0.6 to 0.7 questions Reply #25 – 2003-09-05 01:11:21 QuoteFirst I'm never calling wsclen directly - the call was being made by std::string which is used in one of my libraries.Use string8, which is part of PFC. :BQuoteSo, the final cause of the problem - a single missing _T() wrapper around one string constant in my code. Like Z^7 said, apparently tolerated in .6.You shouldn't need _T() or UNICODE, as you are now using utf8api and all string constants should be UTF-8. Last Edit: 2003-09-05 01:14:17 by kode54
0.6 to 0.7 questions Reply #26 – 2003-09-05 15:49:48 QuoteQuoteFirst I'm never calling wsclen directly - the call was being made by std::string which is used in one of my libraries.Use string8, which is part of PFC. :BQuoteSo, the final cause of the problem - a single missing _T() wrapper around one string constant in my code. Like Z^7 said, apparently tolerated in .6.You shouldn't need _T() or UNICODE, as you are now using utf8api and all string constants should be UTF-8. I wish it were so simple I have reuseable code in this project that I wrote for other projects and is used in all sorts of different applications and environments. Therefore, I can't use foobar's string implementation exclusively.I have a mix of std::string from shared code and foobar's string stuff.
0.6 to 0.7 questions Reply #27 – 2003-09-05 17:01:33 are their analogs for the following v6 play_control enums in v7 - I don't see them.FOOBAR2000_ALWAYSONTOPFOOBAR2000_CONFIG,FOOBAR2000_EXIT,EditAlso for hide/show etc. I'm doing this:user_interface::g_find("Default User Interface")->activate();How can I make this generic for whichever UI is currently active?/Edit Last Edit: 2003-09-05 17:13:10 by danZ
0.6 to 0.7 questions Reply #28 – 2003-09-05 17:39:03 QuoteFOOBAR2000_CONFIG,look into play_control.h:Code: [Select]play_control::g_show_config(page_name)
0.6 to 0.7 questions Reply #29 – 2003-09-05 20:26:25 HI all,does anyone know why, the new version of foobar0.7 has so many dll errors when someone is trying to play mp3's.is there any solution to this. thanx in advance .
0.6 to 0.7 questions Reply #30 – 2003-09-05 20:28:47 QuoteFOOBAR2000_ALWAYSONTOPFOOBAR2000_EXIT,See all of the menu items/actions on the main and context menu sections in the config?menu_manager::run_command()ie. menu_manager::run_command("Foobar2000/Titleformatting help") for a "help" button you can place on any dialog that features a title formatting editor.
0.6 to 0.7 questions Reply #31 – 2003-09-05 20:46:56 QuoteQuote FOOBAR2000_ALWAYSONTOPFOOBAR2000_EXIT,See all of the menu items/actions on the main and context menu sections in the config?menu_manager::run_command()ie. menu_manager::run_command("Foobar2000/Titleformatting help") for a "help" button you can place on any dialog that features a title formatting editor. Ah, that's cool - thanks.
