Topic: [Feature REQ] ASCII buttons - comeback? (Read 2907 times) previous topic - next topic
Hello
I have some question about those Nice looking ASCII buttons in foobar.
For all of us, foobar users this program is simple, small, powerfull
not just like other toys with lots of colors, skins etc.
So, it is possible to bring back those nice looking ASCII buttons (play, pause, stop etc.)
as an option to choose between gfx/ascii ofcourse
Nice idea. I`m asking for this too.
Hello
Search for foo_ui_notepad, it is an interface plugin for 0.7 that gives it the old interface.
Yeah, I miss them too! And while we┬┤re at it, a further text display in the menu line indicating "order" and that @!#* "follow cursor"-status (as a toggle?) would be too great! Otherwise Foobie just got perfect with Tabs and foo_syfm!!!!
Hi
Interface plugin is not a final solution if you can still turn on/off seekbar and other new options. Nice idea is to add some switch "Turn on/off classic look"
After all can you give me some url with that plugin you have mentioned?
foo_ui_notepad, i will test it
Thanks in advance
I like the ASCII buttons too
EDIT: Transparency don't work in foo_ui_notepad
I think that our topic may be closed, in 0.7RC8 release ASCII buttons are back and kicking.
i would like to thank Peter Pawlowski for this option
I don't see them in RC8 is there a way to enable them in it ?
By using your eyes ??
(Prefs/display/default user interface/show ascii buttons).
Be sure to be using the standard menu though.
Preferences - Default User Interface - the bottom checkbox in the column on the left
