Topic: Library to manage tags of all audio format (Read 1736 times) previous topic - next topic
I'm developing an intersting free software to manage the tags of all kind of audio files.
Now I'm using ATL library, from Jurgen Faul, but I'd like to know if exist other library to do this (I use Borland C++ 5.0) or if I can use dll of foobar2000 0.677 to read/write tags.
Where can I ask to have a tech support about this?
Thank you
The ID3v1 and APEv2 tag reading and writing code can be found in the SDK, which is available under the BSD license.
EDIT: In case you miss it, the code is in tagread_i.cpp, inside the foo_input_std directory.
