Topic: Lame Tag (Read 3893 times) previous topic - next topic
Lame Tag
I'm trying to figure out what all the information indicates that are stored within the Lame Tag and what the differences are. I already used google and the forum search, but all I could find was a post by JohnV, but he did not really explain the differences...so here we go again.
Quality: - seems to differ a lot, even in CBR files
Tag Revision:
VBR Method: What are the differences? It uses a different method when using one of the fast presets
Psycho-acoustic Model
Safe Joint Stereo - but why isn't there another field called 'Joint Stereo'?
- nogap (continued)
- nogap (continuation)
ATH Type
Noise Shaping some files use 1 others 2 etc. etc.
Lame Tag
I assume you've read through the LAME tag documentation?
http://gabriel.mp3-tech.org/mp3infotag.html
(No, I know it doesn't explain the different VBR methods etc but it's a start)
Thank you very much for your answer, getID3()! Yes, I’ve read through the LAME tag documentation. However, I still don't understand the differences. For instance the different values for "Noise Shaping" or the "ATH Type" or the "Quality" values (some file have 0 others 100) .
Lame Tag
As for the actual differences between the various noise shapings, ATHtypes, etc - I don't know any more than you
But the VBR Quality number, that I understand.  Xing (who invented the VBR header that LAME adapted into the LAME tag) had VBR Quality as part of their tag, but the scale wasn't documented as to what's 100% and what's 0% (I guess I could dig out some old Xing encoders and figure it out myself... maybe later ). So in the LAME tag, the quality has been defined as:
100 - ((VBR_q * 10) + quality)
So if you encode something as -V4 -q2 the stored quality would be
100 - ((4 * 10) + 2)
100 - 42
58
For CBR files, the quality value is useless as it's hardcoded to "58" for everything from 32kbps to 320kbps!
For presets, the quality number doesn't make a whole lot of sense either:
58 = insane (320 CBR)
67 = fm/radio/tape (112 CBR)
78 = hifi (160 CBR)
78 = [fast] standard (~192+ VBR)
78 = [fast] extreme (~224+ VBR)
88 = cd (192 CBR)
88 = r3mix (~192 VBR)
99 = studio (256 CBR)
So obviously the quality number is pretty much useless (320kbps is 70% worse than 256kbps?) (extreme is the same quality as 160CBR?)
In summary, disregard whatever this value has stored as any indication of quality - its only use is to derive what -V and -q settings were used for non-preset encodings.
Lame Tag
I don't think so! I have CBR 192 files that have Quality 60, others 55!
All my ABR files use 58. Very confusing
But thank you anyway
Lame Tag
Clarification: All CBR files encoded with the latest LAME v3.90.3 give a quality value of "58". Not that it means anything anyways
Lame Tag
Just for the record: this is not true. I found a file that has been encoded with LAME 3.92 and uses 60; another file encoded with LAME 3.93 shows 55.
Lame Tag
But he never said anything about 3.92 & 3.93, just 3.90.3...
Lame Tag
I'm curious where exactly the Lame header is.  Is it at the beginning of the file, the end, part of every frame?  If at the biginning or the end is it between any ID3v1 or v2 tags and the file itself?
I've also been wondering what the --nogap option is for.  It seems to be contradictory in that files made with the swich on play with more of a gap than without the switch.  It also seems to strip the Lame header and screw with the song length calculation.
Lame Tag
I have just encoded all possible CBR files (121 of 'em!) using 3.90.3, 3.91, 3.92 and 3.93.1 (earlier versions don't support the LAME tag) using both -b ??? and --alt-preset cbr ???.
Results: Every file comes out as VBR_Quality == 58, with the exception of -b ??? with LAME 3.91, which come out as 55.
@Jojo
I'd be quite interested in seeing these two files that you have (3.92 @ 60 and 3.93@ 55). Could you send me at least the first 1kB (so I can look at the LAMEtag frame and the first data frame(s)) of each, either to info@getid3.org or http://www.getid3.org/upload/ ?
Edit: <looks at sample files> You're right... those files do have values of 55, 60, even 88! Strange    Different compiles of LAME? Maybe DLL vs. EXE? I dunno...
Lame Tag
It's basically an extension of the Xing VBR header frame, which is the first valid MP3 data frame (although it doesn't contain any audio data). So it's located at the beginning of the file, after any ID3v2 tag that may be present and before the actual MP3 audio data. So your file could look like, with everything in place:
[ID3v2 tag]
[Xing/LAME or Fraunhofer VBR header frame]
MP3 audio data
[APE tag]
[Lyrics3 tag]
[ID3v1 tag]
