Topic: foo_tunes (Read 76804 times) previous topic - next topic
foo_tunes
type: user interface
foobar version: 0.8.1
compenent version: 0.2
---- requires foobar2000 0.8.1 final
* minor fixes
* recompiled with SDK 0.8.1
* smaller size due to using GDI+ to handle images instead of extra library
foobar version: 0.8
compenent version: 0.1.2
---- requires foobar2000 0.8 final
* minor fixes
* added star system for rating (use e.g. quicktag plugin to rate songs)
foobar version: 0.8
compenent version: 0.1.1
* minor fixes
* optimized playlist drawing
* allowed format strings up to 2kB incl. newlines (not so comfortable, but it works)
* dimmed currently played song in playlist
* position and volume sliders moved to pane upon the playlist (more ergonomic)
* bass pulsing cool logo
* new buttons look (dark)
* double click in explorer view instanlty plays folder content
foobar version: 0.7.7b
compenent version: 0.1.0
* MILESTONE 0.1.0
* minor fixes
* better algorithm for sizing cover sheet images
* better looking (professional:) toolbar icons (old-style ones still in da package)
compenent version: 0.0.7 aplha
* minor fixes
* added background color of column
* stripes mode can be now turned off
compenent version: 0.0.6 aplha
* minor fixes
* flicking has been reduced on win2k
* synchro button on explorer toolbar/menu
* added configuration
   * playlist font
   * header on/off
   * hotkeys on/off
   * editable columns with any foobar string format
foo_tunes
download link is broken
it's due to forum upgrade, probably
foo_tunes
then when will that be over      cause the link is still not OK
foo_tunes
The forum upgrade was a while ago (and finished a while ago), some user uploaded files were lost (Avatars for example). The files uploaded to the upload forum were lost. So the link will remain broken until ne_me_sis appears and reuploads the plugin..
foo_tunes
it 's good
foo_tunes
Thanks mate! Will be better than the only version I've found so far (0.0.1...!)
foo_tunes
This is i download before.
thanks a lot
foo_tunes
The pause button doesn't work well.
foo_tunes
I absolutely LOVE foo tunes. brilliant.
Also, I'm new to this forum area...apologies if we aren't supposed to post bugs here. didn't know where else to go. I found 2 bug(ish) things, and one annoyance though:
1.Sending to New Playlists: if the window is a certain size (ie. fullscreen, or maybe just bigger than what it originally was, selecting of songs to send to a new playlist usually results in only one file being sent, and it isn't even in the selected group. I don't think it reproduces with the default ui.
2.The most wonderful awesome ability to drag playlist tabs (*THANK YOU*) kinda freaks out if you have more than one row of playlists.
3. There are some quirks to adding new fields with the built in id3 tag editing side bar. Such as adding new item, then typing anything ("Artist", "Title", ...anything)  and it will not save the changes immediately, or sometimes until you select a different song, then go back to the one that was being edited.
Keep up the FANTASTIC work. FooTunes is simply amazing.
The greatest trick the devil ever pulled was convincing the world he didn't exist.
 -The Usual Suspects
foo_tunes
   Great job. Now fb2k is the best player in the World!!!
foo_tunes
How do you activate foo tunes?  I've downloaded it and put it in the components directory, but can't figure out how to start it.  The .dll shows up in the components list.
TIA
I think that God in creating Man somewhat overestimated his ability.
- O. Wilde
foo_tunes
There is a dropdown list in your "display" option in preferences.
Just change it to footunes and restart foobar
foo_tunes
Thanks neoufo51!
- O. Wilde
