Topic: 0.6 to 0.7 questions (Read 8037 times) previous topic - next topic
First I'm never calling wsclen directly - the call was being made by std::string which is used in one of my libraries.
Use string8, which is part of PFC. :B
So, the final cause of the problem - a single missing _T() wrapper around one string constant in my code.  Like Z^7 said, apparently tolerated in .6.
You shouldn't need _T() or UNICODE, as you are now using utf8api and all string constants should be UTF-8.
I wish it were so simple
I have reuseable code in this project that I wrote for other projects and is used in all sorts of different applications and environments.  Therefore, I can't use foobar's string implementation exclusively.
I have a mix of std::string from shared code and foobar's string stuff.
are their analogs for the following v6 play_control enums in v7 - I don't see them.
FOOBAR2000_ALWAYSONTOP
FOOBAR2000_CONFIG,
FOOBAR2000_EXIT,
Edit
Also for hide/show etc. I'm doing this:
user_interface::g_find("Default User Interface")->activate();
How can I make this generic for whichever UI is currently active?
/Edit
FOOBAR2000_CONFIG,
look into play_control.h:
play_control::g_show_config(page_name)
HI  all,
does anyone know why, the new version of foobar0.7 has so many dll errors when someone is trying to play mp3's.
is there any solution to this. thanx in advance .
Reply #30
FOOBAR2000_EXIT,
See all of the menu items/actions on the main and context menu sections in the config?
menu_manager::run_command()
ie. menu_manager::run_command("Foobar2000/Titleformatting help") for a "help" button you can place on any dialog that features a title formatting editor.
FOOBAR2000_EXIT,
Ah, that's cool - thanks.
