Topic: Flex DSP (Read 1755 times) previous topic - next topic
Flex DSP
Switch DSP based on track metadata.
This component starts independent development on Dynamic DSP v2.1.1.3.
Flex DSP v1.0
What new:
- Added option to log DSP updates.
Fixes:
- Unrecoverable error: 6 channel/DSP updates in exclusive mode.
- Multi-line chain configuration dialog labels.
- Nested chain configuration dialog crash.
Importing Dynamic DSP (v2.1.1.3) chain definitions:
- Open Dynamic DSP, enable 'Export setup on exit' and click OK.
- Copy/rename <profile>/configuration/foo_dynamicdsp.exp foo_flex_dsp.exp.
- Imported settings will be used as default by the first Flex DSP instance added to the active DSPs.
Note: Imports only from the Active DSP root and secondary groups.
Re: Flex DSP
Flex DSP v1.0
What new:
Fixes:
hi
i'm using this amazing plugin!
but can i ask you which version is the last ?
Flex DSP or Dynamic DSP ?
just because i have installed both
should we post here any feedbacks
thanks
Re: Flex DSP
Flex DSP v1.0
What new:
Fixes:
hi
thanks
@francesco, I also enjoy using this plugin. This version is current Flex DSP v1.0.
I think @da yuyu created this thread also to post feedback from users here.
Re: Flex DSP
@Sergey77  @da yuyu
hi
I would like to know if Flex Dsp can enable/disable replaygain and set replagay to album or artist and vice versa , i would like too
about disble and enable replaygain Playlist Attributes (foo_playlist_attributes) can do it but there are some bugs
and i can not find any information how to disable "ReplayGain scanner mode with DSP enabled" outside hide from the context menu
thanks
Re: Flex DSP
hi
i have created a foobar2000 script to add tags items like TRACKDSP and TRACK_FLEXDSP , it could be done with lots of albums in 1 click
so it's pretty easy to add an value like EqLowHigh , or Eqbalance
I think could be a good idea,what do you think?
thanks
Re: Flex DSP
Bug report: it doesn't seem to work with the youtube source plugin.  I have no idea why, but if you need any more info let me know.  Thank you!
