Topic: Pre-Test thread (Read 57706 times) previous topic - next topic
Pre-Test thread
Reply #75
i would hate to see you choose ahead just because its the latest to throw its hat in the ring to the exclusion of qt -- which was i think a surprise in the last two tests, the first for winning outright and the second for placing 2d with cbr. on that basis i would assume it merits inclusion without comment.
Well, I would be interested in Ahead's AAC, BECAUSE it is new and BECAUSE QT was tested and found to be realy good. I would like to see how Ahead fares at 64kpps, so you could roughly compare the two (though this is not realy valid, given the bitrate difference).
I also think that there is a growing userbase for Aheads implementation of the codec, so let's give it a try.
however, if you personally abx qt vs. ahead and conclude that ahead shows more promise, i for one would not object to you kicking qt out. fwiw
I thought is wasn't about chosing the best codecs out of the bunch, but more to include some well known ones... or am I getting something wrong here?!
edit: damn, Rjamorim has smuggeld a post in before mine...
Nothing but a Heartache - Since I found my Baby ;)
Pre-Test thread
Reply #76
My tests were *always*about*quality*
Other features like price, support, license, popularity, etc.  come far behind.
Well, nothing has been decided so far
Pre-Test thread
Reply #77
For mp3-64m I think that blade would be less interesting, as it does not reflect a real usage.
Lame or FhG would be more interesting.
Using FhG is an interesting suggestion if we consider that it is claimed to be the best mp3 codec in this bitrate area. (btw I am wondering how much better than Lame it really is)
Pre-Test thread
Reply #78
I don't take listening tests. But if someone wants to test Ahead 64 vs. QT 64, the results would be very welcome.
I'm interested. To keep it lean some questions to AAC experts here:
Quicktime 6.3:
- Is it a good idea to resample to 32kHz at 64kbps
Ahead AAC (Using NeroMix 1.4.0.4):
- Should PNS be enabled at 64kbps or not?
- Using VBR is recommendable - correct?
- Any settings/hidden preferences/etc. I could have missed?
Thanks in advance.
If anyone's interested I can upload the encoded mp4 samples.
__________________
What about lame --alt-preset 64 vs. fhg? I'm curious about this too. Is there a better fhg encoder for that bitrate than Cool Edit Pro 2.1's?
Pre-Test thread
Reply #79
Well, all I know are claims that FhG is better at 64 because it supports IS, and LAME doesn't.
Anybody caring to perform a quick test Lame vs. FhG?
Pre-Test thread
Reply #80
I don't think it would be. That's definitely preprocessing, and it's bias favourable to QuickTime.
If we resample for one of the codecs, we must resample for all of them.
No. The only reason LC is being included is because it's popular and has hardware support. If we enable PNS, both reasons become moot.
Yes, probably the Tape preset.
Probably not.
I think, traditionally, CoolEdit and Musicmatch always use the latest FhG versions.
So, both should be OK.
Now, it's worth wondering what codec will output the best quality
"Current - Best Quality" or "Legacy - High Quality (Slow)"
Regards;
Roberto.
Pre-Test thread
Reply #81
I'll do a test with ABC/HR on few of samples from this test.
(FhG HQ vs FhG Current vs Lame -ap 64)
ruxvilti'a
Pre-Test thread
Reply #82
I think you'll have to try Quality 1 with FhG in Audition. The lowest preset (10) is announced as 80-95kbps, which is too high for the test.
If even 1 is too high, I might have to go with CBR 64.
BTW, I would like to use that obscuring BAT file you made for the 128 test. Is it OK?
Sorry about not using it on the 128test, but I have a policy of not changing the test unless it's absolutely necessary. Else, some people might believe the results they already submitted were invalid, and that definitely wouldn't be the case.
Regards;
Roberto.
Pre-Test thread
Reply #83
Que? I would assume that any good codec would resample internally when it is appropriate. You're not saying that you will force the codecs to use 44.1 kHz, are you? For one it wouldn't reflect real world usage to force codecs to use a specific sample rate. Normally you would leave that decision to the encoder...
Pre-Test thread
Reply #84
Sure, sure. What I said:
"If we resample for one of the codecs..."
So, I won't resample samples before feeding them to their codecs. But if the codecs do that, it's their business.
Besides, I don't think that a codec resampling is preprocessing. It's just another step in the codec compression flow.
Pre-Test thread
Reply #85
Rjamorim,
you are hereby granted the rights to use my obscured-batch-file-test-method.
Consider it as BSDv2 licensed.
Quality 1 produces too large files, unfortunately.
I have prepared the files and will take the test right now.
ruxvilti'a
Pre-Test thread
Reply #86
ABC/HR 0.9b doesn't save the results when I try to setup a new test.
I get a blank results file with the title of the new test!
I had to do the test twice (except Waiting) because of the bug.
Does anybody have a working link to Friedman?
Results:
ABC/HR Version 0.9b, 30 August 2002
Testname: Waiting MP3@64k
1R = D:\test\L-Waiting.wav
2L = D:\test\FH-Waiting.wav
3L = D:\test\FC-Waiting.wav
General Comments:
1R File: D:\test\L-Waiting.wav
1R Rating: 1.5
1R Comment: Major ringing, slight dropouts
2L File: D:\test\FH-Waiting.wav
2L Rating: 2.0
2L Comment: Underwater
3L File: D:\test\FC-Waiting.wav
3L Rating: 1.7
3L Comment: Bad ringing
ABX Results:
Testname: Big Yellow Taxi MP3@64k
1L = D:\test\FH-bigye.wav
2L = D:\test\FC-bigye.wav
3R = D:\test\L-bigye.wav
General Comments:
1L File: D:\test\FH-bigye.wav
1L Rating: 3.0
1L Comment: Not bad, except slight underwatery quality and lowpass
2L File: D:\test\FC-bigye.wav
2L Rating: 2.5
2L Comment: Less lowpass than 1, but more artifacts
3R File: D:\test\L-bigye.wav
3R Rating: 1.5
3R Comment: Dropouts in guitar + tons of other
ABX Results:
Testname: Gone MP3@64k
1R = D:\test\L-gone.wav
2L = D:\test\FC-gone.wav
3L = D:\test\FH-gone.wav
General Comments:
1R File: D:\test\L-gone.wav
1R Rating: 1.0
1R Comment: Bad dropouts  and ringing
2L File: D:\test\FC-gone.wav
2L Rating: 1.4
2L Comment:
3L File: D:\test\FH-gone.wav
3L Rating: 1.3
3L Comment: Less ringing than 2, but too much lowpass
ABX Results:
Testname: Polonaise MP3@64k
1R = D:\test\FC-ChopinPolonaiseDMoll.wav
2L = D:\test\FH-ChopinPolonaiseDMoll.wav
3R = D:\test\L-ChopinPolonaiseDMoll.wav
General Comments:
1R File: D:\test\FC-ChopinPolonaiseDMoll.wav
1R Rating: 2.5
1R Comment: Slightly more ringing than 2
2L File: D:\test\FH-ChopinPolonaiseDMoll.wav
2L Rating: 3.0
2L Comment:
3R File: D:\test\L-ChopinPolonaiseDMoll.wav
3R Rating: 1.0
3R Comment: Totally destroyed - sounds flangy, tons of dropouts
ABX Results:
Testname: Experiencia MP3@64k
1L = D:\test\FC-experiencia.wav
2R = D:\test\FH-experiencia.wav
3L = D:\test\L-experiencia.wav
General Comments:
1L File: D:\test\FC-experiencia.wav
1L Rating: 2.5
1L Comment: Slightly less ringing than 3
2R File: D:\test\FH-experiencia.wav
2R Rating: 3.5
2R Comment: Sounds very good for 64k
3L File: D:\test\L-experiencia.wav
3L Rating: 2.3
3L Comment: Ringing
ABX Results:
/EDIT\ Cleanup and modifiaction - results same \EDIT/
ruxvilti'a
Pre-Test thread
Reply #88
Don't forget to enable all additional options (like narrowing of stereo image) and disable CRC generation.
/EDIT\
Additional information about my micro-test:
- all samples were decoded with Foobar2000 0.7RC7 without replaygain to 16bit and dithered
- encoded with LAME 3.90.3 --alt-preset 64 and Adobe Audition 1.0 without CRC and with all stereo options enabled.
\EDIT/
ruxvilti'a
Pre-Test thread
Reply #89
Quicktime has a switch to choose sampling rate - as lame (22.05kHz sampling rate is integrated in --preset 64). So it'd be fair to choose the best sounding encoding setting.
Pre-Test thread
Reply #90
Results
Settings used:
<samplename>_CEP_dev.wav
CEP2.1 fhg mp3 encoder
64kbps CBR, HQ, 22050Hz Samplingrate, default lowpass (10349Hz), m/s, intensity stereo, narrowing enabled.
<samplename>_CEP_LP11.wav
64kbps CBR, HQ, 22050Hz Samplingrate, lowpass 11025 Hz, m/s, intensity stereo, narrowing enabled.
<samplename>.wav.wav
lame 3.90.3
--preset 64
<samplename>_qt_44.wav
Quicktime Pro 6.3. AAC
64kbps CBR, Audio Track: "Music"; Stereo; Best Quality; Sample rate 44100Hz
<samplename>_qt_32.wav
64kbps CBR, Audio Track: "Music"; Stereo; Best Quality; Sample rate 32000Hz
<samplename>_Nero.wav
NeroMix 1.4.0.4: Ahead AAC
VBR Tape; HQ; LC
Results so far:
Testname: 001 riteofspring 64kbps mp3/AAC
1R = .\Samples\001 riteofspring.wav.wav
2R = .\Samples\001 riteofspring_qt_44.wav
3R = .\Samples\001 riteofspring_CEP_dev.wav
4L = .\Samples\001 - riteofspring_Nero.wav
5L = .\Samples\001 riteofspring_qt_32.wav
6L = .\Samples\001 riteofspring_CEP_LP11.wav
General Comments:
1R File: .\Samples\001 riteofspring.wav.wav
1R Rating: 2.0
1R Comment: Lowpass sounds too low most of the time
annoying ringing sometimes
watery sound
warbeling of higher frequency background sounds/noise
2R File: .\Samples\001 riteofspring_qt_44.wav
2R Rating: 3.8
2R Comment: Lowpass high enough: Lack of sharpness/brighness at a few points
ringing/warbeling hard to notice.
3R File: .\Samples\001 riteofspring_CEP_dev.wav
3R Rating: 2.5
3R Comment: Practically identical to 1 in:
"Lowpass sounds too low most of the time
watery sound
warbeling of higher frequency background sounds/noise"
but almost no ringing
the background warbeling is a little bit stronger sometimes.
4L File: .\Samples\001 - riteofspring_Nero.wav
4L Rating: 2.8
4L Comment: Lowpass noticable but not annoying (similar to 2)
but much ringing/warbeling/watery sound similar to 3
5L File: .\Samples\001 riteofspring_qt_32.wav
5L Rating: 3.8
5L Comment: No difference to 2:
6L File: .\Samples\001 riteofspring_CEP_LP11.wav
6L Rating: 2.4
6L Comment: Same as 3
"Practically identical to 1 in:
'Lowpass sounds too low most of the time
watery sound
warbeling of higher frequency background sounds/noise'
the background warbeling is a little bit stronger sometimes."
but a bit more ringing (far less than 1)
ABX Results:
Original vs .\Samples\001 riteofspring.wav.wav
   8 out of 8, pval = 0.004
Original vs .\Samples\001 riteofspring_qt_44.wav
   11 out of 12, pval = 0.003
Original vs .\Samples\001 riteofspring_CEP_dev.wav
Original vs .\Samples\001 - riteofspring_Nero.wav
Original vs .\Samples\001 riteofspring_qt_32.wav
Original vs .\Samples\001 riteofspring_CEP_LP11.wav
.\Samples\001 riteofspring_CEP_dev.wav vs .\Samples\001 riteofspring_CEP_LP11.wav
_______________________________
Testname: 002 bigye 64kbps mp3/AAC
1L = .\Samples\002 bigye.wav.wav
2L = .\Samples\002 bigye_CEP_LP11.wav
3R = .\Samples\002 - bigye_Nero.wav
4R = .\Samples\002 bigye_CEP_dev.wav
5L = .\Samples\002 bigye_qt_44.wav
6R = .\Samples\002 bigye_qt_32.wav
General Comments:
1L File: .\Samples\002 bigye.wav.wav
1L Rating: 1.8
1L Comment: Most annoying:
1. Ringing
2. Lowpass
3. smeared drums
Other problems don't matter in comparison
2L File: .\Samples\002 bigye_CEP_LP11.wav
2L Rating: 1.6
2L Comment: Same as 1:
Most annoying:
1. Ringing (slightly worse than 1)
2. Lowpass
3. smeared drums
3R File: .\Samples\002 - bigye_Nero.wav
3R Rating: 3.8
3R Comment: lowpass hard to notice
a few positions with slight chirping/warbling/smearing on cymbals/hihats
4R File: .\Samples\002 bigye_CEP_dev.wav
4R Rating: 2.4
4R Comment: Same as 1 + 2, but less ringing
5L File: .\Samples\002 bigye_qt_44.wav
5L Rating: 4.0
5L Comment: same as 3 but hihats sound a bit better
6R File: .\Samples\002 bigye_qt_32.wav
6R Rating: 4.2
6R Comment: same as 3, 5 but hihats sound best
ABX Results:
Original vs .\Samples\002 bigye.wav.wav
___________________________________
Testname: 006 experiencia 64kbps mp3/AAC
1L = .\Samples\006 experiencia_CEP_dev.wav
2R = .\Samples\006 experiencia_qt_44.wav
3L = .\Samples\006 experiencia_qt_32.wav
4L = .\Samples\006 experiencia.wav.wav
5R = .\Samples\006 - experiencia_Nero.wav
6R = .\Samples\006 experiencia_CEP_LP11.wav
General Comments:
1L File: .\Samples\006 experiencia_CEP_dev.wav
1L Rating: 2.2
1L Comment: Lowpass
Ringing
Smeared transients
2R File: .\Samples\006 experiencia_qt_44.wav
2R Rating: 3.8
2R Comment: Smeared percussion; almost no ringing, warbling; lowpass sounds noticable but ok
3L File: .\Samples\006 experiencia_qt_32.wav
3L Rating: 3.8
3L Comment: Same as 2:
4L File: .\Samples\006 experiencia.wav.wav
4L Rating: 1.8
4L Comment: As 1:
Lowpass
Ringing (much more)
Smeared transients
5R File: .\Samples\006 - experiencia_Nero.wav
5R Rating: 3.8
5R Comment: More accurate than 2 & 3 (sharper percussion) but sometimes slight ringing; hard to tell which is better
6R File: .\Samples\006 experiencia_CEP_LP11.wav
6R Rating: 1.9
6R Comment: As 4:
Lowpass
Ringing (a bit better)
Smeared transients
ABX Results:
So far
for AAC quicktime is better (no mentionable difference between sampling rates);
for mp3 FHG Fraunhofer at default 64kbps settings is better. Here things could change because at least the extreme stereo samples seem to sound extremely crappy with FHG's intensity stereo. L8r.
Pre-Test thread
Reply #91
Next result: The Chopin Piano sample. To me surprising compared to previous ones:
- lame performed far better than FHG
- Ahead AAC was worst of all codecs!
Testname: 003 ChopinPolonaiseDMoll 64kbps mp3/AAC
1L = .\Samples\003 ChopinPolonaiseDMoll_qt_32.wav
2L = .\Samples\003 ChopinPolonaiseDMoll.wav.wav
3R = .\Samples\003 ChopinPolonaiseDMoll_qt_44.wav
4L = .\Samples\003 ChopinPolonaiseDMoll_CEP_dev.wav
5R = .\Samples\003 ChopinPolonaiseDMoll_CEP_LP11.wav
6L = .\Samples\003 - ChopinPolonaiseDMoll_Nero.wav
General Comments:
1L File: .\Samples\003 ChopinPolonaiseDMoll_qt_32.wav
1L Rating: 3.5
1L Comment: Sounds half-good; lowpass detectable but not annoying; ringing, also pre-echo-like (not that much) most annoying artifact; high frequeny noise-like echo reduced on high notes.
2L File: .\Samples\003 ChopinPolonaiseDMoll.wav.wav
2L Rating: 4.0
2L Comment: Sounds good (similar to 1); lowpass detectable but not annoying; very small amount of warble on highest notes; high frequeny noise-like echo reduced on high notes.
3R File: .\Samples\003 ChopinPolonaiseDMoll_qt_44.wav
3R Rating: 4.4
3R Comment: Without focussing on a few seconds everything sounds fine. In ABX situation high frequency warbeling/ringing detectable.
4L File: .\Samples\003 ChopinPolonaiseDMoll_CEP_dev.wav
4L Rating: 3.0
4L Comment: Most noticable: Pre-echo on low notes; compared to this other problems (similar to 1, 2) don't matter.
5R File: .\Samples\003 ChopinPolonaiseDMoll_CEP_LP11.wav
5R Rating: 2.8
5R Comment: Almost the same as 4 but a little bit more ringing
6L File: .\Samples\003 - ChopinPolonaiseDMoll_Nero.wav
6L Rating: 2.0
6L Comment: Annoying: Warbeling (especially on echos: metallic sound); watery sound. Lowpass no problem here in comparision.
ABX Results:
Original vs .\Samples\003 ChopinPolonaiseDMoll_qt_44.wav
New Results:
Testname: 004 Daft_Punk___Da_Funk mp3/AAC
1R = .\Samples\004 Daft_Punk___Da_Funk.wav.wav
2L = .\Samples\004 Daft_Punk___Da_Funk_CEP_LP11.wav
3L = .\Samples\004 Daft_Punk___Da_Funk_qt_32.wav
4L = .\Samples\004 Daft_Punk___Da_Funk_qt_44.wav
5L = .\Samples\004 Daft_Punk___Da_Funk_CEP_dev.wav
6R = .\Samples\004 - Daft_Punk___Da_Funk_Nero.wav
General Comments:
1R File: .\Samples\004 Daft_Punk___Da_Funk.wav.wav
1R Rating: 1.5
1R Comment: Smeared transients, high frequency cutoff much too low, ringing
2L File: .\Samples\004 Daft_Punk___Da_Funk_CEP_LP11.wav
2L Rating: 1.3
2L Comment: Same as 1: Smeared transients, too low cutoff, ringing; but ringing is slightly more annyoing
3L File: .\Samples\004 Daft_Punk___Da_Funk_qt_32.wav
3L Rating: 3.0
3L Comment: Most annoying: lack of brightness, smeared transients
4L File: .\Samples\004 Daft_Punk___Da_Funk_qt_44.wav
4L Rating: 3.0
4L Comment: Same as 3
5L File: .\Samples\004 Daft_Punk___Da_Funk_CEP_dev.wav
5L Rating: 1.5
5L Comment: similar to 1 + 2, but almost no ringing. Transients even more smeared. Can't tell if 1 or 3 is better/worse
6R File: .\Samples\004 - Daft_Punk___Da_Funk_Nero.wav
6R Rating: 2.3
6R Comment: similar to 3+4, but additional warbeling/watery sound. clearly worse.
ABX Results:
__________________________________________
Testname: 005 Enola_Gay 64kbps mp3/AAC
1L = .\Samples\005 Enola_Gay.wav.wav
2L = .\Samples\005 - Enola_Gay_Nero.wav
3R = .\Samples\005 Enola_Gay_CEP_LP11.wav
4L = .\Samples\005 Enola_Gay_qt_44.wav
5R = .\Samples\005 Enola_Gay_CEP_dev.wav
6R = .\Samples\005 Enola_Gay_qt_32.wav
General Comments:
1L File: .\Samples\005 Enola_Gay.wav.wav
1L Rating: 2.0
1L Comment: most audible/annoying: lowpass, ringing, warbeling, smeared drums
2L File: .\Samples\005 - Enola_Gay_Nero.wav
2L Rating: 3.5
2L Comment: Most noticable: lack of brightness, smeared hihats with slight ringing
3R File: .\Samples\005 Enola_Gay_CEP_LP11.wav
3R Rating: 2.0
3R Comment: same as 1
4L File: .\Samples\005 Enola_Gay_qt_44.wav
4L Rating: 3.3
4L Comment: same as 2 but less bright, less ringing, more smearing; slightly worse for me but a matter of taste I'd say.
5R File: .\Samples\005 Enola_Gay_CEP_dev.wav
5R Rating: 2.2
5R Comment: similar to 1 + 3 but almost no ringing. OTH less bright, slightly smearier. All in all a bit better.
6R File: .\Samples\005 Enola_Gay_qt_32.wav
6R Rating: 3.5
6R Comment: similar to 2 and 4. least ringing, same smearing as 4, therefore same rating as 2.
ABX Results:
Testname: 007 gone 64kbps mp3/AAC
1R = .\Samples\007 - gone_Nero.wav
2L = .\Samples\007 gone_qt_44.wav
3L = .\Samples\007 gone_qt_32.wav
4L = .\Samples\007 gone.wav.wav
5L = .\Samples\007 gone_CEP_dev.wav
6L = .\Samples\007 gone_CEP_LP11.wav
General Comments:
1R File: .\Samples\007 - gone_Nero.wav
1R Rating: 1.9
1R Comment: piano part: 2.0 - warbeling, watery, ringing
guitar part: 1.8 - still annoyingly watery + ringing sound
2L File: .\Samples\007 gone_qt_44.wav
2L Rating: 2.8
2L Comment: piano part: 3.4 - background noise gone or bumping pre-echo-like
guitar part: 2.2 - ringing, watery sound almost as bad as 1
3L File: .\Samples\007 gone_qt_32.wav
3L Rating: 2.8
3L Comment: piano + guitar part: same as 2
4L File: .\Samples\007 gone.wav.wav
4L Rating: 2.9
4L Comment: piano part: 3.8 - same as 2,3 but noise completely removed; sounds like lower cutoff but cleaner, less annoying
guitar part: 2.0 - ringing, warbeling (a little better than 2,3) but low cutoff
5L File: .\Samples\007 gone_CEP_dev.wav
5L Rating: 3.0
5L Comment: piano part: same as 4
Guitar part: same as 4, ringing slightly less annoying
6L File: .\Samples\007 gone_CEP_LP11.wav
6L Rating: 2.3
6L Comment: piano part: 2.5 - cutoff noticable = lack of brightness, background noise; (slightly) ringing transients
guitar part: 1.9 - similar to 5,6; a bit more annoying.
ABX Results:
Testname: 009 mybloodrusts.sample20sec 64kbps mp3/AAC
1L = .\Samples\009 mybloodrusts.sample20sec_qt_32.wav
2L = .\Samples\009 mybloodrusts.sample20sec_qt_44.wav
3L = .\Samples\009 mybloodrusts.sample20sec_CEP_dev.wav
4R = .\Samples\009 mybloodrusts.sample20sec_CEP_LP11.wav
5L = .\Samples\009 mybloodrusts.sample20sec.wav.wav
6R = .\Samples\009 - mybloodrusts.sample20sec_Nero.wav
General Comments:
1L File: .\Samples\009 mybloodrusts.sample20sec_qt_32.wav
1L Rating: 3.5
1L Comment: 1st part (left ear mono): good, only slight chirping on right channel, probably not noticable without headphones
2nd part: warbeling cymbals; no obvious lowpass problem
2L File: .\Samples\009 mybloodrusts.sample20sec_qt_44.wav
2L Rating: 3.0
2L Comment: similar to 1 but both problems more obvious
3L File: .\Samples\009 mybloodrusts.sample20sec_CEP_dev.wav
3L Rating: 1.5
3L Comment: 1st part: severe stereo separation problem
2nd part: high pitched drums totally smeared, replaced by warbeling
4R File: .\Samples\009 mybloodrusts.sample20sec_CEP_LP11.wav
4R Rating: 1.3
4R Comment: same as 3; warbeling more "chirpy", therefore more audible; OTH less loss of brightness; slightly worse than 3 I'd say.
5L File: .\Samples\009 mybloodrusts.sample20sec.wav.wav
5L Rating: 2.5
5L Comment: stereo separation in 1st part best of all samples
warbeling/cutoff/smearing similar to 3,4 but less annoying
6R File: .\Samples\009 - mybloodrusts.sample20sec_Nero.wav
6R Rating: 1.0
6R Comment: 1st part: other kind of stereo separation problem than 3,4 but similar annoying
2nd part: most awful chirping/warbeling
ABX Results:
edit: wrong result posted for "007 gone" - corrected.
Pre-Test thread
Reply #92
Hmm.. for plain AAC (not HE AAC)  I think that Ahead's  64 kbps CBR mode is better than 'Tape' preset.  Also, encoder in the latest Nero6 is better.
Pre-Test thread
Reply #93
Weird... for me LAME Polonaise sample is just unlistenable - it is flangy^H^H^H^H^H^Hphasey because of the dropouts!
(It is ~61kbps. I'll try --alt-preset CBR to see if it fixes anything)
FhG samples were just somewhat ringy and preechoey.
/EDIT\ For me, --alt-preset cbr 64 is a bit better on this sample. \EDIT/
ruxvilti'a
Pre-Test thread
Reply #94
Thanks for the info. If I get this right, this means the Nero Mix demo I've downloaded ~1 week ago doesn't contain the latest Ahead AAC encoder - correct? So ... I'll give Nero 6 a try. (Hopefully I get it uninstalled afterwards without any trouble.)
EDIT: I've just downloaded the latest Nero6 and had a look at the extracted files after starting installation: aacenc32.dll is the same version (2.5.5.1) that I had already in my Ahead/Shared folder (HE AAC encoding also works with NeroMix). Is there a newer one I've missed? - I guess not, so I'll start encoding 64kbps CBR ...
I won't test mp3 anymore. Enough time spent on it. The decision lame vs. FHG is still hard IMO.
Lame:
- more problems with ringing, warbeling, etc.
- sometimes quite good, sometimes quite annoying
+ much better for extreme stereo (everything on 1 channel)
+ preserves more details on transients
FHG:
- smeared transients
- problems with extreme stereo (Overrepresented in the test samples?)
+ ringing, warbeling not that bad most of the time
+ somehow constant performance over a broad variety of music
I'd probably choose FHG at CEP's 64kbps default setting (22.5kHz sampling rate).
Pre-Test thread
Reply #95
I guess the biggest problem of lame vs. FhG is for stereo imaging sensibility of listeners. Lame will probably have a quite better stereo image since it doesn't use IS at all.
Have you tried encoding with FhG with IS disabled?
Pre-Test thread
Reply #96
Not yet. good idea ...
Pre-Test thread
Reply #97
rjamorim: Didn't you say that you are looking for quality of the encoders? So i think PNS should be on when encodin AAC-LC with nero at this bitrate. Compatibility with portables should not be noticed in this test.
Pre-Test thread
Reply #98
Results
Settings used:
lame 3.90.3
--preset 64
<samplename>_CEP_is_narrow.wav
64kbps CBR, HQ, 22050Hz Samplingrate, default lowpass (10349Hz), joint stereo, intensity stereo, narrowing enabled
<samplename>_CEP_narrow.wav
64kbps CBR, HQ, 22050Hz Samplingrate, default lowpass (10349Hz), joint stereo, narrowing enabled, intensity stereo disabled
NeroMix 1.4.0.4: Ahead AAC (aacenc32.dll v. 2.5.5.1)
VBR Tape; HQ; LC
<samplename>_Nero_cbr.wav
CBR 64kbps; HQ; LC
Results:
General Comments:
1R File: .\Samples\001 riteofspring_qt_44.wav
1R Rating: 3.8
1R Comment: small lack of brightness, sharpness in a few places
2L File: .\Samples\001 riteofspring_CEP_is_narrow.wav
2L Rating: 2.2
2L Comment: low cutoff, warbeling, watery, ringing, mostly on transients
3R File: .\Samples\001 riteofspring.wav.wav
3R Rating: 2.0
3R Comment: similar to 2, ringing sometimes more annoying
4L Rating: 3.0
4L Comment: warbeling, ringing comparable to 2, 3 but bright as 1, more sharpness
5L File: .\Samples\001 riteofspring_CEP_narrow.wav
5L Rating: 2.2
5L Comment: same as 2
6L File: .\Samples\001 - riteofspring_Nero_cbr.wav
6L Rating: 3.2
6L Comment: same as 4 but a little less obvious
General Comments:
1L File: .\Samples\002 - bigye_Nero_cbr.wav
1L Rating: 3.0
1L Comment: flanging, ringing, smeared transients (hihats)
2R File: .\Samples\002 bigye.wav.wav
2R Rating: 1.5
2R Comment: lowpass, ringing, warbeling
3L File: .\Samples\002 bigye_CEP_narrow.wav
3L Rating: 2.0
3L Comment: similar to 2 but less annoying
4R File: .\Samples\002 bigye_qt_44.wav
4R Rating: 3.8
4R Comment: similar to 1 but much better (-> ringing), OTOH less sharp
5L File: .\Samples\002 - bigye_Nero.wav
5L Rating: 3.6
5L Comment: similar to 1 but less annoying
6R File: .\Samples\002 bigye_CEP_is_narrow.wav
6R Rating: 2.0
General Comments:
small annoyances with warbeling/flanging of different kinds with all samples; hard to judge which is worse (exept for 2)
1R File: .\Samples\003 ChopinPolonaiseDMoll_CEP_narrow.wav
1R Rating: 2.5
1R Comment: Pre-echo, cut-off sometimes too low
2R File: .\Samples\003 - ChopinPolonaiseDMoll_Nero.wav
2R Rating: 1.5
2R Comment: warbeling, ringing, watery; metallic echos
3L File: .\Samples\003 - ChopinPolonaiseDMoll_Nero_cbr.wav
3L Rating: 3.5
3L Comment: same problems as 2 but much better; sometimes bumbping low-pitched noise like sound added (15.8-19)
4L File: .\Samples\003 ChopinPolonaiseDMoll_CEP_is_narrow.wav
4L Rating: 2.5
4L Comment: same as 1
5R File: .\Samples\003 ChopinPolonaiseDMoll_qt_44.wav
5R Rating: 4.0
5R Comment: acceptable cutoff; not much ringing, pre-echo
6R File: .\Samples\003 ChopinPolonaiseDMoll.wav.wav
6R Rating: 3.0
6R Comment: similar to 1,4; less pre-echo
General Comments:
1R File: .\Samples\004 Daft_Punk___Da_Funk_qt_44.wav
1R Rating: 3.8
1R Comment: lack of brightness, high-pitched drums smeared, some ringing/warbeling problems
2R File: .\Samples\004 Daft_Punk___Da_Funk_CEP_is_narrow.wav
2R Rating: 2.0
2R Comment: cutoff, smeared, warbeling, flanging, ringing
3R File: .\Samples\004 - Daft_Punk___Da_Funk_Nero.wav
3R Rating: 3.0
3R Comment: similar to 1, more ringing/flanging, highpitched drums + brightness a bit better; all in all worse
4L File: .\Samples\004 Daft_Punk___Da_Funk.wav.wav
4L Rating: 1.5
4L Comment: similar to 2, ringing more annoying
5L File: .\Samples\004 Daft_Punk___Da_Funk_CEP_narrow.wav
5L Rating: 2.0
6L File: .\Samples\004 - Daft_Punk___Da_Funk_Nero_cbr.wav
6L Rating: 3.3
6L Comment: similar to 4 but more warbeling/dropouts; audible clipping at 5 sec.
General Comments:
1L File: .\Samples\007 gone_CEP_is_narrow.wav
1L Rating: 3.0
1L Comment: piano: cutoff, pre-echo, but not much annoying
guitar: cutoff, ringing , warbeling
2R File: .\Samples\007 gone_qt_44.wav
2R Rating: 2.5
2R Comment: piano: bright, but pumping noise, chirping, pre-echo
guitar: ringing, watery, metallic, brighter but more annoying than 1
3L File: .\Samples\007 - gone_Nero_cbr.wav
3L Rating: 2.3
3L Comment: piano: slightly warbeling noise, flanging
guitar: as 2 but more flanging
4L File: .\Samples\007 - gone_Nero.wav
4L Rating: 1.5
4L Comment: piano: 2.0 - warbeling, ringing, watery; lowpass
guitar: as 3 but even more flanging, ringing
5L File: .\Samples\007 gone.wav.wav
5L Rating: 2.8
5L Comment: same as 1, more ringing in guitar part
6R File: .\Samples\007 gone_CEP_narrow.wav
6R Rating: 3.0
6R Comment: same as 1
General Comments:
1R File: .\Samples\009 mybloodrusts.sample20sec_CEP_is_narrow.wav
1R Rating: 1.5
1R Comment: bad stereo problem in 1st part
2L Rating: 2.5
2L Comment: slight chirping in 1st part
2nd part strong chirping on cymbals
3L File: .\Samples\009 mybloodrusts.sample20sec.wav.wav
3L Rating: 2.5
3L Comment: lowpass, but best stereo reproduction
2nd: cutoff -> loss of details but flanging + ringing not that annoying
4R File: .\Samples\009 - mybloodrusts.sample20sec_Nero_cbr.wav
4R Rating: 1.5
4R Comment: worst stereo problem in 1st part
2nd part not as annoying as 6 but similar
5R File: .\Samples\009 mybloodrusts.sample20sec_CEP_narrow.wav
5R Rating: 2.4
5R Comment: 1st part: same as 3 but more flanging
2nd part similar to 3
6L File: .\Samples\009 - mybloodrusts.sample20sec_Nero.wav
6L Rating: 1.5
6L Comment: 1st part: bumping stereo problem, 2nd awful warbeling, ringing
Conclusions:
In the case where FHG with intensity stereo failed badly before it's improved very much without IS. No general differences detectable, so FHG without IS seems to be the best choice for 64kbps mp3.
Most of the time using CBR improves the performance of Nero AAC but Quicktime is still better.
Pre-Test thread
Reply #99
Conclusions:
Great! Thanks a lot for your invaluable help.
So, here's an updated list of codecs to be featured:
-Nero HE AAC
-Ogg Vorbis
-MP3pro
-WMAv9 std
-Apple AAC LC
-Higher anchor: Lame --alt-preset 128
-FhG MP3 64kbps w/o IS
Real is on hold due to reasons out of my league. I'll know if it'll be featured or not by the weekend.
