitrate.
Either making it better or worse...it has to affect it.
Ok, let me rephrase it... the quality should not be affected to a degree where it is audible.
Next time i talk to Robert, i'll ask him some more about this.
thanks.
