Topic: AUPECg2 audio compression (Read 3869 times) previous topic - next topic
I found a very interseting codec here:
http://students.washington.edu/mvinton/
I've done some listening tests and the quaity at 128 is in most cases better than ogg or aac. At 96 (cut-off @ 18,5kHz!!!) it provides very good quality (most files). I've done the tests on various Vangelis tracks, which are very hard to encode.
I have a little problem with english, and I don't understand if this codec is being developed since 1998.
I downloaded and tested it on Fatboy.wav. 128kbps is really bad, worse than mp3. I haven't tried higher bitrates yet.
Edit: Now I tested it with higher 256kbps, still bad. Highest setting 392kbps was very good, but it had an annoying click in the beginning.
I tried it a while ago and it had clear artifacts at any bitrate. Should sound quite bad at lower bitrates since it lacks joint stereo modes.
The cutoff is a completely meaningless indicator of quality in itself.
But if you feel this is important, you'll be happy to know that the
next version of Ogg won't have a cutoff at all.
GCP
I tried this codec a few months ago and I have to say that the quality is horrible.  It's nowhere even close to being as good as aac or ogg.  If anything, the quality is similar to the Bink audio codec (which someone made similar claims about ).  Anyway, this codec artifacted quite heavily on any remotely difficult test clip I tried... it's not even as good as LAME.  I'd stear clear of it if I were you
I've also tried this long ago (it's not updated). Quality was very bad.. It's in essence just a demonstration codec. It's not seriously tweaked.
Juha Laaksonheimo
What I like of that codec is, it does handle Spahm.wav much better than AAC at 128kbps.
I wouldn't judge codec quality with fatboy.wav and spahm.wav,
You should try many other samples, and I am sure that you will find out that AAC is probably superior.
I am very busy these days so I can't check it by myself, but - one hint before making various claims:
- Are there any scientific papers regarding particular technologies used in the codec?
- Who are the scientists/developers that were researching these algorithms?
- Their background, previous work... all in all - scientific proof that they made an improvement.
Take a look at AAC for example (not because I am the "supporter" of the particular format, but because it is a very nice example)
- Inventors are biggest names in the audio coding industry (M. Bosi, K. Brandenburg, J. Herre, J. Johnston, H. Fuschs and many others) - working for biggest companies (AT&T, Dolby, FhG IIS, Nokia and Sony) and universities.
- It was developed during four years, with legacy of about 10 years of intensive R&D
- Many scientific papers with scientific proofs were written, as well as Ph.D's
- Many subjective tests were carried out with proof that it is good.
- It is a well-established worldwide ISO/MPEG standard
It is not easy to "invent" a good coding system - and it is very hard to tune one implementation to be state-of-the-art. And, verification of the quality is a very tough process.
