Topic: Is there a way to let foobar2k show the total of a playlist, in megabytes? (Read 380 times) previous topic - next topic
I want the total, if possible, and not for single items.
Curls
Re: Is there a way to let foobar2k show the total of a playlist, in megabytes?
The built in Playlist Manager does this. You can open a popup window via the View menu or add it as a Default UI element in layout editing mode. Note that the Total size column is not enabled by default - you have to right click the column header for that.
Thank you!
