Topic: foo_infobox (Read 146301 times) previous topic - next topic
foo_infobox
I have written a small plugin for enhancing the fuction of show file info box.
Here is the screenshot
Edit1: copy the post on "Third-party plugins" thread
Component name - foo_infobox
Component type (appropriate section) - General
Which foobar2000 version the component works with - 0.7.1
Short description of the component - A substitute for the build-in file info box
Compile date - October 18, 2003
Download link - http://pelit.koillismaa.fi/plugins/general.php#8
Some explanation about "Override codepage" option:
If you check that option,then you can select any codepage installed in your system.foo_infobox will convert all meta tags from ANSI to UTF-8 using selected codepage,instead of using system default codepage.
It is useful for reading some tags not stroed in Unicode correctly.
Edit:updated download link to new version
foo_infobox
Now this is a worthy replacement...
Well done.
Edit: After playing around with this new box, I can honestly say that this should be the next official info box for Foobar2000. Seriously, you should contact Peter and have him take a look at this.  Flexible and very functional. The ONLY thing I would ask to make it perfect is to make it resizeable and keep its size over many uses.
foo_infobox
It's nice. Quite a bit more intuitive than the current one.
What do the options 'change focus' and 'follow cursor' do? Would they actually be relevant in the file info box?
Edit:
Answer: 'Change focus' synchronises the selected song in the playlist to the file displayed in the info box and 'Follow cursor' synchronises the file info box display to the song selected in the playlist. Yes, very relevant indeed.
foo_infobox
Some of my files give an error when opening the "special" window.
ERROR (CORE) : Illegal operation:
Code: C0000005h, flags: 00000000h, address: 77C336D0h
Access violation, operation: read, address: 00000000h
Module: "msvcrt", loaded at 77C00000h - 77C53000h
Symbol: "strcmp" (+00000010h)
Code bytes:
77C336B0h:  FD 5E 5F 5B C3 8D 42 FC 5E 5F 5B C3 CC CC CC CC
77C336C0h:  8B 54 24 04 8B 4C 24 08 F7 C2 03 00 00 00 75 3C
77C336D0h:  8B 02 3A 01 75 2E 0A C0 74 26 3A 61 01 75 25 0A
77C336E0h:  E4 74 1D C1 E8 10 3A 41 02 75 19 0A C0 74 11 3A
Crash info dumped to failure.txt in your program directory.
If you are reading this, you should restart the program as soon as possible to avoid further trouble, and report this exact message to the developer.
ERROR (CORE) : error executing menu command: "Show file info (special)"
Don't know what could be the difference, but these files can be opened in text mode by  Total Commander and give ASCII-DOS charset mode in default, while the "good" files are ANSI-Windows by default.  I don't see any other differences, not even in the tag types, APEv2 and ID3v1 are present only in these files.
I Use WinXP SP1 if it's important.
EDIT: OK, encountered some other files with ID3v2 tags, and they give the same error. Maybe the other files once had ID3v2, which got stripped, don't know.
BTW, I use kode54's plugin to read ID3v2 tags, no writing to them , though.
Life is Real...
(But not in audio :) )
foo_infobox
Slight problem with the group boxes. (image)
Stretch the tops of both boxes up by one point and all is well. :B
EDIT: Hmm, from a bit of tweaking, I end up with the final positions/sizes of 205x119 at 3,29 and 153x158 at 212,29. Or, in resource code, sort of:
CONTROL "Standard meta fields", -1, BUTTON, BS_GROUPBOX | WS_CHILD | WS_VISIBLE, 3, 29, 205, 119
CONTROL "Technical info", -1, BUTTON, BS_GROUPBOX | WS_CHILD | WS_VISIBLE, 212, 29, 153, 158
foo_infobox
@kode
Fixed and uploaded,thanks
@kalmark
I don't know what's the problem.In fact foo_infobox doesen't read tags from files directly.It load file info by querying the info from database,or asking database to reload info from file, then querying database
If you upload a file causing the error,I could look into it.
foo_infobox
Got the new dll, but its now saying that XP doesnt see if as a valid windows image.  It doesnt load at all now.
foo_infobox
this crash appeared (after approx a minute), when i installed infobox
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00000000h
Module: "foobar2000", loaded at 00400000h - 0044E000h
Additional info: menu_manager::run_command() / "Playback/Stop"
Version info:
foobar2000 v0.7.1
UNICODE
i thought: shit happens, but then in the next instance this happened
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 77F73905h
Access violation, operation: write, address: 00000001h
Module: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlSizeHeap" (+000005EFh)
Additional info: service creation failure
Code bytes:
77F738E5h:  14 56 E8 4E 92 01 00 0F B7 06 29 43 28 80 65 14
77F738F5h:  00 57 53 E8 7C F6 FF FF 8B 47 08 8B 4F 0C 3B C1
77F73905h:  89 01 89 48 04 75 21 66 8B 07 66 3D 80 00 73 18
77F73915h:  0F B7 C8 8B C1 83 E1 07 B2 01 C1 E8 03 D2 E2 8D
Version info:
foobar2000 v0.7.1
UNICODE
i deleted the plugins and everything runs smooth again. i can't reproduce anything so far, but i thought the error logs might help you somehow. they don't for me
foo_infobox
sorry:blink:
reuploaded,try again
foo_infobox
It seem there are many bugs in this plugin.
I haven't done many test.Now I don't have enough time to debug it and my code skill is very bad.
So try this plugin on your own risk.
foo_infobox
v1.2.4 uploaded
Just fixed a fool bug causing the crack
Please redownload the dll
foo_infobox
Is there any way to sort meta fields [other] by display name (alphabetic)? I have a lot of personnal field, and finding the good one is not very fast with the actual sorting (physical, I suppose) system.
foo_infobox
v1.2.5 uploaded,version num increase so fast
@kalmark and ilikedirtthe2nd
I think I have found what cause the problem before.
Please download new version,hope this had fixed the crash
@guruboolez
I can't open the image,damning proxy server
I have see what you mean.I suppose I could do this in the future,but not promise
foo_infobox
Small suggestion (but don't take this one in count if you don't find it useful for most people): a way to pop-up COMMENT field.
I've on some files a lot of informations, and the small defined box is too small for read them with comfort.
On some other files (opera for exemple), COMMENT field is heavily formatted, with tabs and large lines. For exemple :
                                  Mitridate, Re di Ponto
                                  Opera seria, K87/74a
         Libretto : Vittorio Amadeo Cigna-Santi, dalla tragedia di Jean Racine
Mitridate, re di Ponto........................................... Guiseppe Sabbatini
(King of Pontus – Roi du Pont)
Aspasia, promessa sposa di Mitridate............................. Natalie Dessay
(bethrothed to Mitridate – fiancée de Mithridate)
Sifare, figliuolo di Mitriate.................................... Cecilia Bartoli
(son of Mitridate – fils de Mithridate)
The small box of your nice component is just killing this formatting. Therefore, it would be nice for me to keep a way to pop-up some fields (at least the COMMENT one) with this component.
But don't feel obliged to do it: I can live with old tagging visualisation window, as long as foobar2000 will keep this last one.
foo_infobox
OK, crash fixed, thank you!
Great plugin, BTW, finally some way to use the infobox in an easy&stylish way!
Life is Real...
foo_infobox
V1.2.6 uploaded
Now it is resizeable.
@guruboolez
I have added a button for comment,click it will popup a detail dialog.Hope this will fit your needed.
foo_infobox
For me, it's perfect. Thank you very much.
There's maybe a better or simply complementary way to do it: add an option to allow the user to see ALL fields embedded in a file in "other meta" box. Therefore, if some people need to pop-up another common fields, they can do it.
But for my needs, your system is simply ingenious
Some questions:
what mean "change focus" and "follow cursor" ?
And what is "override codepage" intended for ?
foo_infobox
Some questions:
Change focus: choose if when you click on "previous" or "next" in the file info box, the cursor moves or not in the playlist.
Follow cursor: choose if the informations in the file info box must be updated when the cursor is moved to another track in the playlist.
foo_infobox
Merci very much
foo_infobox
quote from sld
Edit:
Edit:nyarlathotep faster
foo_infobox
v1.2.6.1 uploaded
No more change,only fixed the flicker when opening the dialog
foo_infobox
great plugin ..  i love it... i hope this replace the standard version
foo_infobox
Hmmmm... getting the "invalid windows XP image" crash again upon loading of foobar. Plugin won't load at all with 1.2.6.1.
INFO (CORE) : startup time: 4466 ms
ERROR (CORE) : Failed to load DLL: foo_infobox.dll, reason: Unable to load dll.
foo_infobox
Hmm...work well here
It's weird.I change nothing but one line about displaying the dialog.I think that code doesn't run when loading dll.
It seem only you have that problem.
Did all version can't be loaded,or only some of them?
I compressed the dll using upx.I don't know if this casue the problem.
I have uploaded a uncompressed dll.You can try it.
foo_infobox
v1.2.7 uploaded
download link:foo_infobox.dll
Add an dropdown listbox.Now you can choose how it work when clicking "previous" or "next' button,
save changes,don't save changes or popup a window prompting you
screenshot
If you didn't like new version,you can download v1.2.6 from here
