Topic: NeroEncode (Read 12638 times) previous topic - next topic
NeroEncode
NEncode is an utility that allow you to use Ahead' s AAC encoder via command line ( NEncode.exe <input.wav> <output.mp4> ) interface.
This installer contains only an executable file (EziiiEncode.exe): all Ahead' s DLLs (Aac.dll, aacenc32.dll, aacmp32.dll, NeroIPP.dll and wav.dll) will be copied from your Nero' s audio plugins folder, so you have to install a registred copy of Nero on your computer.
NEncode is wrote by Darp.
There' s a drag 'n' drop encoder derivated from NEncode' s code:
EziiiEncode
NeroVision Express required (version 2.0.1.15 raccomanded).
Installer and its script are wrote by DKDIB.
Visit NSIS download page to make your installers.
"In 18 anni non era mai servita a nessuno, ma qui posso aiutare e persino essere necessaria agli altri."
.hack//SIGN special - Intermezzo
NeroEncode
MSVCR71D.dll ERROR ???
NeroEncode
You have provided the source file!  Is it possible to compile this using M$ VC++ ???
NeroEncode
I don't suppose you can give me instructions on how to compile the source file in M$ VC++.  I keep getting errors, as I am very new to C++
NeroEncode
MSVCR71D.dll.. Isn't that the debug dll?
out of curiosity why didn't you make a Release compile?
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
NeroEncode
Yes, that is the debug DLL.
@DKDIB: I suggest you update your installer with the compile available at RareWares.
http://rarewares.hydrogenaudio.org/files/n.zip
It is compiled in release mode, without weird DLL dependencies.
NeroEncode
nencode.exe in n.zip is exactly the same as in installer
NeroEncode
I'm still having the MSVCR71d.dll problem, even with the n.zip hosted by rarewares.
Anybody knows why ? Does it work with your computer ? Without msvcr71d.dll ?
NeroEncode
NeroEncode
Does anyone know which compiler was used to compile the .cpp file to create the nencode.exe ???
NeroEncode
SWEET, now, how can i go about adding tags to the files ?
i'm using it with eac ...
NeroEncode
TAG don't support it yet, but foobars masstagger and replaygain are working well.
The files are also playable in winamp2 with in_mp4 and the tags work with winamp too.
NeroEncode
Oppps... I can' t remove this DLL so I was unable to determinate is it' s necessary or not.
Bug fixed.
NeroEncode
Bug fixed.
Thank you !
Now, it works !!!
NeroEncode
... but I have one flaw, why doesn't the artist, album, and track title not save to the MP4 file(s)?
I added NEncode into foo_clienc's presets, it will tag your files properly.
NeroEncode
Thank You case, as always excellent work
NeroEncode
I did nencode with Microsoft VS 2003 Enterprise Architect (VS7). I guess that any version of VS will do the job. I'm not sure about any other C++ compiler. There are a lot of COM interfaces and this will require some work.
For VS7 you can use this line to compile:
cl /D "WIN32" /D "_CONSOLE" /D "_AFXDLL" /EHsc /MD nencode.cpp
NeroEncode
Does it support encoding via pipes ?
if not, could some c++ savy member add it ?
NeroEncode
This installer contains a stand alone version of Ahead AAC encoder.
* Ahead AAC encoder (DLL files in program' s directory) based on Nero 6.0.0.15.
Visit www.nero.com to buy unlimited ver.
Hmm... installing this might answer the following questions, but I'm a little hesitant to do so without clarification of the following:
  1) Does this installer contain "limited" versions of the Nero AAC DLLs, or unlimited versions? (Wording of your original post seems to leave this slightly ambiguous....)
  2) If limited, what are the limitations?
  3) If unlimited, is this a legal distribution?
    - M.
NeroEncode
> unlimited versions?
The ver of Nero DLLs is unique (I downloaded them from www.nero.com): unlimited but provided with a file check.
AFAIK, if you haven' t "aacmp32.dll" in the same folder of AAC DLLs you can produce only 50 mp4.
If you' ve "aacmp32.dll" in AudioPlugins (directory used by Nero to store those kind of files) this installer copy it in NeroEncode' s folder.
NeroEncode
DKDIB:
what about pipes ?
can you fix so they work ?
NeroEncode
DKDIB:
what about pipes ?
I doubt pipes can be implemented. This .exe is only sending commands to the DLLs, reading through command line pipes would need to be performed by the WAV DLL.
NeroEncode
Treech wrote:
> what about pipes ?
Sorry, but I can' t do anything about that: I' m not the author of this program.
* Executable file and its source wrote by Darp.
Visit this topic for more information.
NeroEncode
DKDIB:
what about pipes ?
Can you please tell me most about this wav.dll:
what it does
how it works
etc
