Topic: Foobar 2.1 DSP Switcher Toolbar Bug (Read 536 times) previous topic - next topic
Hi. Foobar 2.1 has a bug in displaying DSP Switcher Toolbar.
The Title "DSP" is displayed a few pixels higher than main menu text.
The name of DSP preset "Pure Direct" is displayed a few pixels lower than main menu text.
Default font size in settings is 10pt in this screenshot, but its getting even worse if font is lagrer.
Re: Foobar 2.1 DSP Switcher Toolbar Bug
No, it's not fixed.
"DSP" font also is smaller, doesn't change to 11pt size  as set in Preferencies and is few pixels higher.
The name of DSP preset font has font 11pt as set in Preferencies, but it is few pixels lower than it should be.
Please set a font to size 11pt in "Preferencies - Display -Default User Interface - Colors and Fonts - Default" and make a screenshot once again to confirm.
The toolbar titles seem to be fixed font size, was the same with version 1.6 already (Windows Standard Fontsizes?); font size and alignment of the presets are working for me:
"DSP" is few pixels higher than main menu text.
"DSP" font is smaller than main menu.
The name of DSP preset "Pure Direct" is one pixel lower than main menu text.
Outline of the DSP preset selection box is croped at the bottom
"DSP" itselt can't be changed, this seems to be Standard Windows Menu font - if you open a Foobar Menu, you should see the same font and size.
Can't reproduce the 1 pixel shift you have, everything's perfectly aligned with me - already tried to to reset the toolbar?
I've made my screenshots with default font Segoe UI Standard 10pt. Try to set 10pt
I use foobar on Windows 7 and 8.1. Both have this issue.
I reset toolbar as you suggested.
With font 9pt bold there is pixel shift of all Toolbar names and Preset names. The font of all Toolbars is not bold. All other fonts are bold
With font 9pt Standard there is 1pixel shift of all Toolbar Names (DSP, Order, Output)
So i would ask Peter to fix it if it's possible:
1. Align Toolbar Names and Selections (DSP, Order, Output) inline with Main menu text
2. Change the font and font size of Toolbar Names (DSP, Order, Output) the same as the default font in Preferencies
