Topic: Matroska file format definition (Read 4138 times) previous topic - next topic
I've tried a couple times to make sense of the Matroska file format, as defined on www.matroska.org (which is down as I type this), but I honestly can't make sense of the scheme used to describe the file structure. I read through the documentation and tried comparing it to sample files I'd created, but I can't relate the two. I need to find out basic information such as bitrate, playtime, resoution, sample rate, codecs, etc.  Can someone walk me through how to find that information, please?
Those are very basic "What is Matroska? How do I play it" kind of guides. I couldn't find anything linked from there either.
Looking at the Matroska specs, I can see that all my sample files begin with [1A][45][DF][A3] as expected, but beyond that I'm lost. I can't relate the subsequent bytes to what I'm seeing in the specs. After those first 4 bytes, I see [93][42][82][88], then 'matroska', etc.
I guess what I'm looking for is either a guide for how to parse a Matroska file, or at least how to understand the specs as they're presented.
What's to figure out? It's communist!
j/k
Happiness - The agreeable sensation of contemplating the misery of others.
getID3(), you need to understand EBML first, before understanding Matroska.
EBML is like this : [ID][Length of Data][Data]
The Data can contain other EBML elements, or just an integer, a float, a string, etc.
The ID and the Length are coded like UTF-8. That means depending on the first bits of the ID/Length, you will have an ID/Length that span on 1,2,...,8 bytes (octets).
Once you understand that it's easy to see how Matroska works (I guess). The first element is a Level 0 element. And contains a list of other EBML element in its Data (this is called a Master element). All the elements contains other elements, that sometimes contain just valuable data (int, float, string, date, etc). That makes a hierarchy tree between the data. That's why it's close to the XML principles.
I hope it's a bit clearer now.
