Topic: Subsection Formatting (Read 3167 times) previous topic - next topic
I've been doing some work on the fb2k faq wiki here and have added a sub-question in. Now, intuition tells me that a subsection should have text that's a little smaller or equal in size to the main section, but this subsection's both bigger and italicized. The italics mess it up because I'm using italics to denote the question as well as signifying that it is not as broad in scope as the other questions.
So, what should be done about this?
Well, changed things and switched over to using subsections and subsubsections to signify questions/subtopics, but that isn't much better; there's very little difference between them all!
Argh.
Problem is that there's no such thing as sub sections right now since <h1>, <h2> and <hX> are the same.
