Topic: foo_infobox (Read 165760 times) previous topic - next topic
foo_infobox
Hmm,too many items in dialog
Thanks for this component /\/irana, it is a handy little extension to foobar2000.  However, I would have to agree with you here that the window is getting a bit busy.
Perhaps the Override Codepage, Change Focus, Follow Cursor and Prev & Next Mode boxes could be moved into their own page in the foobar2000 preferences dialog?  I would imagine most people would set these once and never need to see them again when they are actually using the infobox.
foo_infobox
I am having trouble with this new version.  When I try and unzip the file it says it does not appear to be a valid archive.  Is this just me or are other people having the same problem?
foo_infobox
Same issue here. With both v1.2.6 and v1.2.7.
foo_infobox
1. Unzip -> you'll get foo_infobox file (without extension).
2. add ".zip" extension to this file
3. unzip it again -> you'll get foo_infobox.dll file
foo_infobox
"Cannot Open File. Does not appear to be a valid archive" is the error I am getting.
There is nothing to unzip.
foo_infobox
damn
I check the files,it work here.
I zipped the files using winrar3.0,perhapes this cause the problem?
Now I don't have the winzip with my hand.I will reupload them as soon as possible.
Sorry
foo_infobox
Yup, It unzips with WinRAR just fine.
but WinZip is a no go.
foo_infobox
Reply #32
damn
Sorry
I checked it with "file" *nix utility: somehow you managed to do gzipped tar file instead of zip
foo_infobox
Just managed to crash infobox:
1. open info box, disable both "change focus" and "follow cursor"
2. remove all tracks from playlist (or change to "empty" tab)
3. enable "change focus"
4. try to enable "follow cursor" -> crash
Nothing big, since noone should use infobox on empty playlist, but the bug is there
foo_infobox
Reply #34
What I got was gzipped .zip file --- foo_infobox.zip.gz
Strange things are happening around here
Great plugin, though!
Life is Real...
(But not in audio :) )
foo_infobox
Reply #35
I don't know why
Reuploaded
zipped files using winzip2.8
It should be work this time
foo_infobox
Reply #36
fixed in v1.2.7.3
upload
foo_infobox
Reply #37
Then I suppose it is mod_gzip related problem, not /\/irana's mistake...
foo_infobox
Reply #38
hi, /\/irana:
could u make it replace the original menu item 'show file info...' or just hide it?
thx in advance
foo_infobox
Reply #39
You can remove the original yourself in Preferences -> Core -> Context Menu Items
foo_infobox
Reply #40
I will add a config page in the next version.
Let user could choose whether or not displaying that items
foo_infobox
Reply #41
Excellent.  Thank you.
foo_infobox
Reply #42
v1.2.7 uploaded
download link:foo_infobox.zip
I'm getting this:
What am I doing wrong?
foo_infobox
Reply #43
Redownload.
EDIT again: The server is gzip encoding it. (which makes it 15 bytes larger!)
HTTP response headers:
HTTP/1.0 200 OK
Date: Tue, 21 Oct 2003 11:08:38 GMT
Server: Apache
Last-Modified: Tue, 21 Oct 2003 10:15:29 GMT
Etag:
Accept-Ranges: bytes
Content-Type: application/x-zip-compressed
Vary: Accept-Encoding
Content-Encoding: gzip
Content-Length: 23097
Rename foo_infobox.zip to foo_infobox.zip.gz and hope your archive software understands ZIP inside of gzip archive.
foo_infobox
Reply #44
I don't have my own web server
I uploaded them to doc.hydrogenaudio.org
Perhaps that is the reason casusing the error
foo_infobox
Reply #45
Is there any reason to zip it?  The original non-zipped version seemed to download OK.  I wouldn't think people would find it too large to download at 41KB.
foo_infobox
Reply #46
Thanks. That worked!
foo_infobox
Reply #47
Register for hosting services? :B
foo_infobox
Reply #48
Temporary now
I don't want to do that also indeed
But before I found other beter place,it is the only way for me to update my plugin.
Hope Dibrom don't blame me
Ok,I uploaded new version dll,so people can download it here
And could somebody test this link?
That server seem unstable,and don't work for some IP,but you can try it.
Edit: could anybody report the new zip link whether or not work for you?
sorry for making so many trouble with downloading
foo_infobox
Reply #49
The first zip link worked fine for me (having a winrar)...
but this other doesn't seem to...
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe
