Topic: Bug report in FLAC playback? (Read 2560 times) previous topic - next topic
INFO (CORE) : opening file for playback :
INFO (CORE) : location: "file://D:\Documents\Music\Archival Quality Albums\BT - 2003 - Emotional Technology\06 - Dark Heart Dawning.flac" (0)
ERROR (CORE) : unknown error in main playback loop
ERROR (CORE) : Illegal operation:
Code: C0000005h, flags: 00000000h, address: 77F83905h
Access violation, operation: write, address: 95E29095h
Module: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlSizeHeap" (+000005EFh)
Additional info: playback_core main
Code bytes:
77F838E5h:  14 56 E8 4E 92 01 00 0F B7 06 29 43 28 80 65 14
77F838F5h:  00 57 53 E8 7C F6 FF FF 8B 47 08 8B 4F 0C 3B C1
77F83905h:  89 01 89 48 04 75 21 66 8B 07 66 3D 80 00 73 18
77F83915h:  0F B7 C8 8B C1 83 E1 07 B2 01 C1 E8 03 D2 E2 8D
Crash info dumped to failure_00000002.txt in your program directory.
If you are reading this, you should restart the program as soon as possible to avoid further trouble, and report this exact message to the developer.
It's a weird bug, because as soon as I tried starting the track again, there was no error. It's reproducable if I go back and forward in Shuffle mode, but in Default mode and I go between the two tracks that cause the crash, there's no bug. One's an MPC, the other is a FLAC. Okay... re-arranged the files, set it up exactly the way it was before, and no bug.
The bug happened between the end of one track and the beginning of the next.
Argh. Sorry. Gonna be a tricky one to debug, if it's even possible.
Looks like an issue with shuffle rather than with flac input.
