Topic: MilkDrop 3.2 + 800 presets - An audio visualizer (Read 2473 times) previous topic - next topic
Hey guys if you like audio visualizer / MilkDrop, I've made MilkDrop 3.0, and version 3.2 just last week!
It work with any audio source (so foobar2000!), it's 100% compatible with all the MilkDrop's presets,
and bring tones of new features compare to version 2.0.
I've listed the new stuff here : https://github.com/milkdrop2077/MilkDrop3
How to download and install : https://youtu.be/OQdZFlOHe5o
All the new features explained (3.0) : https://youtu.be/QBsDXPENe1I
How to create a beautiful double-preset : https://youtu.be/AdcUPpp1O0k
What's new in version 3.2 compare to 3.1:
- 300+ presets, new HD textures, new HD patterns.
-Double-preset are now displayed correctly when entering/exiting full screen or resizing the window.
-Live blending: pressing the keys 'p' and 'P' will display directly pattern or progress, no more backspace/spacebar needed!
-Reload a double-preset: pressing 'o' will reload a double-preset only with different random values,
very handy to see different plasma blend for example
-Flip presets: press 'u' to flip preset 1 and 2 (and keep the exact position)
-Locked direction: press 'U' to force the direction of the blending,
ex: if you are using the cercle pattern, -1 = from the INSIDE, 1 = from the OUTSIDE
-Block a preset: press 'b' to lock a preset, it will always load first when creating a double-preset (F9 and then SPACEBAR)
-Press 'B' to choose the blending time
-When pressing F4, you can now see both preset names if it's a double-preset
-New borderless mode with F7
-New delete mode: press CTRL+DELETE to start or exit delete mode:
Now you can delete any preset you see simply by pressing the DELETE key (no need to load the list and confirmation)
Very handy if you want to clean a large number of presets, be careful you can't restore a deleted preset!
-When pressing the keys A,D,M,Z or F9, it will auto-switch to 'Show only classic-presets' to avoid any mash-up errors.
-Added the Beginners Guide to MilkDrop Preset Writing in html and doc in the Milkdrop3\docs folder
-Lot's of small bugs fixed...
download : https://github.com/milkdrop2077/MilkDrop3
peace
Re: MilkDrop 3.2 + 800 presets - An audio visualizer
Thank you milkdrop2077 !!
milkdrop is intergalactic, great to see efforts in continuation and even further enhancements, wow!
looks promising and fully loaded - will need some time to check it out in detail..summertime and summertime and AUS-NZ-worldcup  :)
just watched the transition-feature-video.. I must admit, I guess I need to watch it several times to recognize each shown transition between these 2 used psychodelic vizs  :D
This looks...exceptionally promising.
I recall Sardu (of NESticle fame) doing a GL4/GLES2 port of MilkDrop2 as well.
you mean this one? https://github.com/iaddis/milkdrop2020
fun story I never really understood what it does, almost no description on GitHub page, code doesn't compile easily and no release version to test.
Creating double-preset in MilkDrop3 is insanely easy, I recommend everyone to watch this video https://youtu.be/AdcUPpp1O0k
Just buy pressing a few keys, and without any lines of code, you can create new beauties like this:
This is a sweet mix of 2 of the best ever created presets, martin - blue haze + cope - the drain to heaven!
If you make any good .milk2 presets, please send them to me, I'll include them in the next version :)
