Topic: Low Bitrate OGG Encoding (8,16,32...) (Read 5665 times) previous topic - next topic
Hi There,
I'm very keen on embracing OGG as my streaming audio format of choice but one thing I'd love to see supported is modem bitrate encoding support.
No doubt this will be supported in the future... but is there any ETA on this? (I do hope I'm not lumbered with the "It's done when its done!!!!" response, perhaps a rough guess or its priority in development would be more useful)
Or, can you do this already with an encoder hack?
Ideally, I'd be interested in
- 32kbps Stereo (44.1khz ideally; 22.05khz hack would be ok)
- 20kbps Mono (Not sure how mono lies in Vorbis though...
I cant claim to understand the format completely from an encoding perspective... and I've read about and chatted in various rooms but hopefully someone around here can help.
I am new to this forum so have a little patience while I adjust to the etiquette
Cheers
Ruairi
rc55.com - nothing going on
You're going to have to resample to get bitrates that low at the moment, and probably in the future.
Vorbis handles mono input fine, but obviously can't do the channel coupling tricks that it can do with stereo... so you won't get half the bitrate by making the input mono.
Vorbis also handles sample rates other than 44.1/48, but isn't currently fully tuned for them.
The RC2 encoder has code for a 32kbps 22khz stereo mode, and a 48kbps 32khz stereo mode. I'm not sure about the mono modes.
I made a 32kbps 32kHz stereo mode once, but the results weren't very enjoyable.
GCP
How excellent to have someone who actually writes Vorbis here!
Regarding the 32kbit/s 22khz stereo mode... could you tell me the requirements of the source file?
I.e. Does it need to be saved as a 22.050 or can oggenc resample?
Does having a Windows .WAV header affect this?
Would the encoded bitstream be compatible with the Winamp plugin (if not any suggestions)?
And finally, what would the command line be?
Thanks for your help. If it does become useful I'll probably make a web page about it.
Cheers
Ruairi
Oggenc cannot resample, so you'll have to do it in advance with another program.
If there is no WAV header, you need to specify the format the file is in yourself (use oggenc -h to see how).
Yes. Anything that has an RC1 or later decoder can decode _any_ Vorbis 1.0 file.
oggenc -b 32 file.wav
GCP
Garf: Many thanks for your help!
Patchworks: I'll try them now, thanks!
Ruairi
