Global gain, scale factors, signal, quantization 2003-08-26 11:01:47 This could belong to both mp3 and aac forums, so I am asking here.My question is about how to quantize (and dequantize) the signal. I have some doubts regarding how factors are interacting with each others.*global gain and scalefactors:How is the scaling done?Is the scaling done by (global gain * scalefactor) or by (global gain - scalefactor)?*scaling:What is scaled, signal or quantizer step size?
Global gain, scale factors, signal, quantization Reply #1 – 2003-08-26 11:40:47 Quote*global gain and scalefactors:How is the scaling done?Is the scaling done by (global gain * scalefactor) or by (global gain - scalefactor)?It should be:actual_local_sf = global_gain - stored_local_sf;Where - actual local sf would be an actual scaling factor for the particual band, and stored_local_sf would be a value stored in the encoded bitstream.Quote*scaling:What is scaled, signal or quantizer step size?During encoding, MDCT floating-point signal is scaled according to the quantizer step size, and the scaled representation is quantized (converted to integer domain).
Global gain, scale factors, signal, quantization Reply #2 – 2003-08-26 11:56:12 I think that I am still missing a part:let's call ix the mdct output signal (floating point), do we quantize:actual_local_sf * ix ? (of course actual_local_sf is varying between sf bands)
Global gain, scale factors, signal, quantization Reply #3 – 2003-08-26 13:17:59 QuoteI think that I am still missing a part:let's call ix the mdct output signal (floating point), do we quantize:actual_local_sf * ix ? (of course actual_local_sf is varying between sf bands)do for every frequency coef w: QuantSignal[w] = NINT( pow( ix[w] / actual_local_sf, 0.75 ) - 0.0946 )Where:int QuantSignal[w] --> integerized, quantized value of spectrumfloat ix[w] --> input MDCT signal, floating pointactual_local_sf --> global_gain - scale_factor[sfb]
Global gain, scale factors, signal, quantization Reply #4 – 2003-08-26 13:31:46 Thank you very much for those clarifications Ivan.
Global gain, scale factors, signal, quantization Reply #5 – 2003-08-26 14:07:53 QuoteQuantSignal[w] = NINT( pow( ix[w] / actual_local_sf, 0.75 ) - 0.0946 )Ah, yes - I forgot So, it can be seen that if you increase scale_factor[sb], the actual_local_sf value will be decreased (actual_local_sf = global_gain - scale_factor[sb]), and the quantized signal will be amplified - and therefore closer to the original MDCT signal.That's why in the loop iteration process, the distorted bands get amplified and re-checked for distortion. Last Edit: 2003-08-26 14:10:26 by Ivan Dimkovic
Global gain, scale factors, signal, quantization Reply #6 – 2003-08-26 14:47:32 Language is strange sometimes.It seems to me that by increasing the scale_factor (so decreasing the global scale value) the signal is not really amplified but less devided.Overall it is equivalent, but still strange.(I was asking those clarifications because I was wondering about the sfb21 strangeness)
Global gain, scale factors, signal, quantization Reply #7 – 2003-08-26 15:04:52 QuoteIt seems to me that by increasing the scale_factor (so decreasing the global scale value) the signal is not really amplified but less devided.Overall it is equivalent, but still strange.Well, it is a power-law quantizer, in reality it is really an amplification - and in the same time the deviation gets smaller
