Topic: Global gain, scale factors, signal, quantization (Read 4054 times) previous topic - next topic
This could belong to both mp3 and aac forums, so I am asking here.
My question is about how to quantize (and dequantize) the signal. I have some doubts regarding how factors are interacting with each others.
*global gain and scalefactors:
How is the scaling done?
Is the scaling done by (global gain * scalefactor) or by (global gain - scalefactor)?
*scaling:
What is scaled, signal or quantizer step size?
It should be:
actual_local_sf = global_gain - stored_local_sf;
Where - actual local sf would be an actual scaling factor for the particual band, and stored_local_sf would be a value stored in the encoded bitstream.
*scaling:
During encoding, MDCT floating-point signal is scaled according to the quantizer step size, and the scaled representation is quantized (converted to integer domain).
I think that I am still missing a part:
let's call ix the mdct output signal (floating point), do we quantize:
actual_local_sf * ix  ? (of course actual_local_sf is varying between sf bands)
do for every frequency coef w:
  QuantSignal[w] = NINT( pow( ix[w] / actual_local_sf, 0.75 ) - 0.0946 )
Where:
int QuantSignal[w]  --> integerized, quantized value of spectrum
float ix[w] --> input MDCT signal, floating point
actual_local_sf --> global_gain - scale_factor[sfb]
Thank you very much for those clarifications Ivan.
Ah, yes - I forgot
So, it can be seen that if you increase scale_factor[sb],  the actual_local_sf value will be decreased (actual_local_sf = global_gain - scale_factor[sb]), and the quantized signal will be amplified - and therefore closer to the original MDCT signal.
That's why in the loop iteration process, the distorted bands get amplified and re-checked for distortion.
Language is strange sometimes.
It seems to me that by increasing the scale_factor (so decreasing the global scale value) the signal is not really amplified but less devided.
Overall it is equivalent, but still strange.
(I was asking those clarifications because I was wondering about the sfb21 strangeness)
Well, it is a power-law quantizer,  in reality it is really an amplification - and in the same time the deviation gets smaller
